| Rjgk2012 |
 Rjgk2012 Two Stroke Sniffer
| stevo123 |
 stevo123 Nitrous Nuisance
| Easy-X |
 Easy-X Super Spammer
 Posted: 19:46 - 17 May 2020 Post subject: |
Valve clearances! inb4 Nobby
Seriously though, that could be it. Also have a peek in your airbox to see if all looks normal. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Rjgk2012 |
| Easy-X |
| Rjgk2012 |
| Easy-X |
 Posted: 19:51 - 23 May 2020 Post subject: |
Eh? With all due respect I think you must be doing it wrong. I had a Superlight for... well, long enough to check the valve clearances a few times
Anyhoo, 3 or 4 bolts for the rocker cover. It will come off the bike if you're careful. Worse ways loosen the tank so you can lift it a few millimetres to get some clearance. Now you have the rocker arms exposed you should see them move up and down if you push the bike in gear or perhaps (but less accurate) dick with the kickstarter. Most accurate is to pop off an engine cover and turn the flywheel by hand.
Get the arm you're looking at (inlet or exhaust) to close so there's no pressure on it and then break out the feeler gauges. I couldn't tell you the correct gap right now but it should be in the user manual. Don't mix up metric and imperial if your gauges have both numbers etched on!
I would imagine they will need (re)adjusting so just be very careful to hold the square bit steady with some small pliers while you tighten the nut as every fraction of a millimetre counts
<addendum> apologies in advance for the incoherence, best I can manage after a litre of rosé! ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
The last post was made 6 years, 176 days ago. Instead of replying here, would creating a new thread be more useful? |
