Royal Enfield Bullet 500 '94 oil leak
piratebiker
PostPosted: 15:02 - 18 May 2020    Post subject: Royal Enfield Bullet 500 '94 oil leak Reply with quote
Calling Stinkwheel, what gaskets do I need to fix the oil leak indicated by the arrows, & where to buy them? Thanks man.
wr6133
PostPosted: 15:17 - 18 May 2020    Post subject: Reply with quote
Question 2 try here https://accessories.hitchcocksmotorcycles.com/
PostPosted: 15:55 - 18 May 2020    Post subject: Reply with quote
Head gasket and base gasket. As above, hitchcocks have all the stuff.
If you want a reliable UK supplier a bit cheaper, try price part motorcycles.
Not sure if he stocks the composite ones I preferr.
https://accessories.hitchcocksmotorcycles.com/accessory-shop/Head-Gasket-Composite/7675
Order a new carb manifold gasket and a couple of new rocker cover gaskets at the same time in case you tear them, they are too cheap to even bother cutting you own out.
You may also need new copper washers on the rocker oil feed banjos although from your picture, it might already have dowtyu washers on there. You'll need 4.
Or they do a set, but that has a copper sandwich gasket in.
https://accessories.hitchcocksmotorcycles.com/accessory-shop/Engine-Gasket-Sets/18417
Detailed instructions here:
https://accessories.hitchcocksmotorcycles.com/core/media/media.nl?id=188640&c=1062795&h=63b42a9f939e026c61d2&_xt=.pdf
Do NOT pull the splitpin out of the decompressor valve, back-off and remove the cable. There is no need to disturb it when fitting a new head gasket.
Getting the head off can be a total sod because the washers under the head nuts often deform and grip the studs. A lot of bullet owners loosen off the head nuts then start the engine to get it moving. May also be worth getting a set of hardened washers for refitting.
https://accessories.hitchcocksmotorcycles.com/accessory-shop/cylinder-head/18645
PostPosted: 16:09 - 18 May 2020    Post subject: Reply with quote
I'll add, looks like you have the large rocker banjo bolts, so 12mm. You'll need 4. Either copper washers or re-useable (and better) bonded seal (Dowty) washers.
piratebiker
PostPosted: 16:34 - 18 May 2020    Post subject: Reply with quote
Thanks guys.
PostPosted: 18:14 - 18 May 2020    Post subject: Reply with quote
If the head's being a particular bugger, Lone Wolf has a tip here :-
https://www.moonshiners.org.uk/bulletheadgone.htm
The last post was made 6 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.42 Sec - Server Load: 3.6 - MySQL Queries: 13 - Page Size: 48.69 Kb
