| topperuk |
 topperuk L Plate Warrior
| jeffyjeff |
 jeffyjeff World Chat Champion
| redeem ouzzer |
| Bhud |
 Bhud World Chat Champion
| Riejufixing |
| A100man |
 A100man World Chat Champion
 Posted: 21:35 - 18 May 2020 Post subject: Re: Brake Bleed Nipples "weeping" |
| Riejufixing wrote: |
If you apply too much torque to your nipples, it is possible that you will experience weeping.
I never miss one of these..
..not ever.
 ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| A100man |
 Posted: 21:37 - 18 May 2020 Post subject: |
FWIW I don't the think the requirement is to pull the lever back using full pressure. you only need to open the passages to allow ar bubbles to float up. A modest but sustained pull-back usually satisfies. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Nobby the Bastard |
| sickpup |
 sickpup Old Timer
| jeffyjeff |
 Posted: 09:04 - 19 May 2020 Post subject: |
After hearing the voices of reason (thank you Forced and sickpup), I stand corrected.
But I still question why anyone would cable tie the brake lever in order to "get any last air" out of the system. Once the master cylinder piston seal covers the compensating port, all path of air escape is effectively blocked. How is pressurizing the brake line going to help air float up to the top---magic? If you can pull your brake lever all the way to the handlebar, something is wrong. Either there is still air in the system, you have a leaking seal, or you have bent the brake lever.
Correct me if I'm wrong, but I have bled hundreds of brakes successfully, (including the VFR linked brakes and the BMW servo assist) without resorting to a cable tie on the brake lever. ____________________ History shows again and again how nature points out the folly of men. BOC
Getting old ain't for wimps. R.S. Hain |
| sickpup |
 sickpup Old Timer
| topperuk |
| Kris |
 Kris World Chat Champion
| sickpup |
 sickpup Old Timer
| Riejufixing |
| Kris |
| Riejufixing |
| Riejufixing |
 Posted: 10:25 - 19 May 2020 Post subject: |
| Kris wrote: | | sickpup wrote: | (PTFE) No it doesn't work, it's dangerous. The thread is not the seal. |
The tape isn't actually a sealant, it's a lubricant to allow the connection to tighten further. And it's used in many hydraulic systems with a higher pressure than a brake system on a bike. Just don't add too much tape and keep it away from the leading 2 threads. |
I will go all out and say:
sickpup: I certainly agree that the threads of the bleed nipple are not the seal, in any way whatsoever.
OP: Think about it! Think about where the bleed hole at the bottom of the hole is, that connects to the bore of the bleed nipple, and where the thread seal would go. It's not sealing *anything*. It's useless yo put it there, perhaps worse than useless as it will alter the twist that you or a torque wrench feel when doing up the thread, and it will start to disintegrate during the bleeding process.
Kris: Yes, PTFE does have lubricating properties.
Kris: The tape is most certainly a sealant too, and yes, is used in high pressure as well as low pressure applications, and also by some plumbers etc. where it should not be used, e.g. compression fittings. |
| sickpup |
 sickpup Old Timer
| topperuk |
| Riejufixing |
| kolu |
 kolu Nova Slayer
| sickpup |
 sickpup Old Timer
| Nobby the Bastard |
| weasley |
 weasley World Chat Champion
The last post was made 6 years, 180 days ago. Instead of replying here, would creating a new thread be more useful? |
