Under-bucket shims - Yamaha
A100man
PostPosted: 10:11 - 20 May 2020    Post subject: Under-bucket shims - Yamaha Reply with quote
Hi All
FZ750 weeping rocker cover gasket => Change it => Better check valves while I got all the rad etc.. off.
Bugger 80% are tight or under the limit..
..Cams out Rolling Eyes
Now need a good handful of shims. Are these universal across different nikes 7.48mm size crops up on ebay..
..or does anyone operate a swaps pool?
Nobby the Bastard
Harley Gaydar
PostPosted: 12:03 - 20 May 2020    Post subject: Reply with quote
I have some here but they are probably similar size to the ones you've got. Your best bet is fz proboards on facebook.
The admin used to run one
Just measured one. 7mm exactly. Wemoto used to supply them so you can try there.
Triumph Sprint ST 1050
A100man
PostPosted: 13:31 - 20 May 2020    Post subject: Reply with quote
Hi Nobby
yes I'm on ProBoards, (but not FB cos I'm old and curmudgeonly)
Also found this site which appears to sell at a bargain price..
https://www.racing-planet.co.uk/
Nobby the Bastard
Harley Gaydar
PostPosted: 15:04 - 20 May 2020    Post subject: Reply with quote
You could try fowlers as well.i 2would say mine are available to you but like I said, mine seem to be the originals and would probably be too thick.
Let me know which ones you need just in case, though.
The only warning I'd give you is to watch for the chain to jump after you reassemble. The tensioner doesnt always kick in as soon as it needs to and the slack can cause the chain to jump.
Not really an issue but turn it over by hand before putting the valve cover back on just in case.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:20 - 20 May 2020    Post subject: Reply with quote
Graham from proboards says he couldnt find his last week when someone asked so you've probably already asked him on proboards.
jeffyjeff
PostPosted: 17:26 - 20 May 2020    Post subject: Reply with quote
Just 'cause you don't have a FB account does not mean you're old and curmudgeonly. Mark Zuckerburg belongs in prison for what he did to my country. Sheryl Sanders too!
A100man
OK I had just PM'd Graham so I'll expect the worst in that case. Cheers
Copycat73
PostPosted: 17:28 - 20 May 2020    Post subject: Reply with quote
when i did my R1 .. got the shims from here https://www.wemoto.com/
more than adequate ... Thumbs Up
caveat emptor
yen_powell
PostPosted: 18:03 - 20 May 2020    Post subject: Reply with quote
Some bike places will swap your shim for one of the size you want with a small charge.
XT1200Z and a DR350 in bits
Pigeon
PostPosted: 23:21 - 20 May 2020    Post subject: Reply with quote
I tend to go for Hot Cams shims if possible.
Have also used dirtbikestore and ordered individual shims over the years.
Always measure with a micrometer so am sure what goes in is ok.
Checked 15k miles later and things still in spec.
Pigeon
PostPosted: 23:28 - 20 May 2020    Post subject: Reply with quote
From memory, Triumph Service manual says to rotate the engine backwards 1/2 a turn first to trigger the CCT and then go through the usual clockwise rotations.
Something about keeping the slack past the sprockets until the CCT fully engages.
I might be talking utter shite though.
Fizzer Thou
PostPosted: 12:34 - 21 May 2020    Post subject: Reply with quote
I have two large boxes of the Hot Cams shim kits that were bought from a friend who sold his WR450F and no longer had a need for them.Since then i have added my spares that I have accrued over the years of Yamaha ownership ie. the Exup1000 and 5JJ-R1.
If the clearances are negative and there is insufficient space to get even the thinnest of feeler gauge in to place,then the only way would be to remove each shim and note the etched size...or in the worst case scenario to measure those where the size has been worn away...then to plot them on a table and try and ascertain where you can move them around so as to work out what size you need where.
What I found easiest was to support the cam chain in the middle of the cylinder head,then to have one cam bolted in to place and sort those sizes first,turning the cam by hand with the pistons/crankshaft positioned so that they are halfway up the bores so that there is no interference with the opening valves.Then,if it is possible to correctly ascertain the correct clearances using the shims from both inlet and exhaust,order only those that you need from the likes of Wemoto or Yambits,which is where I bought spares from before I bought the Action Cams kits.
When the cam chain tensioner is about to be reinstalled,I found that pressure onto the rear tensioner blade was sufficient to be able to double check that the cams were aligned correctly with the crank timing marks.Only once I was happy with this did I finally insert the tensioner spring and locking bolt.Double checking by turning the engine over by hand several times by using a homemade tool that bolts into the left hand side of the crank helped.Otherwise it is putting the gearbox into first and turning the engine over by rotating the back wheel...which is not very accurate.
Always have a 'Plan B'
Nobby the Bastard
Harley Gaydar
PostPosted: 13:16 - 21 May 2020    Post subject: Reply with quote
I'm pretty sure exup engines are a different beast to the fz engine. Fz has shims 7 mm diameter and I seem to remember that fzr ones are much bigger .
Fz shim below.
https://i.imgur.com/voT6aVL.jpg
Fizzer Thou
PostPosted: 14:55 - 21 May 2020    Post subject: Reply with quote
https://www.ebay.co.uk/itm/7-48mm-Hot-Cams-Shim-Kit-1-20-3-50-In-0-05mm-Increments-3-Of-Each-Size-HCSHIM01/303240486911?hash=item469a8a9fff:g:h7YAAOSwuaFZ3lYo
While being larger they are not substantially larger at 7.48mm.
The kit that Pigeon used as an example is almost exactly what I have got that I use on the R1 and Exup.
I looked on the Wemoto and Yambits websites and surprisingly there is no mention of clearance adjusting shims.But cmsnl.com show them
https://www.cmsnl.com/yamaha-fz750-1986-1tv-england-261tv-310e2_model37291/padadjusting-120_1aa1216800/#.XsaVA9t7nIU
...as do Fowlers of Bristol,to some extent....
https://www.fowlersparts.co.uk/parts/4043395/fz750-1tv-1986-999-b/valves-and-springs?noredir=1
...but they are expensive for those that are available Shocked
A100man
PostPosted: 09:00 - 19 Jun 2020    Post subject: Reply with quote
OK so finally got this job buttoned up having been donated some shims by Nobby Thumbs Up and the rest exchanged at Flitwick..
However post reassembly check shows they are still tight in places, in fact one or too are tighter!
I'm 99.9% sure I swapped correctly then I recalled I had to pry a little to get the intake cam out it was kind of stuck on the locating web.
Did I bend the intake cam?
Couldn't really notice any tight spots turning by hand but I wasn't really paying attention to that.
I ran it around on the starter a few times to see if it need to bed in but it made little difference - the intakes in questions should have been back up to six thou (0.15mm) on #4 but are still around three thou even after a shim swap.
Think I might plastigauge the top caps on the intake cam.
Thoughts?
Nobby the Bastard
Harley Gaydar
PostPosted: 09:24 - 19 Jun 2020    Post subject: Reply with quote
It's not unknown for people to grind shims down. Did you check the shims you took out were actually the size they purported to be?
I only ask because the ones in yours were suspiciously big. Most of the ones that came out of my fz at about 50k miles were too thin to be of use.
A100man
PostPosted: 09:46 - 19 Jun 2020    Post subject: Reply with quote
Hi Nobby
Engine purportedly only has 25K on it, but in reality anyone's guess.
That thought crossed my mind too - tricky buggers to measure with what I have..
Thinks .. stick a rod in first then zero against that length (dim-wit) Rolling Eyes
Might still plastique anyway for the cost. another new experience too.
All the fun of the fair eh?
Nobby the Bastard
Harley Gaydar
PostPosted: 09:54 - 19 Jun 2020    Post subject: Reply with quote
As the ones in there seem to result in tight valves despite being smaller sized than the ones that came out I reckon you can be reasonably confident in measuring the gap using them.
A100man
PostPosted: 13:06 - 19 Jun 2020    Post subject: Reply with quote
My concern was if I had bent the camshaft slightly some clearances might be smaller than expected and some larger.. I suppose either way it's all got to come apart again.. Took bloody ages almost impossible to get a torque wrench onto the sprocket bolts then titting about putting the bike in gear out of gear rotate etc.. etc.. Rolling Eyes
Nobby the Bastard
Harley Gaydar
PostPosted: 21:11 - 19 Jun 2020    Post subject: Reply with quote
From what graham told.me when he taught me how to do it, cams are more.likely to snap than bend.
You did make sure that you numbered all the buckets when you took them out?
A100man
PostPosted: 21:20 - 19 Jun 2020    Post subject: Reply with quote
KInda.. Placed in a large numbered egg box.. There's are chance on or two got swapped though Rolling Eyes
A100man
PostPosted: 21:06 - 22 Jun 2020    Post subject: Reply with quote
Ok, new theory. Went through the ball-ache of taking the inlet cam out again to check the under-reading valves. The offending shims were the values I thought so no drama there. Then, on replacing, I noticed it wouldn't seat properly on the valve stem, I think because i'd dabbed them with assembly lube and there was some trapped air .. meaning that the inverted cup shim on top of the valve stem made a kind on pneumatic damper.
Could it be that when the valve is closed (point of clearance measure) the shim & bucket are being pushed up by the 'damper'. Pre-work the clearance was 6 thou on the dodgy ones and after reassembly with the sticky lube I could barely pass a 2 thou feeler through two of them..
Nobby the Bastard
Harley Gaydar
PostPosted: 21:20 - 22 Jun 2020    Post subject: Reply with quote
You shouldnt need any lube there. There wont be any movement between the valve stem and the shim to need lube to prevent wear.
Remove the lube and refit.
A100man
PostPosted: 22:34 - 22 Jun 2020    Post subject: Reply with quote
Crazy thing is that i had all shims set back together then spotted an italic note in Clymer manual saying to grease with moly or assy lube. Rolling Eyes
So you reckon my trapped air theory stands up ?
Nobby the Bastard
Harley Gaydar
PostPosted: 07:37 - 23 Jun 2020    Post subject: Reply with quote
Trapped air or grease, yes. Quite possible.
If you do want to add grease then between the shim and cap would be preferable
The last post was made 6 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 130.62 Kb
