Suzuki Gn125 SLide carb install ?
MrGMoto
PostPosted: 21:47 - 18 May 2020    Post subject: Suzuki Gn125 SLide carb install ? Reply with quote
Hey my dudes.. I haven't been on here for a while but I thought I would rejoin the joys of the BikeChatForums Very Happy
Okay here is my question...welll sort of a question as well as me asking for some friendly advice.
My friend used to own a Suzuki GN125, the original carb that came with it was pretty shot, he brought a Chinese one off ebay, only to learn that they cap off the mixture screw so you can't tamper with fuelling for emissions purposes.
I then came up with the idea if fitting a old 28mm slide carb that came off one of my Yamaha YBRs, modified the cable to fit and it worked. He said it had more power etc. I never got to ride it with that carb on it.
I was just wondering if anyone knew what the difference would be between a CV Carb vs a Slide carb on a gn and what differences I would notice would be.
My carb is currently the CV style but the diagram has wear when the rubber has made little pin holes on the creases, as a temp fix I have put some silicone sealant over the pin holes and have improved the bikes running state but not 100% as I can not find the correct one
Any help would be great
Very Happy
Hands on is the better way to work!
Easy-X
PostPosted: 11:03 - 19 May 2020    Post subject: Reply with quote
CV carb the airflow and needle control are separate, the one follows the other obviously but there is a lag - the fuel flow is reactionary. Looking at the extremes a scooter wants a CV carb as you tend to go max throttle all the time with a CVT.
Slide carb the airflow and needle control are linked. More airflow and fuel simultaneously dumped down the throat of a greedy engine. More responsive but less efficient. But you can't go max throttle straight from the get go.
Horses for courses then, efficiency and convenience vs responsiveness.
jeffyjeff
PostPosted: 07:08 - 20 May 2020    Post subject: Reply with quote
Back in the day, I had a 1973 Honda CB450. Knowing no better, I thought I would get more power from increasing the carb size. I swapped out the Kehin CV carburetors for Mikuni slide carburetors. Don't remember the precise throat diameter, but the Mikuni's were 4mm over the stock Kehins (maybe like 28mm > 32mm).
The bike did not have noticeably more power, and when I whacked the throttle wide open on the Mikuni's, the slide reacted so quickly that velocity of air flow through the venturi decreased. The bike would stall out. I could counter that effect by modulating my right hand. Ultimately, I reinstalled the stock carburetors, sold the bike, and got a bigger one.
History shows again and again how nature points out the folly of men. BOC
Getting old ain't for wimps. R.S. Hain
Robby
Dirty Old Man
PostPosted: 15:08 - 21 May 2020    Post subject: Reply with quote
You should be able to get a new diaphragm from NRP carbs.
The last post was made 6 years, 178 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 40.77 Kb
