| c_dug |
 c_dug Super Spammer
 Posted: 20:41 - 21 May 2020 Post subject: 2t Aprilia RS125 - running temperatures |
This morning I eventually put my little Aprilia back on the road after sitting unused for probably two full years now, maybe 3.
I've really not ridden it much at all and so perhaps it's always been this way, but according to the dash temperature it never really warmed up. When I first switched it on it showed 71°c which is obviously wrong, then dropped down to mid/low 60s when I started it up.
It did fluctuate a bit on the ride, but I never saw above 72°c at the absolute highest, and it would drop down to maybe 66ish or thereabouts at times.
It ran perfectly the whole time, I probably covered 20 odd miles, I didn't give it the beans for a good few miles just to be safe.
I'm guessing it shouldn't be showing 70°c before it's even started so something is up, what should I be checking? ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| P.addy |
 P.addy Red Rocket
| c_dug |
 c_dug Super Spammer
| Kickstart |
 Kickstart The Oracle
| 1198 |
 1198 World Chat Champion
| jeffyjeff |
 jeffyjeff World Chat Champion
| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| c_dug |
 c_dug Super Spammer
| Kickstart |
| jeffyjeff |
| stevo as b4 |
 Posted: 16:52 - 22 May 2020 Post subject: |
Two strokes like to be kept cool generally, with a lot of generalizations.
I know that 55degrees coolant temperature will always be better than 75 degrees coolant temp on a two stroke. If you ride your Aprilia gently for at least 10min after starting it from cold it will have opened the thermostat by then if it was going to open which is the important thing, regardless of what the number on the gauge says. |
| Old Git Racing |
 Old Git Racing World Chat Champion
| c_dug |
 c_dug Super Spammer
 Posted: 17:53 - 13 Jul 2020 Post subject: |
Looking into this further at the moment, I've installed a new sensor and have checked all of the connections up to the clocks and I'm still getting the same odd readings.
There's no obvious corrosion on any of the connections between the sensor and the guage cluster. I'm wondering if it might be a grounding issue as I also have intermittent issues with the dashboard indicator idiot light, but they don't seem to share a ground judging by the diagram:
https://4.bp.blogspot.com/-_D3o1Sx2x1k/U0-4k7kT79I/AAAAAAAAFXc/T109odQLJuM/s1600/Rotax+123+wiring+diagram.jpg
Any thoughts/suggestions?
Edit: Actually on second look at the diagram it does look like there is a shared ground for the indicators and temp guage, the horn is a wee bit weedy too and is also on the same ground. Looks like I have a culprit. Time to find the ground point! ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| c_dug |
 c_dug Super Spammer
| jeffyjeff |
| c_dug |
 c_dug Super Spammer
| Campbell SOUP |
 Campbell SOUP Two Stroke Sniffer
| c_dug |
 c_dug Super Spammer
| jeffyjeff |
| Robby |
 Robby Dirty Old Man
| jeffyjeff |
| Robby |
 Robby Dirty Old Man
| jeffyjeff |
| Robby |
 Robby Dirty Old Man
 Posted: 10:00 - 16 Jul 2020 Post subject: |
It might, but spark plugs are stupidly high voltage and that cares a lot less about corrosion. Similar thing for ignition pickups, where the quality of the signal isn't that important. As long as a signal can get through to the CDI or ECU, they work.
A temp sensor is trying to constantly measure resistance in a circuit. If there is a load of corrosion in the circuit, then it is going to read more resistance. Add in the fact that you have corrosion, different metals, heat changes in those metals, stuff moving around (so you might sometimes get a better connection than other times) and a load of vibration and it's no surprise that readings will wander around a bit.
Also worth noting that bikes are surprisingly shit for this. Cars seem to get away with a couple of chunky earth straps that just work, and failure is usually down to the strap breaking or rusting away. Bikes have loads of little earth points all over the place, nearly always involving at least two different metals (and sometimes 5 - copper wire, aluminium eyelet, alloy engine, mild steel frame, stainless steel bolt). Galvanic corrosion is an acceptable sacrifice at the altar of lightweight, shiny parts.
Then, just for fun, the earthing points are hidden behind bodywork and the manual gives you a vague indication of where you might find one. |
The last post was made 6 years, 121 days ago. Instead of replying here, would creating a new thread be more useful? |
