Husqvarna 226HD60S - Fixed.
MilfHunter This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Easy-X
PostPosted: 16:55 - 15 May 2020    Post subject: Reply with quote
I'm assuming it's 2-stroke. What mix ratio are you running?
BTW, what's in the safe? Pr0n stash?
<addendum> is the carb a diaphragm type? They can be quite delicate, i.e. easily damaged on reassembly.
steve the grease
PostPosted: 22:57 - 21 May 2020    Post subject: Reply with quote
It sounds weak. Sometimes the fuel pickup in the tank has a lttle filter around it which can get clogged with grass/ fluff/shite. Its a spill type carb where resonance in the inlet moves a diaphragm pulling fuel round , the jets can block , but they are ever so tiny. The diaphragms can split.... does it return fuel to the tank?
I tell you what else is worth doing.... Sounds odd but listen on . With the air filter off get it going as fast as you can and then put your finger down or palm over the carb inlet cutting off the air, give it full throttle. The huge increase in vacuum sometimes pulls shite through the jets clearing them out.
jaffa90
PostPosted: 23:43 - 21 May 2020    Post subject: Reply with quote
Is the carb internal fuel filter clean?
jaffa90
PostPosted: 09:38 - 22 May 2020    Post subject: Reply with quote
All these garden machines have internal fuel filters.
https://www.ahupd.com/226HD60S-Husqvarna-Trimmer--Edger-Hedge-Trimmers-Carburetor-Parts
UPDATE, this is a similar carb kit.
https://www.ebay.co.uk/itm/Carburetor-Repair-Rebuild-KIT-For-WALBRO-K20-WYL-WYL-240-1-WYL-242-1-HOT-R2J4/383546751117?epid=2144570216&hash=item594d2af88d:g:Q6MAAOSwnvpevjqk
jaffa90
PostPosted: 09:56 - 22 May 2020    Post subject: Reply with quote
Pics of carbs. The left carb sounds like yours second pic.
recman
PostPosted: 14:16 - 22 May 2020    Post subject: Reply with quote
Inb4 snapped spark plug and welded chain.
jaffa90
PostPosted: 16:10 - 22 May 2020    Post subject: Reply with quote
kramdra
PostPosted: 13:33 - 25 May 2020    Post subject: Reply with quote
My experience with garden two strokes is that they like to vibrate all the bolts loose, last time mine failed the barrel was coming off. Strip the plastics off and check everything is tight.
jaffa90
PostPosted: 14:43 - 25 May 2020    Post subject: Reply with quote
The fuel mixture is ok (slight smoke), also you have good compression.
It needs more fuel reserve in that carb to keeps high revs.
I would check the carb internal filter and the diaphragm rubber pulse pump and the other rubber diaphragm which lifts the needle valve for flexibility. (carb kit really).
jaffa90
PostPosted: 19:57 - 25 May 2020    Post subject: Reply with quote
I find it easier to scribe a line down one side of the carb for an easier rebuild.
jaffa90
PostPosted: 10:01 - 27 May 2020    Post subject: Reply with quote
Is this yours?
https://www.ransomspares.co.uk/parts/hedge-trimmers/husqvarna/carburettor/721000.htm?gclid=EAIaIQobChMI-_uzyeHT6QIVy-vtCh0WjwAfEAQYASABEgKjR_D_BwE
Why not remove it and clean the outside then open it up, it may only need the filter cleaning and the diaphragms checking (which are common).
jaffa90
PostPosted: 11:08 - 27 May 2020    Post subject: Reply with quote
The internal fuel filter is a round very fine wire mesh 5 mm diameter.
(i use a thick needle point to flip them out)
Can you post pics of the diaphragms?
Also read my previous posts.
kramdra
PostPosted: 11:11 - 27 May 2020    Post subject: Reply with quote
Just strip it, spray it all with carb cleaner, let it soak, reassemble with cereal packet gaskets, 5 min job.
The last post was made 6 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 131.86 Kb
