Lexmoto xtrs 125 Issue
ConorDrew92
PostPosted: 13:19 - 13 May 2020    Post subject: Lexmoto xtrs 125 Issue Reply with quote
Hello guys,
Pulled my old learner bike out of storage to sell,
But it’s developed an issue I know this is chinese crap but be nice to sell it running.
I’ll attach some photos of what I’m seeing aswell, issue is when switched on it fires up but will red line the engine straight away and sit there.
I have a tube from the bottom of the tank I’m assuming this is the breather so can just dangle but I also have a tube not connected that comes out the bottom of the carb? So a little confused tubes I’m holding one is from the tank the other under the carb
Any help would be appreciated as want this sold to get some bits for the mt07
Thank you
jeffyjeff
PostPosted: 13:37 - 13 May 2020    Post subject: Reply with quote
no photos attached.
But: there is normally a tube that drains the well around the fuel fill on the tank, so that overflow is drained away from hot engine parts. Also, the carburetor float bowl may have a drain tube connected, actuated by a turning a drain screw on the side of the carb.
Easy-X
PostPosted: 15:38 - 13 May 2020    Post subject: Reply with quote
jeffyjeff wrote:
...Also, the carburetor float bowl may have a drain tube connected, actuated by a turning a drain screw on the side of the carb.
Usually doubles up as the carb bowl overflow if a bit of grit jams the float needle open.
Kit352
PostPosted: 19:02 - 25 May 2020    Post subject: Reply with quote
Does the throttle turn and return freely? It may be a stuck slide.
carofmadness
PostPosted: 22:54 - 25 May 2020    Post subject: Reply with quote
Could be stuck carb slide or stuck throttle cable, the cable may be stuck and when turning the bars it causes the throttle to be opened, check by turning the bars with the engine running.
2018 Black Royal Enfield Continental GT 535 Single Cylinder (daily) : 1985 Honda CG125 (my first bike) : 2014 AJS Daytona 125 (my mums bike)
The last post was made 6 years, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 42.88 Kb
