FZ1 Overheating
TravisBickle
PostPosted: 19:09 - 01 Jun 2020    Post subject: FZ1 Overheating Reply with quote
Hi guys hoping you can help.
Is this normal?
So my temperature gauge reads anything between 80c and 110c once warmed up. If I use the kill switch the cooling fan keeps going like a good'un. Only when I turn the ignition off it stops. 110c seems a bit high to me! Only gets that high when stationary or going very slowly, usually 80 to 90 when rolling. I've checked coolant level and it's at the top of the filler cap once cooled down a bit (but not stone cold, I think I checked it like an hour after I got home from work on it). Also might be a bit of a gurgling noise when running but might just be my imagination Brick Wall
2024 BMW M1000XR
2021 Honda CMX500 Rebel S
2016 Triumph Tiger 1050 Sport
xX-Alex-Xx
PostPosted: 19:36 - 01 Jun 2020    Post subject: Reply with quote
Yeah that’s normal if you’re stopped in traffic or going slow. You’ll see a warning light usually around the 120 mark.
DILLIGAF
TravisBickle
PostPosted: 19:39 - 01 Jun 2020    Post subject: Reply with quote
Thanks. Stupid question but that's put my mind at rest Very Happy
Just I'm used to seeing my car temp gauge never budging off 90c I suppose bikes are different, I wouldn't know because this is the first bike I've ever had with a temperature gauge.
Also alarming cos my boot melted all over the exhaust. Like not just a bit, made a proper semi circle dent in the heel of my boot about an inch deep and black gunge all over the pipe just in front of the end can. Never done that before, maybe got a smidge of black stuff on the exhaust before but never melted all the way through like that before, so wondered if it was running hotter than usual...
2024 BMW M1000XR
xX-Alex-Xx
PostPosted: 19:44 - 01 Jun 2020    Post subject: Reply with quote
Just bear in mind a bike has a radiator about the size of a gnats bollock compared to a car, and car manufacturers tend to have the needle sitting in the middle of the gauge unless there’s a problem.
I’d be more worried about where you’re keeping your foot instead of how how the exhaust gets Very Happy
DILLIGAF
FretGrinder
PostPosted: 22:08 - 01 Jun 2020    Post subject: Reply with quote
Yep my fazer 800 used to sit in this range as does my MT-09, so it's all good.
Yamaha MT-09
ಠ_ಠ
TravisBickle
PostPosted: 22:21 - 01 Jun 2020    Post subject: Reply with quote
Thank you sirs Thumbs Up Praying Dance! Clapping Bounce!
2024 BMW M1000XR
Fizzer Thou
PostPosted: 22:34 - 01 Jun 2020    Post subject: Reply with quote
My 5JJ-R1 has a digital temperature display and the fan cuts in at 105c and switches off at around 80c if I kill the engine but keep the ignition switched on.
Might I ask what ratio of coolant you use?If you are using a standard mix of 50/50 then it is not going to work effeciently as (A) anti-freeze/glycol is not very good at heat exchange and (B) this country is never going to go down to -30c,even in the worst case scenario.If you were to use 100% ultra pure water then it would be better as anti-freeze/glycol is not very good at moving heat away from hot spots like around the cylinder head and the upper part of the barrel where combustion occurs.But then you need the anti-corrosion inhibitors found in glycol.
Since I first owned a water cooled bike I have used 70% distilled water,25% high quality concentrated anti-freeze/glycol and 5% WaterWetter.Even in the streets of Monte Carlo then the R1 was able to run okay in the 38c heat...unlike me.I sweated buckets Thumbs Down Shocked Thumbs Down
Always have a 'Plan B'
TravisBickle
PostPosted: 22:38 - 01 Jun 2020    Post subject: Reply with quote
To be honest I haven't had the bike that long so haven't got round to / felt necessary to replace the coolant that's already in the system, although I did get my motorbike mechanic to give it a thorough going over after purchase as I'm a bit mechanically-able to by no means an expert! Probably wouldn't hurt to flush the system and replace.
What's water wetter?
2024 BMW M1000XR
Fizzer Thou
PostPosted: 22:45 - 01 Jun 2020    Post subject: Reply with quote
https://www.redlineoil.com/waterwetter-coolant-additives
I use it in the KTM enduro,the R1 and the Exup-R.
The last time I bought some I got it from Demon-Tweeks Thumbs Up Wink
jaffa90
PostPosted: 23:21 - 01 Jun 2020    Post subject: Reply with quote
A spanner in the works,
Q, You think it is over heating so how accurate is a temp gauge??
TravisBickle
PostPosted: 23:40 - 01 Jun 2020    Post subject: Reply with quote
It's a crude yardstick, but a yardstick nonetheless :-/
2024 BMW M1000XR
jeffyjeff
PostPosted: 08:12 - 02 Jun 2020    Post subject: Reply with quote
+1 with FretGrinder and xX-Alex-Xx Your temperature range coincides with my experience on the fifth-gen VFR's. The fan switch engaged the radiator fan at 223F. I routinely saw, on hot days in traffic, temps up to 230-233F. As I recall, the ECM would not intervene until the temp reached 250F. Never got that high.
One fact most people don't consider: Once the thermostat is fully open (approx. 195F) it can no longer regulate the temperature of the engine. At that point (wide open 'stat) the engine temperature will increase, degree-for-degree with the ambient air temperature. Ie. if your thermostat is maxed out at 210F on a 100F day, and ambient increases to 105F>the engine temp will climb to 215F. Get it? At that point, the only way to cool down the engine is to 1) increase airflow through the radiator, or 2) lower the temperature of the airflow through the radiator.
That's why seemingly minor cooling system faults have such a big effect; debris blocking the radiator fins, bent radiator fins, wonky thermostat, cooling system fan issues or modifications. Also, the pressure cap is critical. The boiling point of coolant raises 3 degrees F for every 1 psi in cooling system pressure. A 15 psi pressure cap raises the boiling point by 45 degrees from 212 to 257F. More is not better, though. I once had an old Rambler (American Motors automobile) with a 9 PSI pressure cap. I fit a 15 PSI cap, only to suffer repeated radiator leaks. Took me a few years to realize that I had caused my own problem.
TravisBickle
PostPosted: 08:44 - 02 Jun 2020    Post subject: Reply with quote
https://i.ibb.co/KwSxYWf/20200602-092801.jpg
https://i.ibb.co/YBsZD5Y/20200602-092752.jpg
Any idea how to get the gunge off the exhaust pipe???
2024 BMW M1000XR
pepperami
PostPosted: 09:08 - 02 Jun 2020    Post subject: Reply with quote
Cold exhaust pipe, petrol, rag, and plenty of elbow grease.
Fine wire wool is good also.
jeffyjeff
PostPosted: 12:23 - 02 Jun 2020    Post subject: Reply with quote
pepperami wrote:
Cold exhaust pipe, petrol, rag, and plenty of elbow grease. Fine wire wool is good also.
The wire wool will leave micro scratches where it is applied. Still looks better than the remnants of your boot. You can use wet/dry sandpaper to polish out the scratches. Start with 600 grit, and work gradually up to 1500. Finish up with some automotive paint rubbing compound for a shine that will rival OE.
blurredman
PostPosted: 13:00 - 02 Jun 2020    Post subject: Reply with quote
Ah yes, the boot on the exhaust problem.. Mainly when women pillion riders get off the bike then almost break their ankle as the wedge is no longer there. I've still got a pair on my exhausts..
Never bothered to clean them off to be honest.. Cool
TravisBickle
PostPosted: 15:43 - 02 Jun 2020    Post subject: Reply with quote
That's a fair point, the bike is producing 150hp which is more than most cars and like you say the rad is probably less than half the size?
Where I'm placing my right foot is a problem at the moment. Only because I dropped the bike the other day and bent the foot brake lever up so now I'm paranoid about dragging the rear brake constantly as it's sitting higher up than before, so I know it's a bad habit but instead of having the arch of my foot on the peg I've been having it set a bit further back with the ball of my foot on the peg and only bringing my whole foot forward when I need to use the brake.
A bit embarrassing really. First time ever dropping a bike. I knew it would happen, it happens to us all eventually just a question of when and how. Was trying to do a U-turn on a hill/camber, just didn't give it enough momentum and before I knew it too much weight was on one side and I had passed the point of being able to save it. Was like slow motion I could see it happening but there was nothing I could do about it other than try to minimise the damage. I laid it down so gentle it was like I was laying a new born baby in its cot LOL. Fortunately was doing 0mph when it went down and it had all of my strength making sure it went down as gently as possible, and also fortunately it's got crash protectors so all the weight was on that so apart from the slightly bent foot brake lever I actually got away with no other damage to the bike at all, not even a scuff on the crash bung itself! Phew but heart was in my mouth at the time Embarassed
That reminds me, I most go out and bend that back into place now... keep forgetting!
2024 BMW M1000XR
PostPosted: 16:49 - 02 Jun 2020    Post subject: Reply with quote
Don't worry about dropping it. I've thrown some of mine sideways like surfboards.
I have a similar looking exhaust, link pipe + converse = hot mess. Laughing Its coming up nicely with some harpic.
TravisBickle
PostPosted: 16:55 - 02 Jun 2020    Post subject: Reply with quote
Yay I just earned my first gold karma blob.
A bit like Morgan Freeman earning his freckles for his good deeds.
https://i.gifer.com/viq.gif
2024 BMW M1000XR
jeffyjeff
PostPosted: 10:22 - 07 Jun 2020    Post subject: Reply with quote
Dude! Belated congratulations on your first gold karma blob. Here's to many more!
Andy_Pagin
PostPosted: 17:55 - 08 Jun 2020    Post subject: Reply with quote
My FZ1 runs at about 100 degrees around town, so OPs seems normal. I always make sure I have a spare fuse for the cooling fans, the bike definitely needs both of them spinning to avoid overheating in urban traffic.
The last post was made 6 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 113.65 Kb
