R&G Fender Extender
ThunderGuts
PostPosted: 10:52 - 05 Jun 2020    Post subject: R&G Fender Extender Reply with quote
So decided to fit a fender extender; got the R&G one and looking at the install, it uses a thin strip of adhesive tape and four little plastic pop rivets. I get the impression from the instructions the adhesive tape is only a temporary element while fitting the rivets and it's the latter that actually give the strength, but they look a bit puny? Is this adequate, or have others come up with other ways to secure theirs?
Cheers Thumbs Up
TG.
NJD
PostPosted: 11:29 - 05 Jun 2020    Post subject: Reply with quote
Replace with small bolt and nut (flanged, or nut and washer depending what works etc) if problems occur.
Never had one flap about (not R&G, but in general) on the bikes I've had with them installed.
jeffyjeff
PostPosted: 14:11 - 05 Jun 2020    Post subject: Re: R&G Fender Extender Reply with quote
ThunderGuts wrote:
So decided to fit the R&G one and looking at the install, it uses a thin strip of adhesive tape and four little plastic pop rivets.... but they look a bit puny? Is this adequate, or have others come up with other ways to secure theirs? Cheers Thumbs Up
I agree that the double sided adhesive tape and plastic rivets look inadequate. I have ditched the tape on several fender extenders, and tried two adhesives successfully.
On my BMW, I sanded down the inside of the fender and the matching part of the fender extender. I drilled and fit the plastic rivets to align the extender, then used ABS cement to glue it on. A C-clamp helps clamp the pieces together while the cement sets up.
On my YBR, I did not have ABS cement available, so I used Shoe-Goo, a shoe repair adhesive.
These methods will not work if you think you will ever want to take the fender extender off, but they work well if you don't want it to come off unintentionally. Wink
History shows again and again how nature points out the folly of men. BOC
Getting old ain't for wimps. R.S. Hain
ThunderGuts
PostPosted: 14:41 - 05 Jun 2020    Post subject: Reply with quote
Cheers all. Thumbs Up I have some small stainless dome-head allen bolts which could prove to be an inconspicuous solution. Glad I'm not the only one who thinks 3 or 4 little plastic pop-rivets seems insufficient given not just the force of the air, but going through puddles and all that water pounding against it.
TG.
jaffa90
PostPosted: 15:17 - 05 Jun 2020    Post subject: Reply with quote
Brings back memories, mostly used Pyramid fender extenders, removed that spongy sticky sided stuff and drilled 4 small holes through all for the self tapping screws provided.
Then drilled slightly larger holes in the fender/mudguard only so that the self tapping screws bite the extender fender with a thin layer of sealant inbetween.
Finish off with touch up nail varnish on the screw heads the same colour as the fender/mudguard.
Nuts & bolts is a no no on concaved surfaces.
The last post was made 6 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 45.13 Kb
