Kawasaki ER5 1999 running issues
Malvern
PostPosted: 19:17 - 14 Jun 2020    Post subject: Kawasaki ER5 1999 running issues Reply with quote
I bought an ER5 (1999) which had been someone’s project and I’ve been trying to fix its issues! I’ve got to the point where all the electrical gremlins and general maintenance issues are resolved but have an issue when running:
The bike starts and revs absolutely fine, when riding it bogs at about 3500rpm in all gears. The bike has an aftermarket exhaust and filters fitted and I’m not sure if the carbs have been adjusted to suit. Does anyone know a good method to check if this is the issue and whether the mixture screws need messing with of new main jets? Or have a suggestion what else it could be? The carbs themselves are very clean and functioning well.
jeffyjeff
PostPosted: 22:23 - 14 Jun 2020    Post subject: Re: Kawasaki ER5 1999 running issues Reply with quote
Malvern wrote:
...when riding it bogs at about 3500rpm in all gears. The bike has an aftermarket exhaust and filters fitted and I’m not sure if the carbs have been adjusted to suit.
Greetings, Malvern: Does that above statement mean that it has a flat spot at 3500rpm (and is able to accelerate higher than that)?
If not, do you mean that it will start and run but only up to about 3500rpm? It would be very odd that the motor would not accelerate beyond 3500 regardless of gear selection.
In either case, I would start by making sure that fuel flow to the carburetors is not obstructed. Then disassemble the carburetors and check the float bowls for debris/water, correct float height, and diaphragm condition. On assembly, make sure the carburetors are synched properly.
Beyond that, you'll need to clarify what you mean by "bogs at about 3500rpm." In a worst case scenario, your problem could be caused by something other than a simple carburetor adjustment.
Robby
Dirty Old Man
PostPosted: 22:35 - 14 Jun 2020    Post subject: Reply with quote
Aftermarket air filters - is that a K&N filter in the original airbox, or is it running pod filters?
If you're running pod filters, get an airbox. That particular engine in its various incarnations is known to rely heavily on the airbox to run right.
The for carb setup, start off with the factory settings from the manual for both jet sizes, float height, needle position and mixture screw.
Then you have a baseline to work from. I would generally open the mixture screw out another half turn on a bike of that vintage when it was fashionable to have a lean idle, but after 20-30 years of wear it just produces a weak, stumbling idle. Then if it is still cocking around at 3500rpm I would raise the needles one notch.
Main jet only becomes a limiting factor at close to full engine power. For everyday riding you tune on the needle.
Malvern
PostPosted: 23:52 - 15 Jun 2020    Post subject: Reply with quote
Thanks for the replies guys.
It doesn’t go above 3500-4000 rpm in all gears, absolutely fine up to that point. When it’s on the stand it’ll Rev up to screaming no problem, it’s just when I’m actually on it and riding.
It’s aftermarket pods that are on it along with an aftermarket exhaust. There have been some mods done to the bike which will mean refitting an air box is not possible since there’s no room for it any more.
I stripped and cleaned the carbs, there were no obvious issues.
I’ll have a (logical) play with the air/fuel screw. The issue being that there is only an issue when riding and not on the stand do adjustment and testing is going to be slow! I also don’t have the special tool for reaching the screws so I’ll have to figure something out!
jeffyjeff
PostPosted: 06:54 - 16 Jun 2020    Post subject: Reply with quote
Check the fuel supply to the carburetors. Make sure that the petcock flows fuel freely and that there are no restrictions, debris, fuel filter issues, etc restricting fuel flow.
Does that bike have a vacuum operated fuel tap on it? If so, a vacuum leak could be causing the tap to partially restrict fuel flow (in addition to the suggestions listed above).
PostPosted: 07:57 - 16 Jun 2020    Post subject: Reply with quote
It needs an airbox. No danger it'll run properly without one and that huge flatspot is exactly what you get on those with no airbox.
If you thrash the living tits off it you can probably get it onto the main jet (about 7-8,000 rpm) and it'll pull through the flatspot but then you're stuck riding it at wide open throttle everywhere making it unrideable.
There are a couple of accessory jets that take care of fuelling at the rev range in question (brass jets facing backwards towards the air filter round the edge of the carb choke). make sure these are clear by blowing through them with compressed air/carb cleaner spray.
Cheap, easy fix. £14.. There are cheaper but this one has the rubbers/intake trumpets and clamps on too.
https://www.ebay.co.uk/itm/Kawasaki-ER5-ER-5-OE-Air-box/363016352548?hash=item548575f324:g:XLAAAOSwbw1Z-JCR
Get a new air filter at the same time.
Robby
Dirty Old Man
PostPosted: 19:11 - 16 Jun 2020    Post subject: Reply with quote
Also worth mentioning that the mixture screw only affects the mixture at idle and very low engine power. Your problem will not get fixed with the mixture screw. You'll be removing the carbs a lot to fiddle with them.
Malvern
PostPosted: 14:10 - 21 Jun 2020    Post subject: Reply with quote
Thanks guys, I’ve fitted an air box back in and it now runs fine....next issue is the coolant reservoir, which the previous owner re-sited since they removed the air box and modified the tail. I now can’t find a home for it!
Malvern
PostPosted: 14:12 - 21 Jun 2020    Post subject: Reply with quote
This is where it was!
The last post was made 6 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 61.3 Kb
