| c_dug |
 c_dug Super Spammer
 Posted: 20:31 - 15 Jun 2020 Post subject: BMW R1200GS. Piston met valves - new piston needed? |
Boy am I having a bad week! I was literally waiting for the next sunny day to get some nice pictures and list the bike on eBay, but apparently life has a different plan.
Last Monday on what was likely to be my final outing on the GS it fired it's spark plug like a bloody cannon, fortunately it missed the nearby cars and pedestrians. A quick inspection showed the threads had shot out all the way down to the base, I'm guessing there was some damager there, could have caused it myself I suppose, who knows.
Anyway, recovered to my sister's place nearby where they fortunately have a well equipped garage. Tuesday I took the head off and dropped it to a nearby well-regarded workshop to have an insert fitted.
Today I picked it up again and refitted. Clearly made a giant cock of things because very long story short I've managed to break two exhaust valves on the side I was working on. Not entirely sure how this hapoened as I am certain I followed the book to the letter, but obviously I dun-goofed somewhere along the way. Very angry at myself, no need to rub it in (please!).
Tempted as I am to never touch a set of spanners again as it now seems I've fucked both the spark plug thread and the valves, I do need to reverse this mess and can't afford the workshop bill to pay somebody to do it for me, so I'll be fixing it myself one way or another.
Question is, how much do I need to replace?
Cylinder head is a write off for certain, the broken valve stem stabbed a nice hole right beside the valve seat.
The piston has some very minor dents in the centre which I'd imagine would be fine, but there is a slightly deeper dent near the edge which I'm less sure about, I'd like opinions please.
The bike neve fully fired up, it turned over once before stalling. Do I need to worry about crank bearings?
I checked the cylinder bore and that at least looks fine, so no worries there.
Anything else I should be checking?
I still plan on selling the bike so I'd like to repair it as cheaply as possible whilst still doing everything that needs doing, I wouldn't want a dodgy repair job playing on my conscience.
Pictures to follow very shortly, just uploading to Imgur. ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| c_dug |
 c_dug Super Spammer
 Posted: 20:38 - 15 Jun 2020 Post subject: |
Hopefully this works!
First picture shows the cam sprocket slipped around the camshaft, you can see the locating key and keyway on the camshaft are 20-30° apart. I'm certain they were aligned when I put the cam sprocket on so not sure how this occurred.
https://i.imgur.com/uR1wjeG.jpg
Next picture shows the piston damage, I'm not sure it's shown well in the photograph but at the lower edge in the picture you can see the deepest ding.
https://i.imgur.com/fuRqv8i.jpg
Last picture shows the head.
https://i.imgur.com/tVJeut3.jpg ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| Riejufixing |
| Riejufixing |
 Posted: 20:48 - 15 Jun 2020 Post subject: |
| c_dug wrote: | Hopefully this works!
https://i.imgur.com/tVJeut3.jpg |
Can you get a better pic of the inside of the combustion chamber, plenty of light but not "over exposed"? Piston too.
I'd check that the top land (between the piston crown and the first piston ring) has not been pushed down to pinch the top ring. If it has you can fix that with care. Also don't write off anything yet. Have a look at the bottom end of the valve guides to see they're OK. No nasty bore marks I take it.
Edit: If you did put the key in the sprocket you'll find it's sheared, which it is likely supposed to. |
| c_dug |
 c_dug Super Spammer
| Robby |
 Robby Dirty Old Man
 Posted: 23:21 - 15 Jun 2020 Post subject: |
Might want to check the width of the ring lands with some feeler guages to make sure it hasn't collapsed them.
Head is probably salvageable. May be cheaper to just replace with a used one though and definitely easier.. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Riejufixing |
 Posted: 05:08 - 16 Jun 2020 Post subject: |
Nowt wrong with the piston. Main that can hold up to the huge pre-ignition forces you can get on these will be fine too.
If it was my cylinder head I would weld it up, or at least attempt to.
Otherwise, call Motorworks or James Sherlock. My choice (by experience) would be Motorworks as unlike Sherlock they have always given me 100% competent and satisfactory service.
Bloody shame that the 2 engines on ebay both are damaged RHS  ____________________ a.k.a 'Geri'
| c_dug |
 c_dug Super Spammer
| buddy |
 buddy Trackday Trickster
| c_dug |
 c_dug Super Spammer
 Posted: 22:01 - 19 Jun 2020 Post subject: |
Collecting this tomorrow, thanks for finding it  ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| Polarbear |
 Polarbear Super Spammer
| c_dug |
 c_dug Super Spammer
| A100man |
 A100man World Chat Champion
 Posted: 22:38 - 20 Jun 2020 Post subject: |
| Polarbear wrote: | One of my friends BMW did exactly the same, valves hit piston, and I've heard of others doing it as well. Is there a flaw in the engine they don't want to admit to?
VW Golf syndrome.
'It's a German made Golf so it can't go wrong or be of poor design'.
Gotta hand it to Fritz and pals for their brainwash marketing over the past 40 years. Fairly ordinary cars being passed off as the doyenne of motoring - they even got away with that emissions scam with reputation in tact. For years the press has vaunted the Ford Focus as a better car than the Golf but...'
So perhaps the same applies to the GS..
Just saying'.
PS I blame Paula Hamilton ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Polarbear |
| MCN |
 MCN Super Spammer
| c_dug |
 c_dug Super Spammer
 Posted: 09:42 - 26 Jun 2020 Post subject: |
Well, it was a loooong day yesterday, but in the end I rode my own bike home 40 odd miles on the motorway and a few miles of country lanes, and it worked flawlessly, actually felt the best it has in a while.
Once I removed the old cam gear the damage was obvious when compared with the replacement.
https://i.imgur.com/Y6DchoF.jpg
I'm still not entirely sure how this happened but my best guess is I hadn't located the key properly into the keyway on the camshaft before torquing it down.
I gave the piston a real good clean up too and the damage at the outside was much less severe than I thought:
https://i.imgur.com/PEyFpr9.jpg
It catches the light in pictures but in reality it's probably .5mm deep at the very most and also a mm or two further in from the edge than I thought which made me much less worried about the rings.
I carefully scraped the burr off of the top then turned the engine over a few times by hand and inspected the cylinder wall. No sign at all of anything untoward going on below the crown of the piston so have gambled on it being fine rather than removing the cylinder and measuring it all up - perhaps I'll regret that, but it was the difference between riding home yesterday or leaving it at my sister's for a about three more weeks.
Home sweet home:
https://i.imgur.com/d6geFww.jpg
Plan now is to do an oil change, run it for a few weeks to make sure it's all hunky dory, then crack on with changing it for something a bit sportier. Borrowed my dad's K1300GT whilst the GS was off the road, and I think it's swung the decision in favour of a VFR1200 rather than K1300S. ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| c_dug |
 c_dug Super Spammer
| Riejufixing |
| Polarbear |
 Posted: 12:46 - 26 Jun 2020 Post subject: |
Nicely sorted.  ____________________ Victory Cross Country American tractor. |
| c_dug |
 c_dug Super Spammer
| Robby |
 Robby Dirty Old Man
| Riejufixing |
The last post was made 6 years, 138 days ago. Instead of replying here, would creating a new thread be more useful? |
