Socket spanner set choose help needed
SC9
PostPosted: 15:47 - 16 Jun 2020    Post subject: Socket spanner set choose help needed Reply with quote
Heya,
I want to buy a socket spanner set for minor car fixes and I was wondering if you can help me with a quick advice. I am not looking for something fancy and expensive, since I have no idea if I will ever use it or what for.
What should I choose between this
£20 72 pieces set from B&Q
https://www.diy.com/departments/72-piece-standard-socket-set/1785068_BQ.prd
and this £35 74 pieces from Lidl
https://lh3.googleusercontent.com/proxy/fMW543yLIyJHdJr9Hbnw8-7OzilIo0plXArJftAuUXeROEi4XG1qzHrchTGJWOMwKT0iJBBoV3Sv5MmeLHSCeO9GGuSCkvLfID9X4OHKPN2LWcL_cCB_R5e4HibjQ1t7JhLO93E
Should I go for the lowest price or Power Fix would be a little bit better than the other unknown one?
Thank you
Riejufixing
PostPosted: 16:12 - 16 Jun 2020    Post subject: Re: Socket spanner set choose help needed Reply with quote
SC9 wrote:
Why isn't there a proper link to the Lidl product?
WD Forte
PostPosted: 16:27 - 16 Jun 2020    Post subject: Reply with quote
The £20 B&Q set looks fine for a starter set.
I see it has 6 sided sockets which is all I use nowdays
as they are less prone to round off rusty old nuts and bolt heads
There will only be a few that you'll need to use regularly
say 8,10,12,14,17,19mm mainly
maybe other sizes at times.
£20 isnt a lot of dosh and you'll probably add and upgrade tools later on
as we all do
I'm still using a set of hex sockets I bought from B&Q years ago
and they've served me well, but keep the receipt just in case.
bikers smell of wee
Bhud
PostPosted: 17:41 - 16 Jun 2020    Post subject: Reply with quote
I've got a few B&Q ones, and they do at least 3 levels of quality in sockets, so you can't tell much from that link. All I can say is, the ones I bought individually from off the shelf at B&Q are a lot beefier than the ones shown in that boxed set.
The way I would do it is, forget these sets. Spend about £20-£30 on a set of branded metric 1/4-inch sockets where the only other thing in the packet is a wall-mounting rack. Then get a ratchet separately, perhaps an extender separately, and a couple of socket size adaptors to give you a bit of flexibility in the future. At some point you may need thinner walled sockets, or you might break one from using it as a bearing drift or something. But if you do it this way around and try to go for quality sockets rather than a one-size-fits-all toolkit with lots of unneeded items, you're more likely to end up with a decent sockets that will last a lifetime. £20-£30 is OK for a reasonable home DIYer set of sockets, I think. But, personally, I would doubt you would get good sockets among 72/74 trinkets in a box, for that money.
Riejufixing
PostPosted: 18:08 - 16 Jun 2020    Post subject: Reply with quote
I do sort of agree with that, because the OP doesn't know what he wants to do on his car. What can you do in the way of "minor car fixes" that you need sockets for? Change the disc pads? A 1/2" drive socket. Change the exhaust? 3/8 will be fine, he might get something 1/4" isn't up to. What else. Battery? Removing ancilliary components? Any old thing. Auxiliary belts? Take the seats out? Arse about with the handbrake? Change a wheel, use what's provided. Change the steering rack? Change the oil & filter...?
Bhud
PostPosted: 18:11 - 16 Jun 2020    Post subject: Reply with quote
D'oh!
I wrote 1/4-inch but meant 1/2-inch
Kawasaki Jimbo
PostPosted: 19:05 - 16 Jun 2020    Post subject: Reply with quote
as they are less prone to round off rusty old nuts and bolt heads.
Also I wish I hadn't bought so many 12-point spanners and sockets, mostly bought in sets so I have sizes I've rarely used. Good for limited access apparently, but I'm slowly buying 6-points and wondering whether to have an eBay clearout of the rest.
pepperami
PostPosted: 19:24 - 16 Jun 2020    Post subject: Reply with quote
Another vote for 6 sided sockets.
I picked up a handful at car-boot sales, not expensive Thumbs Up .
Now I buy them in ones & twos when I can,
I find then better than the multi sided sockets.
Kentol750
PostPosted: 20:00 - 16 Jun 2020    Post subject: Reply with quote
Halfords have been good to me for over 20 years, look for sales and then online discount too, got an extra 15% off by ordering online and waiting 4 days.
Some bikes.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:18 - 16 Jun 2020    Post subject: Reply with quote
I bought a set of 6 sided impact 1/2 drive sockets for £45 quid in the summer. I'm expecting them to last my lifetime (unless I lend them to ste after he managed tto snap my 8mm hex tang bit....). Lifetime guarentee
https://www.halfords.com/tools/hand-tools/tool-kits/halfords-advanced-modular-tray-set---18pc-impact-socket-set-439227.html
I also bought a cheap set of sockets from halfords (1/4 and 3/8) about 18 years ago. I still have them all including the 3/8 to 1/4 adaptor. Im on about my 6th 3/8 wrench (I always have 3) simply because they've worn out from use and the rachet bit had died. The last one I bought was an expemsive one rather than the cheap ones that I've picked up prior to that.
Triumph Sprint ST 1050
ThunderGuts
PostPosted: 08:45 - 17 Jun 2020    Post subject: Reply with quote
Another vote for 6 sided sockets. Although I've graduated to more substantial tools these days, when I started out messing around on cars as a teenager I managed to get apart a surprising amount of stuff with a cheap 1/4" drive set (which came with a 1/4"-3/8" adaptor so I could use bigger sockets!) and it never broke, even when I used a bar on the end to loosen a particularly tight sump plug. It's amazing what you can get away with (sometimes!). I actually still have it and it lives in my beer festival toolkit.
As a general note though; I'd say that if the OP envisages any kind of repeat use (remember that socket sets can find a use on all sorts of things like lawnmowers, garden furniture, gates, garage doors, loft ladders etc.), it's worth getting something semi-decent. I use this, hardly expensive, but it works very well and seems decent enough for casual use;
https://www.toolstation.com/draper-12-inch-socket-set/p54253
TG.
Hetzer
PostPosted: 09:17 - 17 Jun 2020    Post subject: Reply with quote
What a perfect opportunity to pass comment on the continuing cheapening and shoddification of all things but in this case, automative tools. Has anyone been to halfrauds lately? Specifically the gloriously sophisticated-looking brushed metal and shiny tempered glass cabinets in which used to reside actual high-quality sockets and ratchets? "Professional" they called them. You could tell they were the real McCoy because the insides of the sockets had splines like the teeth in a shark's mouth. Thousands of them! Such that if you needed to adjust the position of the socket on a nut you had to do nothing but merely THINK and you got a fraction of an inch of new angle on the fucker you were trying to loosen. Now? Six sides. If you need to adjust the position you need a telegraph and a fucking tug-boat.
I don't understand why. Is it so much more expensive to cast a piece with multiple splines? Now the so-called "professional" range looks like the standard shite you get from the chinese aisle at Toys R Us.
Jewlio Rides Again LLB
PostPosted: 12:40 - 17 Jun 2020    Post subject: Reply with quote
Or you can buy both?
Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems
PostPosted: 13:32 - 17 Jun 2020    Post subject: Reply with quote
Yes, they do more than one range. Our local one certainly still sells professional along side cheapish tat.
Also, I don 't have a problem with 12 sided sockets. Yes, 6 sided are useful when the nut has rusted to hell but I reckon most problems with 12 sided are people using a 'close' size rather than the proper one or that cheap sets have crap tolerances. I have an ancient Halfords professional 12 sided set that is still good.
I do have a six sided 3/4" drive set and impact sockets if I need smaller sizes and brute force is the order of the day.
WD Forte
PostPosted: 14:04 - 17 Jun 2020    Post subject: Reply with quote
How come all impact sockets are 6 sided?
I dont recall ever seeing a 12 spline impact socket and
since I only use 6 sided sockets now I haven't struggled with a rounded off a worn or rusty nut
or bolt head for a long time.
Once the socket is on the nut/bolt, the adjustment angle depends on the amount of teeth
and quality of the rachet not the socket.
Offering up a hex socket to a nut means you may have to turn it a max of 60 degrees as opposed to 30 degrees
on a 12 but this is hardly a chore and has never had me wanting a 12.
Spanners now that's different.
Trying to shift nuts/bolts in a restricted space with hex type spanners could be an arseache
so good quality 12 spline spanners win here.
OP mentions car work.
Many cars now use hex cap head bolts, M&F Torx type bolts n shit so sets of these are
often needed as well as sockets to do a lot of work.
bikers smell of wee
ThunderGuts
PostPosted: 14:35 - 17 Jun 2020    Post subject: Reply with quote
I think the forces exerted are somewhat different; impact tools will repeatedly tighten/loosen their grip on the nut/bolt on each impact cycle, whereas with handtools it tightens slowly and progressively. I imagine with impact tools it's more to do with the cumulative forces on a relatively small area of metal on a 12 spline vs a hex.
That said, my experience is it's the nut/bolt that's the problem usually - I don't think any of my sockets have rounded off/deformed to the point they don't grip well anymore.
TG.
Freddyfruitba...
PostPosted: 14:50 - 17 Jun 2020    Post subject: Reply with quote
My Halfords set must be about vintage 1978, and is still in great condition, which is more than can be said for the plastic moulded insert which all the sockets and tools fitted into - the plastic degraded years ago so everything just rattles around in the metal case. I can't come up with any realistic way to solve it, but it annoys me so much that I'm almost tempted to bin it and buy a whole new socket set...
BTTD
PostPosted: 15:47 - 17 Jun 2020    Post subject: Reply with quote
Worth taking a look at machine mart if you want to build a tool set out out of small kits, but you'll end up spending more.
https://www.machinemart.co.uk/c/hand-tools/
I have a set of powefix spanners and allen keys in the house toolkit which appear to be decent enough. They don't have the finish of Draper or Halfords professional range tools, but I've given them some abuse and they aren't made of cheese. I would buy again.
PostPosted: 16:04 - 17 Jun 2020    Post subject: Reply with quote
I have a similar problem in that my socket set came in a big moulded plastic case and the clasps have long since broken off. It has a ratchet strap round it to keep it shut now.
Total overkill but there is nothing worse than sorting out a large box of metric, imperial, torx, star and spline sockets when they deposit themselves over the workshop floor. Evil or Very Mad
NJD
PostPosted: 16:58 - 17 Jun 2020    Post subject: Re: Socket spanner set choose help needed Reply with quote
Riejufixing wrote:
Agree.
First post and suspicious blocked link, hmm. Tut Tut
May be wrong, and will chip in if proven otherwise.
Hetzer
PostPosted: 17:20 - 17 Jun 2020    Post subject: Reply with quote
I've long had a full set of the good ones. I don't think they're available any longer anyway, there are none in the fancy cabinets.
yen_powell
PostPosted: 21:27 - 17 Jun 2020    Post subject: Reply with quote
I have just put Sealey layered foam in a lot of my tool box drawers, cut around the sockets etc so they sit snug in it. Nothing moves now when the drawers get slammed or the box gets moved about on a lumpy floor.
XT1200Z and a DR350 in bits
Freddyfruitba...
PostPosted: 11:27 - 18 Jun 2020    Post subject: Reply with quote
Brilliant! Just googled that - I had no idea; thanks a lot. Going shopping...
yen_powell
PostPosted: 11:42 - 18 Jun 2020    Post subject: Reply with quote
It's not cheap for the amount you get but you can't beat it for knowing something hasn't been put back, a point I noted after one of my sockets did a runner and made me upset every time I opened the drawer. Found it in the end though. I tried a normal foam the first go, but the layered stuff is definitely easier.
https://images.versys1000.com/P1270673.jpg
https://images.versys1000.com/P1270671.jpg
https://images.versys1000.com/P1270665.jpg
The spanners one is temporary with a bit of left over foam I had lying about, trying it out to see if I like it or not before doing the whole drawer.
steve the grease
PostPosted: 14:36 - 18 Jun 2020    Post subject: Reply with quote
Please please look at 3/8 and 1/4 drive sets. 1/2"drive is miles too big and clumsy and over the top for bikes for anything less than 17 or19mm. I use my 1/4 drive set on anything 6-13 and the 3/8 set for 8-17mm over 17 I use my 1/2" drive set. Have you ever used/ seen an 8mm 1/2" drive socket , ridiculous overkill with too large a head to go on lots of fittings.
Oh and 6 point please. 12 point sockets are cheaper to make* and were neccessary before ratchets became common ( like in the war) , but 6 point sockets fit the nuts so much better.
Just noticed this is for CAR work not bikes , so only partially applies. Some smaller fittings on cars can be very tight, so 1/2" for over 14mm maybe.
* Because less material is deformed to forge the socket fron the blank
The last post was made 6 years, 94 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 138.09 Kb
