| goto10 |
 goto10 World Chat Champion
 Posted: 18:53 - 20 Mar 2018 Post subject: Anyone know about small [split] aircon units? |
I'm looking for a small pre-gassed split system (outside/inside units) for DIY install (with help from an electrician) - I saw this:
https://www.appliancesdirect.co.uk/p/eiq-9wminvqc/electriq-eiq9wminvqc-air-conditioner
The outside unit will be within a couple of metres of the inside unit - it's pre-gassed so I'm guessing I need to lose the extra hose in the wall.
It looks cheap & cheerful - avoid or ok? - any other recommendations? ____________________ '12 NC700S & '12 CB600F Hornet [Stolen by some dickless twat] Suzuki GT500 shed |
| uberkron |
 uberkron Crazy Courier
| G |
 G The Voice of Reason
| MCN |
 MCN Super Spammer
 Posted: 06:07 - 24 Mar 2018 Post subject: |
I just took delivery of one of these beasts.
https://uk.trotec.com/products/machinery-homecomfort/air-conditioning/comfort-air-conditioners-of-the-pac-series/pac3500e/
£307 (+ additional £15 for the window kit)
I researched a bit before buying.
I also considered a split unit but I think for our temporary 'summer' a split unit was possibly a bit ghey.
This unit is relatively quiet (most noise when compressor is running/ cooling). It cools my room relatively quickly 1°C drop in about ten mins.
The window vent is a bit phaph but manageable.
Split units are really quiet as the noise maker is banished to the outside.
They have no/much less phapery with vents etc.
And they take up less space.
But most require professional/trades to fit.
Mainly due to the gassing part.
Possible Part (something) electrical code regulations too. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Rockhopper |
 Rockhopper Trackday Trickster
| G |
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 20:59 - 25 Mar 2018 Post subject: Re: Anyone know about small [split] aircon units? |
| goto10 wrote: | I'm looking for a small pre-gassed split system (outside/inside units) for DIY install (with help from an electrician) - I saw this:
It looks cheap & cheerful - avoid or ok? - any other recommendations? |
I'm surrounded by them here in Cyprus, we have 'em in the bedrooms.
There doesn't seem to be much brand loyalty, although "Haier" seem quite popular. I guess most of 'em are made in China, draw your own conclusions.
Ours are "Rowa" units, 9000 btu cooling, rated for 480cubic meters per hour, they've been in for 10 years never had a problem with 'em, never needed to re gas. TBH they don't get used much so if your going to be using one daily you should do some research.
Make sure the cubic meter per hour figure, quoted on the unit, is enough to move at least 2.5 to 3 times the volume of the room per hour, otherwise you're wasting your money!
If you're using the unit for cooling, for maximum efficiency set the temperature to 3 degrees lower than the ambient temperature, there is no point setting it any lower, believe me I should know! ____________________ "Everybody needs money, that's why they call it money!"  |
| dydey90 |
 dydey90 World Chat Champion
There is a gap of 2 years, 85 days between these two posts... |
| Premium Cat |
 Premium Cat L Plate Warrior
 Posted: 13:00 - 18 Jun 2020 Post subject: |
My husband and I, we tried once DIY installing on our own the AC, because we moved in a new house. It was a bad idea, and we ended up buying a new one  |
| Polarbear |
 Polarbear Super Spammer
| MCN |
 MCN Super Spammer
| Premium Cat |
 Posted: 14:10 - 18 Jun 2020 Post subject: |
We had to buy a new AC unit of course! haha  |
| mentalboy |
 mentalboy World Chat Champion
| MCN |
 MCN Super Spammer
| mentalboy |
| MCN |
 MCN Super Spammer
 Posted: 09:49 - 24 Jul 2020 Post subject: |
| ingrowzelqui wrote: | My sister and I, we wanted once DIY installing on our own the AC, because we decided to try to live separately from our parents, so we wanted to see if we can succeed. We googled and informed ourselves about the process, so we thought we were ready to do it. It wasn’t such a good idea after all, as you can imagine, because we’re not professionals, and don’t know a lot about these technics. So, we ended up failing, and we had to ask for a professional’s help. Thank god the guys from https://www.catsnknobs.com/ came to assist us that evening because I’m sure if they didn’t, we’d ended up screwing the AC. Such interesting adventure in the middle of the summer was quite the experiment. Never again! |
You used God in your post so it's fake news. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| sgneeds |
This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
 sgneeds L Plate Warrior
 Posted: 06:39 - 15 Sep 2020 Post subject: |
| MCN wrote: | | ingrowzelqui wrote: | My sister and I, we wanted once DIY installing on our own the AC, because we decided to try to live separately from our parents, so we wanted to see if we can succeed. We googled and informed ourselves about the process, so we thought we were ready to do it. It wasn’t such a good idea after all, as you can imagine, because we’re not professionals, and don’t know a lot about these technics. So, we ended up failing, and we had to ask for a professional’s help. Thank god the guys from https://www.catsnknobs.com/ came to assist us that evening because I’m sure if they didn’t, we’d ended up screwing the AC. Such interesting adventure in the middle of the summer was quite the experiment. Never again! |
You used God in your post so it's fake news. |
What happened to that comment? Did he link it to an air con servicing
post? Like this website? I have been seeing a lot of it recently.
https://sghomeneeds.com/services/aircon-servicing |
| Polarbear |
 Posted: 17:54 - 15 Sep 2020 Post subject: |
Oh go on then, I'll chuck you a spam rating.  ____________________ Victory Cross Country American tractor. |
The last post was made 6 years, 36 days ago. Instead of replying here, would creating a new thread be more useful? |
