Carbs not going wide open xj600
buddy
PostPosted: 14:52 - 19 Jun 2020    Post subject: Carbs not going wide open xj600 Reply with quote
Hey all, noticed on my bike the carb butterflies dont open all the way. Is this normal?
Even if you push on the bit that the trhottle cable goes onto. Its a dead stop like its not supposed to open all the way.
When this baby hits 88 miles per hour... you're gonna see some serious shit.
A100man
PostPosted: 17:33 - 19 Jun 2020    Post subject: Reply with quote
There's normally some adjustment on the carb rack for balancing.. Perhaps you can get the to open more but you might affect the balance - .
Bhud
PostPosted: 18:46 - 19 Jun 2020    Post subject: Reply with quote
Looks normal to me, although I can't get a clear idea of the angle, from that picture. Are your carbs Mikuni BDS26?
If you're in any doubt, just have a look. Take the airbox off, and push the throttle linkage as far as it will go. It has a limited arc of travel, by design. The butterflies should open almost to a 90-degree angle at max throttle. This won't happen if there's an obstruction (e.g. if you dropped a screw or something which is getting wedged in between the linkage pulley and its furthermost rest position).
Check that they all look roughly the same, and if they are, you're good to go. If not, they may be well out of balance. Set up properly, when they're all closed, they're not fully closed and when they're all open, they're not at a perfect 90 degrees.
buddy
PostPosted: 20:49 - 19 Jun 2020    Post subject: Reply with quote
Thanks for the replies lads
So they are mikuni carbs, not sure what model.
And i can push on the throttle linkage and thats as far as they go.
The stupid picture wont load properly, but theyre about 90% open.
Its a dead stop i can feel, its not like the cable isnt allowing it. Its the carbs themselves i would say.
Ive not workes on bike carbs with this arrangement, but every other carb or throttle body i have seen will open all the way i.e. perpendicular.
She runs fine but i might have it off tommorow. Yes i would say at a glance the carbs seem balanced, they all travel the same amount
A100man
PostPosted: 23:14 - 19 Jun 2020    Post subject: Reply with quote
On reflection I think I'm talking shite - the adjuster screws only affect the amount of opening at idle..
buddy
PostPosted: 23:17 - 19 Jun 2020    Post subject: Reply with quote
Yeah the adjuster screw thats easily visible does the idle
A100man
PostPosted: 08:50 - 20 Jun 2020    Post subject: Reply with quote
Generally there's a main idle screw and 'round the back' some more for fine tuning the individual carbs (Balancing) - although it's best to have a set of vacuum gauges for that.
spottedtango
PostPosted: 12:48 - 20 Jun 2020    Post subject: Reply with quote
As said that looks normal. My Suzuki gs650 does the same at wide open throttle .
buddy
PostPosted: 09:48 - 27 Jun 2020    Post subject: Reply with quote
SOLVED:
incase anyone ever has a similar problem. It was one of the clips for the carb mounting rubbers fouling one of the outer carbs
Easy-X
PostPosted: 15:19 - 27 Jun 2020    Post subject: Reply with quote
buddy wrote:
SOLVED:
Great news! Could you take a snap of the area in question? Might help someone down the line Smile
buddy
PostPosted: 15:53 - 28 Jun 2020    Post subject: Reply with quote
Its virtually impossible to see with the carbs on. But i noticed it was opening wider with the carbs off the bike
Easy-X
PostPosted: 23:17 - 28 Jun 2020    Post subject: Reply with quote
Ah well, thanks for letting us know Thumbs Up
Bhud
PostPosted: 23:52 - 28 Jun 2020    Post subject: Reply with quote
There shouldn't have been any obstruction. If an intake rubber was interfering with throttle pull, then they weren't put on correctly in the first place. This would have been a very basic error made by someone putting the carbs back on the bike.
The last post was made 6 years, 73 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 76.11 Kb
