Air compressor
RAYK47
PostPosted: 10:42 - 23 Jun 2020    Post subject: Air compressor Reply with quote
Hi all, a little advised needed.
I am looking to buy a compressor for my car but also want to use it on my bike to check pressures and top up etc.
Can anyone recommend one that will be good for both. i assume i need it to be able to plug into 12v for car and mains for bike, but i can seem to find one of those (would using a mains adaptor be fine). prefer digital display for ease of use as well.
Preferable no more than £35-40
https://www.amazon.co.uk/FYLINA-AU01004-Inflator-Compressor-Adaptors/dp/B07SD49STH/ref=sr_1_12?dchild=1&keywords=compressor&qid=1592905209&smid=A3SP08KAKMM7PN&sr=8-12
Thanks in advance.
Riejufixing
PostPosted: 11:54 - 23 Jun 2020    Post subject: Re: Air compressor Reply with quote
Why a compressor? I'd buy an ordinary stirrup pump for the job. Much less faff. That's if you're not disabled in some way.
If you're putting on a new tubeless tyre, you'll probably want a much bigger compressor.
PostPosted: 12:24 - 23 Jun 2020    Post subject: Reply with quote
I bought one of these mains pumps for the garage. The pump itself is pretty good, but the cable and air line are short, the connector and case is cheap, and the gauge is next to useless.
https://www.amazon.co.uk/gp/product/B00133VDCM
I end up just using my 30 year old £10 Halfords foot pump and pencil gauge. Battered, but they work.
PostPosted: 12:38 - 23 Jun 2020    Post subject: Reply with quote
I have a proper compressor in my garage so that gets used most of the time.
For away from the garage I have a cordless compressor/jump starter.
If I was buying a new one I'd go cordless but without the heavy battery, something like this one purely because I cannot be bothered with cables. 1st world problems and all that.
https://www.amazon.co.uk/Werktough-Inflator-Handheld-Compressor-Automatic/dp/B07G944Y6W/ref=sr_1_11?dchild=1&keywords=compressor+charger&qid=1592912202&quartzVehicle=29-405&replacementKeywords=compressor&sr=8-11
[/img]
PostPosted: 18:38 - 23 Jun 2020    Post subject: Reply with quote
I have a proper compressor with a proper tyre inflator fitting.
I use a bicycle track pump with an integral pressure gauge to do my motorbike tyres though. By the time I've got the compressor turned on, charged up and the fitting attached, the job would have been done.
I only use the compressor for fitting tyres.
RAYK47
PostPosted: 10:22 - 24 Jun 2020    Post subject: Reply with quote
thanks for the responses guys.
I am not looking for something that i can use to change tyres (i am not able to do that) i am only looking for something that will be used to check levels and top up if needed. Also being portable.
A100man
PostPosted: 10:55 - 24 Jun 2020    Post subject: Reply with quote
Track pump or foot pump then - although 12v electric ones could be useful for camp beds - if you ever use them.
Riejufixing
PostPosted: 11:37 - 24 Jun 2020    Post subject: Reply with quote
I agree with stirrup pump for adding a bit of air, they're excellent, I find them much better than foot pumps, which jump about a bit. For camp beds I have a low-pressure, high volume 12V "blower upper" which I think was £7 from Lidl. Knocks spots off those plastic bellows things.
Perhaps:
https://www.amazon.co.uk/Amtech-I9455-Aluminium-Hand-Gauge/dp/B001DYCKY6/ref=sr_1_3?dchild=1&keywords=stirrup+pump+aluminium&qid=1592994791&s=automotive&sr=1-3-catcorr
Edit: Criticism of the above because "the handle falls off". I reckon people must be ham-fisted, if I may say that, and pull up hard. That happened on my £4.99 Lidl one, but it was easy to push the handle back on.
RAYK47
PostPosted: 13:26 - 24 Jun 2020    Post subject: Reply with quote
Thanks all, i think i will get one of those.
jeffyjeff
PostPosted: 16:54 - 25 Jun 2020    Post subject: Reply with quote
I use one of these. Very portable, I keep it under the seat along with a tire plug kit. Removed the lighter jack and replaced with an SAE connector that matches the plug for my battery tender. I've used it several times, once to repair a flat on the road some 45 miles away from home. I bought it after experiencing mixed results with a CO2 cartridge tire inflator.
kramdra
PostPosted: 10:04 - 26 Jun 2020    Post subject: Reply with quote
As above, electric tyre inflator under seat. They can be made quite a bit more compact by removing the case. I use a ring branded one which is excellent and also used it for fitting several tyres when I couldnt be bothered to get big compessor out.
The last post was made 6 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 70.96 Kb
