| doggone |
 doggone World Chat Champion
 Posted: 16:16 - 28 Jun 2020 Post subject: |
I'd imagine straight electrics. Electricity will take the path of least resistance so if the LED/resistor combination is in paralell with the fuse itself, the electricity will simply go down the fuse wire because there is next to no resistance.
If the fuse blows, it'll then go through the LED (and presumably doesn't cook the wiring because the LED is applying load to the circuit).
I use a similar thing for finding shorts where I plug a bulb in in place of the repeatedly blowing fuse. When the bulb goes out, the short is gone. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| WD Forte |
 WD Forte World Chat Champion
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| WD Forte |
| Nobby the Bastard |
| Islander |
 Islander World Chat Champion
 Posted: 19:11 - 28 Jun 2020 Post subject: |
The resistance of a semiconductor is tricky to calculate as it's non-linear in relationship to the current that's passing through it. However, as the forward voltage of a typical LED is around 1.2v it will require a suitable resistor in series to ensure that the foward current doesn't exceed the maximum value. So if we assume a forward current of around 20mA, it'll need a resistor that will drop 10.8v at that current. This is around 540 ohms - 560 is a good value to use.
A fuse would typically have a resistance of a few millohms - a much lower resistance than the LED and series resistor. The current would flow in proportion to the ratio of the resistances. Let's assume a combined resistance on the LED of 600 ohms and a fuse resistance of 60 milliohms. That would mean that 10,000 times more current would flow through the fuse than the LED. The LED would remain unlit as long as the fuse was intact. If it ruptures, then the led would draw the current that the resistor allowed and would light.
Simple really  |
| Polarbear |
 Polarbear Super Spammer
| Islander |
| Easy-X |
 Easy-X Super Spammer
 Posted: 22:25 - 28 Jun 2020 Post subject: |
Anyway.
The smart place for the LED is on the fuse holder, not the fuse itself. You have to throw the LED away every time the fuse blows with an indicator fuse.
And even those are dumb because you can get re-settable circuit breakers that go in the place of a blade fuse these days. They cost about tree fiddy. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 6 years, 138 days ago. Instead of replying here, would creating a new thread be more useful? |
