Dt 125re 2005 no power, feels flat
Ballsdeep69
PostPosted: 22:35 - 29 Jun 2020    Post subject: Dt 125re 2005 no power, feels flat Reply with quote
Hi everyone I am Andrew and I have a dt 125 re 2005 which feels really flat. I have just put a new piston and rings in, done the crank seals etc. It ticks over smooth and drives through all the gears but is really lagging in power in ever gear. I have pinned the power valve open half way to try that but it is still flat. You open it up we're it starts to get going but just bottoms out on the revs change gear bottoms out again. When you put full throttle out and max it to the top it starts to miss like it's not sparking right or not getting enough fuel to give it that extra power. does not have that power valve type feeling on it. I can ride it about round the doors but it is so flat. Only Doing about 40 mph top end
WD Forte
PostPosted: 23:13 - 29 Jun 2020    Post subject: Reply with quote
Have you given it a dose of caustic soda down the exhaust at all?
maybe it's all gummed/coked up.
bikers smell of wee
Easy-X
PostPosted: 00:07 - 30 Jun 2020    Post subject: Reply with quote
And of course, at the other end how's the air filter?
Nice nickname. I'm guessing you're a youngster Smile
Ballsdeep69
PostPosted: 00:20 - 30 Jun 2020    Post subject: Reply with quote
[quote="Easy-X"][quote="WD Forte"]Have you given it a dose of caustic soda down the exhaust at all?
maybe it's all gummed/coked up.[/quote]
Nice nickname. I'm guessing you're a youngster :)[/quote]
Tried a new one mate.
Ballsdeep69
PostPosted: 00:27 - 30 Jun 2020    Post subject: Reply with quote
Yes tried another exhaust also.
A100man
PostPosted: 08:10 - 30 Jun 2020    Post subject: Reply with quote
Cable routing, throttle slide opening fully?
Carb clean and check jet sizes ?
redeem ouzzer
PostPosted: 08:56 - 30 Jun 2020    Post subject: Reply with quote
Piston Clearance?
Be a REAL MAN!
Fizzer Thou
PostPosted: 10:18 - 30 Jun 2020    Post subject: Reply with quote
Is the gasket between the reed valve block and the barrel in good condition?
Is the reed valve in good condition?
Have you tried a new plug cap?
Always have a 'Plan B'
jeffyjeff
PostPosted: 04:55 - 01 Jul 2020    Post subject: Reply with quote
Besides checking the reed valve and carburetor slide, you might also consider some additional possible causes of your low power condition:
1. Fuel flow to the carburetor could be restricted.
2. Tank vent could be clogged, resulting in low fuel flow to the carburetor.
3. Carburetor main jet could be obstructed or gummed up (especially true if the bike has been sitting for an extended period)
4. Carburetor float could be set improperly, or the float valve could be stuck or obstructed.
5. Weak spark or problems with ignition timing advance might also affect your high end performance.
Good luck with your troubleshooting. Let us know what you find.
Robby
Dirty Old Man
PostPosted: 07:30 - 01 Jul 2020    Post subject: Reply with quote
Drain the carb and see what comes out, I have symptoms like this from water in the carb before. Its works OK on the pilot jet which is pickup up fuel from the top of the float bowl, but when you get on to the main jet it's picking up a mixture of fuel and water from the bottom of the bowl.
Lots of simple things that it could be. Lots of more complex things as well - this is a recently rebuilt 125, I have no idea about your mechanical competence, so I have to assume you may have cocked up something on the rebuild.
As mentioned, a new spark plug and cap never hurts. I'm assuming the two-stroke oil system is working properly and it has oil in the bottle.
The last post was made 6 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 62.33 Kb
