F650GS Fault
struan80
PostPosted: 14:48 - 04 Jul 2020    Post subject: F650GS Fault Reply with quote
Riding along minding my own business and the bike just cut out and died. No power even enough to start the dashlights.
It has a new battery so I'm thinking it may be the rectifier or stator. Is there a way of testing these?
Check Insulation resistance and a continuity test? Is there any other method for checking this? Thanks.
spottedtango
PostPosted: 15:12 - 04 Jul 2020    Post subject: Reply with quote
Have you checked the starter relay fuse hasn't popped? Give the other fuses a check too.
Also check if there's a block connector that goes to the relay and that isnt loose.
smokin joe
PostPosted: 16:21 - 04 Jul 2020    Post subject: Reply with quote
I'd bet on the fuse. Same thing happened to me when I had a GPZ500.
I pushed the damn thing over two miles home and then discovered a spare fuse in the box Mad
struan80
PostPosted: 16:25 - 04 Jul 2020    Post subject: Reply with quote
Thanks guys. I'll check the fuses first, would be the wise thing to do....doh
martin734
PostPosted: 18:13 - 04 Jul 2020    Post subject: Reply with quote
Stupid question, but have you checked the battery leads? I had the same symptoms on a previous bike and after much head scratching it was found to be a knackered negative battery lead that had come adrift.
Current bike: ST1100 "Big Red"
Nobby the Bastard
Harley Gaydar
PostPosted: 18:32 - 04 Jul 2020    Post subject: Reply with quote
First question: Do you have a multimeter?
Triumph Sprint ST 1050
struan80
PostPosted: 20:56 - 04 Jul 2020    Post subject: Reply with quote
Yes I have a multimeter.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:42 - 04 Jul 2020    Post subject: Reply with quote
Check the voltage on the battery in dc. Should be about 12-13 volts.
Then start the bike. It should now read 14-15 volts.
Tell us the results.
xX-Alex-Xx
PostPosted: 22:11 - 04 Jul 2020    Post subject: Reply with quote
You say it’s got a new battery... you did check the leads were on tight? You didn’t say what you’ve already tried...
DILLIGAF
The last post was made 6 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.03 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 56.78 Kb
