Wanted, electrics wizard for Honda 600 hornet 2000
kevb
PostPosted: 19:31 - 05 Jul 2020    Post subject: Wanted, electrics wizard for Honda 600 hornet 2000 Reply with quote
Anyone out there that's a bit of a guru on the electrics for this machine?
So I've recently bought an engine complete with loom, CDI and coils, the project is a kartcross. I've just spent the entire weekend trying to get it running but I'm at a loss, I haven't got as far as getting a spark yet!
I'm hoping that one of you guys understand the "conditions" required from the CDI to start. From the electrical diagram and reading posts on here this is what I've got.
CDI inputs/outputs
crank sensor OK
carb position sensor OK
Green wire earthed OK
Black and white wire 12v+ OK
Pink wire 9v+ reference OK
Coils OK
Light green wire to neutral switch OK
Yellow and yellow & white pulse generator OK
Green and white- this is the one I'm a bit confused about. Does it require
to be grounded or is there another type of signal/input that I'm missing.
Looking at the diagram this is what I think it needs to run???
Anyone out there that is able to shed to some light on the matter....PLEASE.
TIA Kev.
PostPosted: 19:34 - 05 Jul 2020    Post subject: Reply with quote
Did that model have HISS? If so you need the HISS assembly from the ignition barrel - and the correct key.
kevb
PostPosted: 19:40 - 05 Jul 2020    Post subject: Reply with quote
No it's pre HISS, it's a more simplified approach where there's a diode in the ignition switch that regulates the voltage to 9v for the pink wire.
BigTim
PostPosted: 22:33 - 05 Jul 2020    Post subject: Reply with quote
My blackbird 98/99 is HISS but it doesn't say so anywhere on the ignition.
i say this in case you're assuming it isn't because it doesn't say it.
MZ S50B, Suzuki GP100, Honda CBF1000, Honda Blackbird (I like my Blackbird)
kevb
PostPosted: 15:41 - 06 Jul 2020    Post subject: Reply with quote
The wiring diagram shows it to be without immobiliser, HISS came in on the hornet 2002/2003 I believe.
kevb
PostPosted: 21:21 - 11 Jul 2020    Post subject: Reply with quote
F18
PostPosted: 15:23 - 12 Jul 2020    Post subject: Reply with quote
Didn't these also have a throttle position sensor - but wired into the ignition control module (rather than an ecu).
I'd say if you've got the 14-pin module, you'll need something on all 14 lines.
Summer is just around the corner
kevb
PostPosted: 18:07 - 13 Jul 2020    Post subject: Reply with quote
yes it has the throttle position sensor connected
F18
PostPosted: 22:19 - 14 Jul 2020    Post subject: Reply with quote
Is it wired ?
Have you got something on all 14-lines ?
kevb
PostPosted: 21:06 - 21 Jul 2020    Post subject: Reply with quote
F18 wrote:
Is it wired ?
yes, all wired
That_Hornet
PostPosted: 21:18 - 21 Jul 2020    Post subject: Reply with quote
Side stand switch?
F18
PostPosted: 11:38 - 22 Jul 2020    Post subject: Reply with quote
^^^^^^^ that is your G/W
- the full circuit is s/stand and clutch switch with diodes (in the fuse holder).
You do have the right diagram, yes ?
(Because I don't know what you have and I don't even know which diagram for certain you need.)
Are you certain your pink (snark!) is wired correctly via the bit that it needs to ? I'd have thought this was most likely an issue as it is deliberately not shown on most diagrams (and not for discussion in an open forum).
Did this actually run ?
kevb
PostPosted: 19:20 - 06 Aug 2020    Post subject: Reply with quote
Not running yet Sad
I believe I have the correct diagram, well all the wires (including the pink) correspond to my harness.
I've tried everything (I think) including a change of crank sensor and ICM,. The coils have the correct ohm readings.
Help!
F18
PostPosted: 23:05 - 06 Aug 2020    Post subject: Reply with quote
I'm thinking it is most likely your pink.
It is generally undocumented for a good reason.
That *needs* to be correct before it will play.
You don't mention how you are testing the ignition - you do know it is a wasted spark type. It is easy to get misdirected when checking this, the whole setup works togther. And, you need a good frame earth to check one plug (at a time) - that paint can be quite good sometimes.
Of course, it isn't unknown for older Honda CDI units to fail.
The last post was made 6 years, 98 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 79.89 Kb
