| Riejufixing |
| steve the grease |
 Posted: 19:03 - 06 Jul 2020 Post subject: Re: LED stop/tail lamp arrays. |
| Riejufixing wrote: | The sort with multiple LEDs. I have seen one with only some of the LEDs working, not the same ones consistently though. On the same lamp, some of the brake light LEDs work, again not all consistently, and not all the same as the tail lamp LEDs. Cause? Fixable? |
Manufacturers ones are probably fine , but some of the lights that are imported and sold on Ebay and Amazon are just not up to it. The weather proofing is not up to a standard that works in the UK. I have an LED light on my bike water has got in and corroded it all up. It trash basically. I have fitted about 6 new rear lamp clusters to my neighbours Landrover. Same story - water ingress- some LEDs fail. ____________________ All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
I've been riding, and fixing , bikes for 50 years, in that time the more I learn, the less I am absolutely sure of..... |
| A100man |
 A100man World Chat Champion
 Posted: 20:38 - 06 Jul 2020 Post subject: |
I just fxed one of those LED disco lights for my daughter. Needed a specific blue LED which I source from ebay for a couple of quid. You need to get the power/current correct though or it will 'blow' .. This was 1W and surpisingly bright i.e. you couldn't look directly at it.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Riejufixing |
| Easy-X |
 Easy-X Super Spammer
| Riejufixing |
 Posted: 22:49 - 06 Jul 2020 Post subject: |
| Easy-X wrote: | How about metal fatigue on the circuit board due to poor quality soldering i.e. dry joints. Any change in the pattern if you belt it tap it lightly? |
This is from following the bike when it was going along, so there will have been bumps. The "grid" of tail lamp LEDs was changing; some going off, some coming on, from time to time; the brake lamp side of things was similar but not as bad, and not matching. I don't know hoe the LEDs are arranged. I've got another unit here, but it's sealed. Maybe the brake LEDs are the same as the tail ones, fed a higher voltage? Looking through the lens, I can see four cross-head screws fixing the "chrome" reflector to whatever's behind it, which possibly has the LEDS on a circuit board behind it too.
Poor solder joints are a nightmare. I once repaired the Isuzu DCU on an Astra MKIV, by re-doing a solder joint in it, which saved about £700. Just for a dab of solder! HJ published my fix, hope it helped someone else. |
| Robby |
 Robby Dirty Old Man
| Easy-X |
| WD Forte |
 WD Forte World Chat Champion
| Fizzer Thou |
The last post was made 6 years, 100 days ago. Instead of replying here, would creating a new thread be more useful? |
