Honda CB125T poor spark
ajb235
PostPosted: 16:46 - 07 Jul 2020    Post subject: Honda CB125T poor spark Reply with quote
My CB125T has a poor spark at the plug, giving me poor starting and running.
When I check through the HT system I have copper cored HT leads, 5k ohm resistance plug caps and resistor plugs.
Seems to me that resistor plugs AND resistor plug caps is not right, and there is too much resistance in the HT circuit.
So, is it resistor plugs or resistor plug caps? What did Honda do originally?
I would also like to know the correct spark plug type.
Thanks
ajb
ajb235
PostPosted: 16:48 - 07 Jul 2020    Post subject: Honda CB125T poor sparks Reply with quote
It's a 1981 bike , which 6volt electrics.
Fisty
PostPosted: 17:32 - 07 Jul 2020    Post subject: Reply with quote
Wall of incoherent autism incoming.
Fatter and faster than Fret
jaffa90
PostPosted: 17:42 - 07 Jul 2020    Post subject: Reply with quote
Fit a non resistor cap and a spark plug without the R and S, find a copper core if you can.
gbrand42
PostPosted: 18:23 - 07 Jul 2020    Post subject: Reply with quote
Teflon is gonna have a field day with this, brace yourselves
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
Fizzer Thou
PostPosted: 20:58 - 08 Jul 2020    Post subject: Reply with quote
On my CB125T2 I had weak sparks when I first hooked up a battery so as to try and start the bike.But both spark plugs only had a very weak spark,so I checked the voltages feeding the coils,which are fed by the 6 volts via the ignition switch.As there is no kill switch there should have been 6 volts on the coils but there was only about 3 volts.Having rebuilt the igniton switch after cleaning the internal contacts I now had the full 6 volts on the coils and nice fat sparks from the new NGK standard CR8HS plugs and resistor plug caps.
As it happened,there was a smoke screen from both exhausts as the pistons and bores are extremely worn.But that is another story.
Always have a 'Plan B'
ThunderGuts
PostPosted: 07:29 - 09 Jul 2020    Post subject: Reply with quote
I was assuming that, but barring a single post a week ago, he's not been seen since May. Thinking
TG.
steve the grease
PostPosted: 15:12 - 09 Jul 2020    Post subject: Reply with quote
I have a lot of time for people who check things out - find the problem -take something apart and fix it.
Fisty
PostPosted: 17:46 - 09 Jul 2020    Post subject: Reply with quote
Must be furloughed from BCF
ajb235
PostPosted: 21:33 - 09 Jul 2020    Post subject: Reply with quote
Thanks , that's well worth a try.
ajb235
PostPosted: 13:37 - 25 Jul 2020    Post subject: Reply with quote
Well, a success story to report. On the advice of fizzerthou I checked the voltage at the coils, which was low at 5.3 volts. I replaced the ignition switch and soldered the wiring connections to the coil. Who needs old push fit connectors anyway? I also replaced the plug caps and plugs with non resistor types. Started straight away with a good fat blue spark at the plugs. Result! Thank you!
Fizzer Thou
PostPosted: 21:47 - 26 Jul 2020    Post subject: Reply with quote
Glad to hear that you have got it sorted Thumbs Up Very Happy Thumbs Up
Enjoy the first ride Cool
Have some kharma for a good effort Thumbs Up Karma
jaffa90
PostPosted: 23:44 - 26 Jul 2020    Post subject: Reply with quote
""""I also replaced the plug caps and plugs with non resistor types. """"
What about thanks/ karma for me? Sad
jeffyjeff
PostPosted: 15:27 - 27 Jul 2020    Post subject: Reply with quote
...says the man with 3 gold medals. Wink
Respectfully, the karma you've acquired by helping out your brother cannot be measured in gold blobs. Its way more profound and deeper than that. it's the real deal.
The last post was made 6 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 82.77 Kb
