| EazyDuz |
 EazyDuz World Chat Champion
| Easy-X |
 Easy-X Super Spammer
 Posted: 22:48 - 07 Jul 2020 Post subject: |
Unless you're talking CX500 or Moto Guzzi I'd be very surprised if your valve clearances from front to back weren't different - the front's always gonna dump heat better than the rear
As to the how of valve clearances changing over time you'll need a materials engineer. There'll be one along shortly... ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| steve the grease |
| jeffyjeff |
 jeffyjeff World Chat Champion
| EazyDuz |
 Posted: 09:14 - 09 Jul 2020 Post subject: |
| jeffyjeff wrote: | | Easy-X wrote: | As to the how of valve clearances changing over time you'll need a materials engineer. There'll be one along shortly... |
The mechanical engineer is out to lunch, but he saw your post and asked me to help out. ha ha. I'll try a brief explanation.
The exhaust valves are the hottest moving parts of your engine, followed by the intakes. Over the millions of cycles between service intervals, the valve face and seat wear into each other. This effectively causes the valve to recede into the cylinder head, reducing clearance between the rocker arm and valve stem. It is normal for valve clearance to decrease over time.
How can the clearance increase? The C800 rockers have a wide, flat shoe (opposite the adjuster) that the cam acts upon. Wear on the rocker shoe, or wear on the cam lobe can cause the valve clearance to increase. Wear on your screw adjusters can also increase the clearance.
In a perfect world, wear on the cam and follower is exactly offset by wear at the valve face and seat, and the engine can go many thousands of miles without adjustment. |
Interesting, thanks for the detailed reply.
Service interval is every 7500 miles on the tappets but I don't see an issue with doing it every 10,000. Yes some valves were tight but had no hot starting problems and the bike was running just fine before hand. It was just nagging me not knowing when the last valve job was done as it's not in any of the previous owners service records. ____________________ To shreds you say? Tss tss tss |
| Easy-X |
| jeffyjeff |
The last post was made 6 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
