YBR125 strange chain tension/noise advice
ruprechtmonke...
PostPosted: 21:54 - 13 Jul 2020    Post subject: YBR125 strange chain tension/noise advice Reply with quote
Hi all, got a strange issue with my bike. I bought it a couple of months ago to practice on due to my test being delayed because of the lockdown. It's had a new chain and sprocket set but I noticed when checking that the chain had too much slack. I've adjusted it to about 25mm (manual states 20mm - 30mm). However in doing this it developed a noise when riding which I can best describe as an almost rubbing/whirring that comes and goes every few revolutions of the rear wheel and increases/decreases with speed. Seems to happen more when the throttle is applied. I thought it may have always done this and I hadn't noticed so to test this theory I loosened off the chain a bit and took it for a ride. The noise went. I've checked both the front sprocket and wheel alignment, etc and all looks good (I've also changed the oil on the bike). The back wheel spins freely when on the centre stand. Now obviously I don't want to ride about with a loose chain so does anyone have any ideas what may be causing this? Thanks
Riejufixing
PostPosted: 22:25 - 13 Jul 2020    Post subject: Reply with quote
Check the tension at various points. So, rotate the back wheel nearly half a turn, check. Do it again, check. And again, until you have checked a few points. Is it tight anywhere? Perhaps it is. You will have to say!
jaffa90
PostPosted: 23:44 - 13 Jul 2020    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=330781
steve the grease
PostPosted: 00:05 - 14 Jul 2020    Post subject: Reply with quote
I think the 20-30 mm is when you are sat on the bike. It's probably miles too tight if you adjusted it on the stand. As you apply weight ( like sit on the bike) the chain gets loads tighter , loosen it off and see if it improves.
Nobby the Bastard
Harley Gaydar
PostPosted: 08:19 - 14 Jul 2020    Post subject: Reply with quote
Most manuals state tension should be checked unloaded and on the side stand.
Is the alignment t of the back wheel been checked?
Triumph Sprint ST 1050
ruprechtmonke...
PostPosted: 11:24 - 14 Jul 2020    Post subject: Reply with quote
Yes, the manual states that. I've checked the alignment a few times now and made sure the marks line up on either side.
Riejufixing
PostPosted: 12:35 - 14 Jul 2020    Post subject: Reply with quote
There can be a difference between what the marks say and what actually is. I would be inclined to double-check.
ThatDippyTwat
PostPosted: 18:02 - 14 Jul 2020    Post subject: Reply with quote
My old YBR was miles out when adjusted on the marks, even the MOT chap commented on it. Use a rule/caliper and measure from a fixed point.
ruprechtmonke...
PostPosted: 09:39 - 16 Jul 2020    Post subject: Reply with quote
Thanks for the tips. So I've measured from a fixed point and the wheel is aligned, took the chain guard off and noticed the part nearest the front sprocket was slightly bent and had a 'clean' bit inside possibly where the chain was rubbing? I bent this back and cleaned/lubed the chain for the first time since getting the bike. Result is the noise has gone away so one or both of these things sorted it. Cheers
The last post was made 6 years, 65 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 59.36 Kb
