| Riejufixing |
 Riejufixing World Chat Champion
| The Artist |
 The Artist Super Spammer
| Fisty |
 Fisty Super Spammer
| Riejufixing |
| Riejufixing |
| panrider_uk |
 panrider_uk World Chat Champion
| Polarbear |
 Polarbear Super Spammer
| Fisty |
 Fisty Super Spammer
| Riejufixing |
| hedgehugger |
 hedgehugger World Chat Champion
| stinkwheel |
 Posted: 23:58 - 13 Jul 2020 Post subject: |
Some varieties of spud are good for making chips, others are terrible. King Edwards are probably favourite of the ones you commonly get in the shops. Then Maris Pipers.
Also, don't be afraid to just deep fry them. It's how chips are supposed to be made anyway. I deep fry them in a wok. Heats up quick, uses comparatively little oil. the trick is to do them in small batches with the temperature high enough.
Chip pan fires tend to happen when they are left unattended by drunk people. They happen rarely when attended by a sensible, sane person and are only dangerous if you panic. The trick is to simply put the lid on if it takes ahold and it'll go out. Wont even spoil the chips. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| The Artist |
| wr6133 |
 wr6133 World Chat Champion
| ThunderGuts |
 ThunderGuts World Chat Champion
| ThunderGuts |
 Posted: 08:27 - 14 Jul 2020 Post subject: |
| wr6133 wrote: | | The Artist wrote: | And about steak, the best way is sous vide |
Intrigued. In my head the flavour is going to be pure, unadulterated beefy awesomeness.
Is there a cheapo way I can try this at home without buying any fancy equipment? |
The key with sous vide is temperature control; without a thermostat, a small pan of water can be adjusted manually and monitored with a thermometer, but because it's a small volume of liquid the temperature fluctuates all over the place, which isn't good. If you have a large stockpot, even though it seems overkill, fill it up with water as it's a greater mass meaning less rapid temperature fluctuations. Just keep on adjusting the temperature and checking periodically. Alternative is if you have a watertight coolbox, preheat that then fill with water, adjust temperature by scooping some water out and adding some boiling water. Years ago I used to use a converted coolbox to mash grain in when brewing beer; I'd lose about 3 degrees C over an hour without touching it (although the grain does increase thermal mass), but I was unhappy with that loss so built my own mash tun. I was mashing at about 67 deg C - not sure what temp you would sous vide steak at but I'd imagine most coolboxes would handle 80 deg C easily enough, I'd be wary of going higher. Don't worry about the fact it's hot water and plastic as the food is protected by the sous vide bag.
Sous vide is quite interesting, but for meats you'll need to sear it afterwards or something. ____________________ TG. |
| The Artist |
 Posted: 10:26 - 14 Jul 2020 Post subject: |
https://i.redd.it/n65yvxor96l41.jpg
Not my pic but this is what you can do. Perfectly cooked all the way through and then an extremely hot sear to make the crust.
You really need a sous vide machine (£100 minimum) to do it properly and then you need some method of searing afterwards. A normal frying pan is not enough and most other methods make a lot of smoke so not advisable in a normal kitchen. |
| Riejufixing |
| hellkat |
 hellkat Super Spammer
| The Artist |
| Riejufixing |
| ThunderGuts |
| The Artist |
| Ribenapigeon |
 Ribenapigeon Super Spammer
| A100man |
 A100man World Chat Champion
 Posted: 22:43 - 14 Jul 2020 Post subject: |
Dear oh my - 'sous vide' .. ffs
Coming up in next thread..
'Nobby's crocheting tips..'  ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| Riejufixing |
The last post was made 6 years, 63 days ago. Instead of replying here, would creating a new thread be more useful? |
