C-clip sizes
XT65
PostPosted: 23:42 - 13 Jul 2020    Post subject: C-clip sizes Reply with quote
Good evening all
If an exhaust outlet diameter is 34mm , then what size C-clip to hold in the db killer? And DIN?
Is it bigger (35mm) or the same?
Sounds a daft question I know..
I'm looking at them in eBay.
It's for an arrow 52501 AO system that's the only spec I could find was the outlet diameter.
Any suggestions please?
Cheers all!
steve the grease
PostPosted: 12:11 - 14 Jul 2020    Post subject: Reply with quote
Its a bit of an abstract question. "If the exhaust outlet diameter is 34mm." What does that mean? I think you need to be more specific. The exhaust port? The exhaust pipe bore diameter? The exhaust pipe external diameter? Without at least one hard and fast fact it's impossible to understand your dilemma...Let alone make any helpful suggestions.
jeffyjeff
PostPosted: 17:55 - 14 Jul 2020    Post subject: Reply with quote
At the risk of being way off base, it seems to me that you are asking about a band clamp or muffler clamp, not a C-clip. Usually band clamps have an operating range based on diameter. Assuming the exhaust can slides over the header pipe, and assuming 34mm is the OD of the header pipe, you need something larger to accommodate the can. 35mm is probably too small. Probably best to purchase the muffler and measure before buying the clamp. Again, sorry if I misinterpreted your question.
The last post was made 6 years, 73 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.15 - MySQL Queries: 15 - Page Size: 35.64 Kb
