| RickTaff |
 RickTaff Nitrous Nuisance
 Posted: 19:40 - 09 Jul 2020 Post subject: Front brake help, please! |
Fitted brand new discs and pads to my CB500S, took it to MOT passed fine, no advisory's at all. Checked brakes they were fine, spun front wheel while on a jack and it spun ok.
What I have noticed though, and it was noticeable even on way to MOT, is the rear brake works perfectly fine, but the front one is puzzling me.
If I am travelling say 30, 40, 50 etc mph and pull the front brake to slow down due to the car in front turning or braking etc it seems fine, but when rolling to a dead stop at a traffic light or say junction with front brake lever engaged; You can feel a sort of "jerky" feeling in the stopping motion, like the front wheel has abit of drag to it.
Discs aren't warped, theyre brand new and he checked it all in MOT, pushed pistons back in before fitting new pads, too
Could it be
1 - The front brakes need bleeding again, as i maybe still have air in system. (lever feels ever so slightly spongy, doesn't travel all the way to the bar when pressed, but i'd say at most halfway or so)
*I did query the air theory with a garage earlier and they seemed to think it could be, their opinion was because the lever has to travel maybe a little further than normal to engage the brakes, it's causing the pads to grab/bite the disc harder than maybe usual -due to the lever being further in-, thus causing the "non-smooth" stopping motion*
2 - There is maybe some shit on the disc/pads and brake cleaner and scotch pad is needed.
3. They still aren't quite worn in or bedded in. Have done about 90 miles on them
Cheers.
| Nobby the Bastard |
| RickTaff |
| Islander |
 Islander World Chat Champion
| A100man |
 A100man World Chat Champion
 Posted: 21:07 - 09 Jul 2020 Post subject: |
| Islander wrote: | Did you clean the mounting surface thoroughly before you fitted the new discs? |
This..
Fitted some new discs to wife's Picasso once but omitted to clean all the rust off the hub so the mounted just a couple of thou out of true. Over a period of weeks they developed high spots (apparenty they can get 'heat treated' on the high spots which accelerates the 'warping') and had to junk them after a few thousand miles instead of 10-20k due to judder. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| Robby |
 Robby Dirty Old Man
| stinkwheel |
 Posted: 23:37 - 09 Jul 2020 Post subject: |
The ones with the brembos can be really bad for pulsing. I had a nighmare with Mrs stinkwheels one. Even landed up dial gauging and shimming the disc. Some of the pattern discs had a vertical runout straight out of the box!
You can buy floating discs for them now. Much better. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Robby |
 Robby Dirty Old Man
| Polarbear |
 Polarbear Super Spammer
| RickTaff |
| Robby |
 Robby Dirty Old Man
The last post was made 6 years, 69 days ago. Instead of replying here, would creating a new thread be more useful? |
