Cutting a drive chain/Fitting fork bush guides.
Irezumi
PostPosted: 15:00 - 15 Jul 2020    Post subject: Cutting a drive chain/Fitting fork bush guides. Reply with quote
I very rarely change a drive chain and when I have I'f normally had access to power points to remove the chain. This time I don't so I'm looking for alternatives.
Has anybody ever hacksawed or used bolt croppers on an old chain? Which is best, any other suggestions?
Thanks for any help.
martin734
PostPosted: 15:05 - 15 Jul 2020    Post subject: Reply with quote
Without power tools I have managed to split one using a file, a chisel and a large lump hammer. Although a battery angle driver would have been much easier.
Current bike: ST1100 "Big Red"
Riejufixing
PostPosted: 15:50 - 15 Jul 2020    Post subject: Re: Cutting a drive chain Reply with quote
Bolt croppers snip drive chain very easily. You might need to adjust the jaws to "close", that's all. No fuss, no mess.
Irezumi
PostPosted: 19:27 - 15 Jul 2020    Post subject: Reply with quote
Thanks for the help, much appreciated.
I'm now having another issue which I'll put in here regarding fork guide bush. What are people DIY ways of installing these? The bush needs to be compressed and pressed down simultaneously to fit.
PostPosted: 19:37 - 15 Jul 2020    Post subject: Reply with quote
Bit of plastic waste pipe with a similar ID to the fork OD and a mallet.
Irezumi
PostPosted: 20:10 - 15 Jul 2020    Post subject: Reply with quote
Thought that was going to be the suggestion, which is what I've done before. However my current forks are 46mm stanchion diameter. So finding a 46ID and a 50-ish OD is proving tricky.
Hong Kong Phooey
PostPosted: 20:30 - 15 Jul 2020    Post subject: Reply with quote
Hacksaw goes through in under 30s.
Riejufixing
PostPosted: 22:06 - 15 Jul 2020    Post subject: Reply with quote
Sir could perhaps find a shortish length of 50mm and expand it by resting a hot piece of bar or tube along the inside. I assume someone sells a boring old tool to do the job though.
PostPosted: 22:58 - 15 Jul 2020    Post subject: Reply with quote
In fairness, yes, just buy the fucking tool. having done so, I wish I had bought a seal driver years ago. You can get adjustable ones that are pretty much universal.
Next on the list is a blind bearing puller.
Riejufixing
PostPosted: 23:56 - 15 Jul 2020    Post subject: Reply with quote
Rawlbolts Smile (Kukko do nice ones if you want to - pah! - buy the proper job Wink ).
Hong Kong Phooey
PostPosted: 00:01 - 16 Jul 2020    Post subject: Reply with quote
Never fancied hammering bread into a hole?
Riejufixing
PostPosted: 00:06 - 16 Jul 2020    Post subject: Reply with quote
He won't need to if he's got the dough....
(Haw! Haw! Yes, I had to look it up!)
Robby
Dirty Old Man
PostPosted: 11:20 - 16 Jul 2020    Post subject: Reply with quote
Blind bearing pullers are fairly cheap now for hobby-grade ones. I think my set was under £50, and has been worthwhile.
Fitting bushes, I use plastic plumbing waste pipe. If it's too small to fit over the fork, I just cut it lengthways and open it up so I get a snug fit over the fork and coverage of most of the bush.
Bushes shouldn't need that much force to drive in. Make sure the fork leg where the bush sits is clean - a quick clean-up with a finishing pad or very fine emery paper to remove any corrosion, varnish or crap. Also good to run a pick or very small screwdriver around the bottom of the seat where a bit of crap tends to accumulate.
The last post was made 6 years, 66 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 76.53 Kb
