| Ste |
 Ste Not Work Safe
| kramdra |
 kramdra World Chat Champion
 Posted: 14:35 - 16 Jul 2020 Post subject: |
Also looks like bicycle bleed nipples are just screw holes with an oring seal, there is no nipple that seals on a tapered seat? I am not quite sure how that works as some air will get in when swapping the nipple for the sealing screw.
https://cdn.shopify.com/s/files/1/0269/4791/1754/files/mineral-oil-boiling-points.png?v=1571391068
Interesting.
To swap dot4 would likely need new seals and hose, or just strip and clean?
No I am not using baby oil, tho it would be easy to check its boiling temp.. |
| stinkwheel |
 Posted: 19:27 - 16 Jul 2020 Post subject: |
It's a totally sealed system. You fit a funnel thing into the hole so you can brim it with oil, bleed all the air out then put the screw in. No reservoir as such.
I'm not sure if the seals will be an appropriate material for DOT4.
My AVID Juicy brakes use DOT4. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Ste |
 Ste Not Work Safe
 Posted: 19:54 - 16 Jul 2020 Post subject: |
The seals in mineral oil systems will be unhappy if DOT fluid is put in the system.
For bleeding them you'll need either the Shimano bleed funnel or a syringe with the same fitting that Shimano levers use.
Air won't get in when you refit the screw to the caliper after removing the bleed syringe and hose.
There'll be appropriate bleed kits available if needed (like this https://www.totalbleedsolutions.co.uk/clarks-mountain-bikes one) and there'll be many guides on youtube showing how it's done.
| kramdra |
 Posted: 21:03 - 16 Jul 2020 Post subject: |
Got this seemed light, narrow, with some padding.
https://i.postimg.cc/YC5vbLFM/IMG-20200716-201733.jpg
Even with it fully back, I feel like I want another 2 inches adjustment.
Jumping up a small kerb my chain jumped off the front sprocket and stopped the bike dead. Ive had simillar jumping down a kerb with chain jumping off the rear. What is the cause? Only small kerb, was going slow. |
| stinkwheel |
| Easy-X |
 Easy-X Super Spammer
| stinkwheel |
| Ste |
 Ste Not Work Safe
| Easy-X |
| Ste |
 Ste Not Work Safe
| kramdra |
| sickpup |
 sickpup Old Timer
| Easy-X |
 Posted: 01:06 - 22 Jul 2020 Post subject: |
I'd go with the same as a woman motorbike: slightly bigger up front
180mm would probably not be too much of an upgrade (with regards to fork stress) and easy enough to do. Did me okay on my stupid >30mph eBike. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| kramdra |
 Posted: 23:38 - 31 Jul 2020 Post subject: |
The seat is a massive improvement now that my fat arse is used to it. I did upgrade the discs and put sintered pads, much better.
The chain jumping has been a pain. Right when I need power, bang, no power. Decided to replace, picked up new chain and rear sprockets and idlers, Btwin branded from Decathlon. Looks like I need to order the front set, but new dont have much more meat on the teeth. What to get?
Rear sprockets only have minor wear but the old chain is missing 3 rollers, that was the cause.
https://i.postimg.cc/fWvGmxTW/IMG-20200731-171107.jpg
This any good?
https://www.decathlon.co.uk/triple-chainset-7-8-9s-mtb--id_8523921.html |
| kramdra |
| Ste |
 Ste Not Work Safe
| kramdra |
| Ste |
 Ste Not Work Safe
| kramdra |
| Ste |
 Ste Not Work Safe
 Posted: 11:03 - 05 Aug 2020 Post subject: |
9 speed chainrings are completely fine with 8 speed chains.
I think the reason you can't find any that say hardened teeth is because they don't exist and that's because they're not necessary.
Depending on what length cranks you want and what size chainrings you want and that eBay listing for the FC-M311 only has one variant available, the rest are available from Tredz. https://www.tredz.co.uk/.Shimano-FC-M311-Altus-Square-Taper-Chainset_74973.htm
The FC-M371 will be slightly better quality than the FC-M311 however it's going to be the cheap Decathlon chain that wears first. |
| kramdra |
| Ste |
 Ste Not Work Safe
 Posted: 12:44 - 05 Aug 2020 Post subject: |
Your eight speed rear derailleur doesn't come into it.
Go for 28-38-48 if you're happy with those on your old chainset.
How long should the chain, cassette and chainring last? Ages and ages and ages and ages. It will be the chain that's the weak link, no pun intended, but that's only going to reduce the lifespan to ages and ages and ages.  |
| kramdra |
| Ste |
 Ste Not Work Safe
 Posted: 13:02 - 05 Aug 2020 Post subject: |
I do wonder how long rollers had been missing from your chain.
We were busy telling to set up the limit screws on the derailleurs, to check for worn teeth on the chainrings and things like that when it turns out that your chain was literally falling apart.
It's a good example of the importance of thoroughly checking your bike over every so often. Although missing chain rollers is the type of thing that should be noticed when oiling the chain.  |
The last post was made 6 years, 83 days ago. Instead of replying here, would creating a new thread be more useful? |
