| Tonyg1987 |
 Tonyg1987 Renault 5 Driver
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| jeffyjeff |
 jeffyjeff World Chat Champion
 Posted: 01:24 - 18 Jul 2020 Post subject: |
Here is the procedure I use. You might use some of these steps to augment the procedure posted by xX-Alex-Xx
1: Inspect all cooling system hoses before you start. Look for hardened hoses, bulging hoses, soft, weak spots, cracks, or damage caused by overtightened hose clamps.
2: Drain coolant into a 6 to 8 quart capacity container. Loosen drain screw (usually on or near the water pump), then remove pressure cap. Then completely remove the drain screw and direct the coolant into your pan.
3: Remove plastic surge tank (overflow tank) and pour out the coolant. Clean if necessary.
4: Replace defective cooling system components found during inspection.
5: Install surge tank. Install drain screw using a new copper washer.
6: Premix your coolant to the appropriate concentration of antifreeze/water. Use a hydrometer to determine the concentration and therefore freeze point and boiling point.
7: Slowly pour coolant into the system until full. Too much enthusiasm can cause air to become trapped in the recesses of the water jacket. Do it slowly. Don't forget to fill the surge tank to between the lower and upper limit levels.
8: Rock the bike side to side to free trapped air. Top off the coolant.
9: Start engine. The coolant level may drop as the water pump circulates the coolant. Top off the coolant.
10: Replace the pressure cap.
11: Run engine until the thermostat opens. It will achieve that point when the hose going to the top of the radiator becomes hot.
12: Shut down the engine and allow to cool for several hours. When cool, remove pressure cap and top off coolant.
13: Take the bike for a ride around the block. Upon return, check the system for leaks, especially around any parts you replaced during service. After the engine cools, check the coolant level and top off if necessary. If the system is working as designed, the surge tank level will fluctuate slightly, but engine coolant will always be right up to the level of the pressure cap. When the pressure cap goes bad, more often than not it will force excess coolant into the surge tank and out the overflow. That is the classic sign of a defective pressure cap.
NEVER EVER REMOVE THE PRESSURE CAP FROM A HOT ENGINE. Hot scalding coolant can permanently disfigure your attractive mug, and you could suffer the consequence of that mistake for the rest of your life. I know a guy who was off work for 6 weeks when he pressure cooked his hands by removing the cap off a hot radiator. BEWARE. ____________________ History shows again and again how nature points out the folly of men - BOC |
| Robby |
 Robby Dirty Old Man
| Nobby the Bastard |
| Robby |
 Robby Dirty Old Man
| jeffyjeff |
| xX-Alex-Xx |
| sickpup |
 sickpup Old Timer
| redeem ouzzer |
| Robby |
 Robby Dirty Old Man
| jeffyjeff |
| redeem ouzzer |
The last post was made 6 years, 58 days ago. Instead of replying here, would creating a new thread be more useful? |
