Honda CBF600 SA8 2008 Flasher relay
Rick600
PostPosted: 18:18 - 24 Jul 2020    Post subject: Honda CBF600 SA8 2008 Flasher relay Reply with quote
Hi.
This is the semi-faired fuel injection C-ABS version.
Can anyone tell me where the flasher relay is located? I don't want to have to remove all the fairings to find it. It isn't behind the front fairings, looked there already as it seemed the most logical to me somehow. Any help much appreciated.
Thanks.
xX-Alex-Xx
PostPosted: 19:12 - 24 Jul 2020    Post subject: Reply with quote
Tried under the seat? More often than not they’re located around the battery/fuse box area. You could also try behind the clocks. You can probably get a copy of the service manual online if your google-fu skills are strong enough.
DILLIGAF
martin734
PostPosted: 19:14 - 24 Jul 2020    Post subject: Reply with quote
Pretty sure it is behind the rear fairing piece/cowl on the right hand side. You need to remove the seat, side panels, grab rails and rear fairing to get to it.
Current bike: ST1100 "Big Red"
Rick600
PostPosted: 21:22 - 24 Jul 2020    Post subject: Reply with quote
Thanks both. It isn't under the seat or around the battery. I thought probably behind one of the rear panels. Thanks for helping out.
xX-Alex-Xx
PostPosted: 21:25 - 24 Jul 2020    Post subject: Reply with quote
Yeah I’d go with rear panels then. I remember my F4i had a few bits behind the rear panels (regulator etc). Service manual will help you a lot if you can get it.
DILLIGAF
F18
PostPosted: 16:01 - 25 Jul 2020    Post subject: Reply with quote
If it the OEM flasher - find a quiet spot, turn on an indicator and you'll here the little fecker ticking.
Later hornets were certainly behind the rear panel - as above.
Summer is just around the corner
kramdra
PostPosted: 17:07 - 25 Jul 2020    Post subject: Reply with quote
Hondas its normally attached on the headlight loom and hidden in the nose fairing.
Rick600
PostPosted: 17:40 - 13 Aug 2020    Post subject: Reply with quote
Thanks to everyone who replied. I have changed the unit and I can confirm that it is behind the cowl on the right hand side just beside the seat. I was able to wiggle it out just by removing the passenger seat and there was just enough space between the frame member and the plastic cowl to get the old one out and the new one in. It is a tight fit but it can be done. Saves you the trouble of removing the cowl if you just go slow and patient. It mounts with one of those rubber 'band' things around it, then that slips onto a metal flap on the frame.
The last post was made 6 years, 91 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 53.6 Kb
