How the hell do I get a stuck fuel cap to open lol?
RickTaff
PostPosted: 00:20 - 26 Jul 2020    Post subject: How the hell do I get a stuck fuel cap to open lol? Reply with quote
zxr 750 1991. Fuel tank is off the bike, no fuel in it. Key will go into the barrel fine, but will only turn 45 degrees to the right, will not go any further
Have shot wd40 down there, wiggled the key. Pushed down on the key while turning - nothing -... stumped
any ideas would be greatly appreciated Laughing
Riejufixing
PostPosted: 00:33 - 26 Jul 2020    Post subject: Reply with quote
Try it upside-down or at some other angle? Leave it to soak with some solvent in (e.g. petrol) and jiggle the key about while gently turning? Drip some solvent in and blow it out with air then try again?? Swear at it and repeat?
jeffyjeff
PostPosted: 02:22 - 26 Jul 2020    Post subject: Reply with quote
Maybe the lock is working right. After years of storage, the cap and seal ring could be stuck shut. Try adding a pint of gasoline into the tank via the fuel line (that feeds the carburetor). Turn upside down to work the petrol toward the cap seal. Apply compressed air into the tank as you turn the lock and attempt cap removal. Be prepared for a burst as the cap opens.
PostPosted: 05:32 - 26 Jul 2020    Post subject: Reply with quote
Can't you unbolt it from the tank?
MCN
PostPosted: 07:18 - 26 Jul 2020    Post subject: Reply with quote
Can you unbolt it from the tank?
Asking for a friend.
Pour a boiled kettle over it. Maybe not bubbling hot. Not all at once.
Heating the phuquer may soften the rubber sealing ring and then it might move. It may take a minute or more to heat up the cap, tank neck and seal.
Then either get a new cap or try some silicone grease on the seal of the old one.
Silicone won't harm the rubber seal. Oil based grease might.
And never use an oil based lubrication with a condom either. 😉
Robby
Dirty Old Man
PostPosted: 07:48 - 26 Jul 2020    Post subject: Reply with quote
Is this a bike that has been standing for a while?
If so, the cap locking mechanism is likely to be covered in loads of alloy corrosion - white powdery shite.
Lots of WD40, keep working the key. You will gradually scrape it off by operating the lock.
pepperami
PostPosted: 08:41 - 26 Jul 2020    Post subject: Reply with quote
I’ve said this before and I’ll say it again.
Compressed air and solvents/oils/fuels and enclosed spaces (petrol tanks) are a very dangerous mix. Shocked
You may have no problem for 999 times, the next time BOOM!
Please be careful!
Kawasaki Jimbo
PostPosted: 10:01 - 26 Jul 2020    Post subject: Reply with quote
I had this problem. You can't remove the cap surround because the bolt(s) holding it to the tank are under the cap. WD40, etc. didn't work and I escalated up to brute force, starting with a rubber mallet hoping to break the corrosion (unsuccessful), then on to narrow-nose pliers around the base of the key, and turn. The key survived with a slight twist but it's helpful if you've got a spare. Last resort though.
When it freed it was apparent that the corrosion was in the latch. Applications of oils and solvents through the barrel wouldn't have reached there.
RickTaff
PostPosted: 20:25 - 27 Jul 2020    Post subject: Reply with quote
getting a spare or 2 cut tomorrow. Do you mean insert key into the barrel, and rather than turn it by hand grip it with pliers on the stem of the key and use them to turn it?
RickTaff
PostPosted: 20:28 - 27 Jul 2020    Post subject: Reply with quote
I believe it has been stood for a while in a garage yes. How long though i couldnt say.
RickTaff
PostPosted: 21:21 - 27 Jul 2020    Post subject: Reply with quote
Finally done it! Relief
pepperami
PostPosted: 07:36 - 28 Jul 2020    Post subject: Reply with quote
How did you do it and what bit was stuck?
MCN
PostPosted: 09:46 - 28 Jul 2020    Post subject: Reply with quote
Well?
Spill the beans Punk. (Rick Taff)
RickTaff
PostPosted: 17:31 - 28 Jul 2020    Post subject: Reply with quote
The key wouldnt turn far enough to open the latch. Was like hitting a brick wall. Ended up sticking broken half of the other key into the barrel, and gripping it with needle nose pliers and turning. turned straight away. Oiled the latch and like new now
jaffa90
PostPosted: 22:45 - 28 Jul 2020    Post subject: Reply with quote
Well full marks for
Kawasaki Jimbo
The last post was made 6 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 89.97 Kb
