Honda throttle switch unit
kramdra
PostPosted: 13:17 - 25 Jul 2020    Post subject: Honda throttle switch unit Reply with quote
Mine is broken and has been a while. Ive tried to find a replacement. The lid of the switch gear is nylon and has two threads on the back for the throttle cables, one is M12x1 and the other is smaller. It appears common for the nylon to crack on the threads, as they are very thin plastic, there are a couple cracked on ebay.
Seems common part across most Hondas, other than later ones have no light switch, or have hazard switch instead, and different connector - but I can sort that easy. I can buy a tatty used item for 15-30 quid, new ones seem unobtainable.
I can sort a smaller switch unit if there is something aftermarket available for the throttle, but it does need to fit standard cables. Chinese item, appears to be two identical smaller threads.
www.ebay.co.uk/itm/For-7-8-22mm-Motorcycle-Accelerator-Twist-Quick-Action-Throttle-Grip-Black/123391981113
What else is there?
jeffyjeff
PostPosted: 16:35 - 26 Jul 2020    Post subject: Reply with quote
what bike is it - year, make, model?
Campbell SOUP
PostPosted: 17:18 - 26 Jul 2020    Post subject: Reply with quote
From previous posts its for a CBR600 F4i
Would this be what you're after?
https://www.cmsnl.com/products/sw-set-st-kill_35013mbwa10/#.Xx26DVqSlaQ
35013MBWA10 is the original part number for googling purposes. I usually use the exploded assembly diagrams on Fowlers Parts then go from there.
The last post was made 6 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 36.04 Kb
