2015 Keeway Superlight 125
Goonerruss
PostPosted: 15:35 - 27 Jul 2020    Post subject: 2015 Keeway Superlight 125 Reply with quote
Afternoon everyone,
So I recently purchased the above bike and so far so good, I do however have a few nagging issues which hopefully someone will be able to help me out with Smile
Ok so the issues are:
1: Fuel gauge reads half when bike is off and then full when running regardless of fuel level.
2: RH indicators do not work front and back, LH indicators are absolutely fine.
3: Rev counter goes up to 2000 rpm but then nothing yet engine rpm goes right through to redline territory, 0-2000 rpm is fine but anything after that it just doesn't register.
4: Neutral and 1st seem to have a mind of their own, they both tend to go missing. When riding and coming to a stop I tend to go back down through the gears before coming to a stop but for whatever reason 1st sometimes just isn't there and I have to pull away in 2nd. When returning from said ride I have to play the up down game until neutral eventually reveals itself.
5:Bike feels hesitant and somewhat jerky when say in 3rd and doing a steady 30mph almost like it's hitting multiple flat spots Confused , feels spot on when giving it the beans and going up through the gears (I have cleaned the carb and put fresh fuel in).
Any help or advice would be greatly appreciated.
And I thought buying a keeway was a good idea...
Easy-X
PostPosted: 16:08 - 27 Jul 2020    Post subject: Reply with quote
1) I never had a problem with mine like this but it'd be worth disconnecting the gauge and checking what voltage you have from the level sensor. E.g. empty the tank and see if it varies when you pour in fuel from a jerry can, basically to decide if it's a sensor or gauge fault.
2) The Superlight runs "Harley-Style" push button indicators. I'd suspect the RH switch is faulty. Find the connector for the right hand cluster and check the switch is actually working after that I'd suspect the relay. (Should be blue/red wire for the left switch, red/yellow for the right and black for ground.)
3) For the rev counter I'd suspect the mechanism has some grit in it or something. If you disconnect the tacho cable from the engine side you can try giving it a whizz with an electric drill and see if it does the same thing.
4) These Chinese gearboxes are a bit shit Smile I often had a game of hunt the neutral (seem to be affected by engine temperature and oil quality) but not finding 1st doesn't sound good Sad Might be the gear selector drum is worn but you'd have to dive into the engine for a peek at that.
5) I had the EFI version so I only had the issue that (deliberately for emissions) it was always running a tad lean. From the manual the carb looks like the most generic diaphragm-type one could get Wink This is less a Keeway specific issue and more of a shit Chinese carb thing. Usual stuff: check diaphragm for tears, float height, etc. If you're sure the carb's nice and clean you could try moving the clip on the main jet needle down one position - should add some fuel in the midrange.
I'll PM you the service manuals. Badly written and badly translated Chinglish but better than nothing Very Happy
Goonerruss
PostPosted: 16:14 - 27 Jul 2020    Post subject: Reply with quote
Fantastic advice, really appreciate the feedback, I'll get cracking on with it as soon as it stop bloody raining
The last post was made 6 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.3 - MySQL Queries: 13 - Page Size: 40.2 Kb
