Needs a "frame change"?
hellkat
PostPosted: 21:51 - 27 Jul 2020    Post subject: Needs a "frame change"? Reply with quote
The Esteemed Daughter is looking at bikes, and has spotted this, which I think she quite fancies.
https://www.bikesales.com.au/bikes/details/2018-Ducati-Monster-659-ABS/SSE-AD-6724408
So effectively its an accident damaged bike/write off.
But she has asked me to ask you guys ( Rolling Eyes ) ...
Is a frame change an expensive option?
Sounds like it to me, but I'm guessing you could pick one up at a breakers for reasonable price.
I'm not asking you to talk her out of it ... just explain why she shouldn't (or indeed should) buy it.
Neither of us has particularly high levels of mechanical knowledge, although ... she is younger and quicker-minded than me these days, she could probaby learn.
If she wanted to Shocked
A100man
PostPosted: 22:01 - 27 Jul 2020    Post subject: Reply with quote
Hmm, so it doesn't need a frame change due to damage but requires one for admin purposes in NSW, Australia - is that correct?
My FZ750 is a frame swap - it makes it worthless to a collector but as a hack it doesn't bother me. In UK reg number goes with the frame so my 1988 bike became 2 years younger with the 'new' frame.
In terms of mechanical know how it shouldn't be too bad - the most tricky part will be routing the wiring and cables correctly. Also if there are any seized fastenings although if looks too new for that.
Overall you have to take into account the hassle, the time the cost of the new frame and how much value the frankenbike then loses..
hellkat
PostPosted: 22:04 - 27 Jul 2020    Post subject: Reply with quote
Yes I expect thats the situation.
In order for it to be a road bike ... I guess ... as he talks about making a track bike out of it, so I have to assume the frame as it is would not be roadworthy.
c_dug
PostPosted: 22:05 - 27 Jul 2020    Post subject: Reply with quote
Regardless of the cost which, obviously will vary from bike to bike, it's A LOT of work, it's not something I'd happily choose to do based purely on the amount of space, time, and effort required, rather than outright difficulty.
PostPosted: 22:35 - 27 Jul 2020    Post subject: Reply with quote
I've "reframed" two bikes. The mechanics of it aren't too bad IF you have a complete bike to change over with all the fixtures and fittings. That said, it's not straightforwards either, on a modern bike there are an inordinate number of small fiddlty bits that need to go in the right place in the right order. You don't want to get the engine in then find you needed to fit the airbox first or that you got the wiring loom looped the wrong way round a chassis beam.
That aside, both the ones I did were, on paper at least, complete and fully working motorcycles, even if they were actually a pile of knackered rusty shite out the back of an indian takeaway. As far as the DVLA were concerned, I'd simply changed the engine on a totally vanilla motorbike, not built a bike up from scratch onto a bare frame.
So I'd say you'd want the "frame" side of the deal to appear on its paperwork as a complete bike and you're just swapping the engine, even if the frame is the only bit of it you're actually using.
Not sure how the rules work down-under though.
EDIT: A less scrupulous person might just swap the VIN plates and make sure they kept the new "frame" in their posession.
Riejufixing
PostPosted: 22:46 - 27 Jul 2020    Post subject: Re: Needs a "frame change"? Reply with quote
I am not sure what their rules are. I would be inclined to search for the vehicle in the 'Stralian "write off" databases that seem to exist, and find out whether the vendor is telling the truth. Apart from that:
"On his second day riding he tipped over at very low speed. We all know how easy that is to do. My insurance company made it a statutory write off for economic reasons meaning that it can’t be registered without a frame change. There isn’t much wrong with it. The cosmetic damage cost would be high if new parts were used. Damaged hardly. A great track bike."
*In context* what does that really mean?
PostPosted: 22:51 - 27 Jul 2020    Post subject: Reply with quote
Also always worth mentioning the old addage "If it seems too good to be true, it usually is.".
If it was quick and easy to do, why haven't they done it?
PostPosted: 08:23 - 28 Jul 2020    Post subject: Reply with quote
I can sum this advert up in one easy to digest phrase that Minellials should understand.
Dodgy AF.
Robby
Dirty Old Man
PostPosted: 08:39 - 28 Jul 2020    Post subject: Reply with quote
It's the equivalent of a category B (in old money) write-off over here. Australia does seem a bit more keen to do write-offs where the vehicle can never go back on the public road than we are.
In terms of time/cost, she would need to:
1. Get a frame that can go on the road. Traditionally done by buying a vehicle that was stolen, ragged and vandalised - blown engine, knackered bodywork, but good frame.
2. Strip everything off both bikes.
3. Put all the good bits on the frame that can go on the road.
4. Get rid of all the other crap.
It's 2-4 days work for someone competent, followed by a few more weekends of fiddling to get it all right. A frame is likely to be quite expensive, seeing as the bike is only 2 years old - you aren't going to find breakers yards full of them.
Tdibs
PostPosted: 11:24 - 28 Jul 2020    Post subject: Reply with quote
North worth the time/money tbh unless you are keen on spannering. Also I would leave it as a big question mark how truthful the advert is, any the likely hood of finding more (expensive ducati) damage.
Also tanks resale value.
wr6133
PostPosted: 12:23 - 28 Jul 2020    Post subject: Reply with quote
Strip one frame and reassemble on to other based on what you photograph/video when stripping.
Unless the saving is HUGE I wouldn't bother and I'm confident that I could do it (with the aid of a workshop book). It won't be "fun", it'll be a frustrating learning experience of what it would be like to work in the Ducati factory if the factory was a small garage and your daughter the sole employee Laughing
Though that may be the easy part, compared to actually getting a replacement frame that isn't written off and doesn't kick the bottom out of the budget bucket.
That's why I think she shouldn't do it.
hellkat
PostPosted: 14:31 - 28 Jul 2020    Post subject: Reply with quote
Yeahhhhh she's not the most patient of girls. Laughing
(Italian blood, she gets very angry very quickly) Laughing Wub
MaybeGuy
PostPosted: 15:25 - 28 Jul 2020    Post subject: Reply with quote
It's not a frame swap... It's an engine swap. Wink
Over here it's a very simple process. Swap "engine", get a blue slip to check and update the new numbers. And you're free to register it.
NSW has dumb laws that mean no kind of write off can return to the road unless you're the one who owned it at the time. It means the scrap auction lots are full of brand new cars with fender benders.
You need a receipt for the engine, so the buyer would need to provide it to prove its not stolen.
I own an engineering company in Lisarow, about an hour north of Sydney if it's of any use for the swap. Enjoy finding just a frame though.
The last post was made 6 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 81.54 Kb
