HONDA 125 CD BENLY 1984
Princessdarks...
PostPosted: 16:13 - 07 Aug 2020    Post subject: HONDA 125 CD BENLY 1984 Reply with quote
Hi everyone
I am currently rebuilding my Honda 125 cd. The parts are in Hull being sprayed. The engine is in the garage with pistons scratched
I have ordered a new piston and barrel set. Along with head gasket set
too.
They called me today and said I need a new oil filter for this engine. Can anyone advise me on where I cohld purchase one? I'm really struggling to find
one. Many thanks all
:D :D
PostPosted: 16:17 - 07 Aug 2020    Post subject: Reply with quote
I don't think they have a filter, just a metal gauze type set up.
Wemoto suggest that also.
https://www.wemoto.com/bikes/honda/cd_125_t__benly_12_volt/84/picture/oil_filter_screen___strainer
Fisty
PostPosted: 16:18 - 07 Aug 2020    Post subject: Reply with quote
They don't have a filter just a strainer/gauze.
Edit:-beaten by Paddy, wot he sed.
Fatter and faster than Fret
PostPosted: 16:21 - 07 Aug 2020    Post subject: Reply with quote
Fisty wrote:
beaten by Paddy
I'd accept a beating from Fisty, any day.
pepperami
PostPosted: 16:53 - 07 Aug 2020    Post subject: Re: HONDA 125 CD BENLY 1984 Reply with quote
Princessdarkside wrote:
Hi everyone
too.
Very Happy Very Happy
Hmmm? Who is THEY?
As far as I can remember that bike has a gauze filter.
Are THEY trying to con some money out of you??
Nobby the Bastard
Harley Gaydar
PostPosted: 18:35 - 07 Aug 2020    Post subject: Reply with quote
Paddy. wrote:
Fisty wrote:
beaten by Paddy
Get in the queue.
Triumph Sprint ST 1050
steve the grease
PostPosted: 18:44 - 07 Aug 2020    Post subject: Reply with quote
It will also have a centrifugal filter built into the end of the crank.
There was some discussion on here a week or two back in a thread about a CB125S.
Basically the oil runs through a chamber before it goes into the crank.
Any heavy bits ( metal) and other crap gets flung out to form a hard paste on the sides of the chamber.
Undo the cover and scrape the crap out. 3 phillips screws under the clutch cover. It's not the sort of filter you do every 3000 miles.
jeffyjeff
PostPosted: 18:57 - 07 Aug 2020    Post subject: Reply with quote
The attached pic above also appears to show a strainer screen, similar to the one on a YBR.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:14 - 07 Aug 2020    Post subject: Reply with quote
Any reason why the strainer cant be cleaned.and reused?
jeffyjeff
PostPosted: 20:59 - 07 Aug 2020    Post subject: Reply with quote
That is the recommended service for the YBR. Clean it and reuse it until it becomes damaged or otherwise unserviceable.
steve the grease
PostPosted: 16:01 - 09 Aug 2020    Post subject: Reply with quote
The gauze cant really be considered a filter as such... is there to stop rocks , lumps of crap ( and anything else that has got in the engine via the dipstick hole) and balls of blue hylomar getting dragged into the oil pump and wrecking it. On cars the similar gauze is called a strainer....
Nobby the Bastard
Harley Gaydar
PostPosted: 18:57 - 09 Aug 2020    Post subject: Reply with quote
Thats bollocks. I've cleaned them in the past.
How the fucking hell do rocks get in there?
Paddy?
Fisty
PostPosted: 19:22 - 09 Aug 2020    Post subject: Reply with quote
A strainer is a type of filter.
Fizzer Thou
PostPosted: 21:02 - 09 Aug 2020    Post subject: Reply with quote
Luckily,like the CB125S,the crankshaft is the roller bearing type and so does not need super clean oil like a plain bearing type crankshaft.The centrifugal device gets rid of the fine debris,as shown in the fiche
https://www.cmsnl.com/honda-cd125t-general-export-kph_model50479/partslist/0050.html#.XzBi87B7nIU
The part numbers are the same as for the UK so any Honda dealer would be able to source parts.Good idea to replace the cover gasket as well and to not use instant gasket Wink
Many parts are interchangeable with the CD185 and the CD200T.I bought a wreck of a CD200T and rebuilt it with many new parts,but only as a project.Even after 38,000 miles there was only a small amount of solidified crud that had built up in the centrifugal oil device.
Always have a 'Plan B'
Princessdarks...
PostPosted: 21:23 - 09 Aug 2020    Post subject: 1984 HONDA 125 CD BENLY Reply with quote
Right guys. Just an update... I have attached the images of what the Italian's sent me. As its 2 Italian brothers doing it.
Also I think I've found the correct parts on the honda website. I've also attached that.
Thanks again and hope you all had a good weekend 😀 👍
Fisty
PostPosted: 21:31 - 09 Aug 2020    Post subject: Reply with quote
Part 11. Thats it.
Princessdarks...
PostPosted: 21:35 - 09 Aug 2020    Post subject: HONDA 125 CD BENLY 1984 Reply with quote
I have read all your messages I am picking it up from them tomorrow. And yes my initial thought was clean it up and just re use it.
No they are not scamming me. I couldn't find anyone to rebore my engine until I come across a bloke and in conversation mentioned my bike
He said he knows 2 italian brothers that love motorbike engines and would love to do it. So I called and sure enough they were excited. So far I've ordered a head gasket set. A piston and barrel set. As the pistons are scratched but they don't rebore just put sleeves on? Whatever that means and now they mention and sent me the pictures to this stuff. So I dont think they would scam me plus I've asked how much labour each time and they avoid the question so I genuinely think theyre enjoying it
This engine has not been touched since being built in 1984. Its been sitting in my father's shed for 30 years at least. So I'm quite impressed with how she's working out. I've attached some more images for anyone interested.
Next project. A 1986 genesis fzr
PostPosted: 22:18 - 09 Aug 2020    Post subject: Reply with quote
The rubber bit round the edge of the gauze screen has probably started coming apart, had it happen on a CB125T2.
David silver spares are my usual first go-to place for classic honda parts.
Fizzer Thou
PostPosted: 11:22 - 10 Aug 2020    Post subject: Reply with quote
I looked on the Dave Silver website and,although the CD125T is mentioned,as are the CD185T and the CD200T,those components are not showing.They are still available from stock at Fowlers of Bristol under the model of the CD250U,which just shows how many parts are interchangeable between models
https://www.fowlersparts.co.uk/parts/4859210/cd250uk-1989-e/oil-pump?noredir=1
steve the grease
PostPosted: 22:47 - 10 Aug 2020    Post subject: Reply with quote
Well yes , but it is a very crude filter, filtering out stuff down to about a quarter of a millimeter, which is why I refered lightheartedly to 'rocks, lumps of crap' etc. If you have got crap .25mm circulating round your lubrication system, then you have got problems ( sand might be an example) - which is why I said the gauze isn't really a filter, on it's own it is not anywhere near enough to protect the lubrication system.
A paper filter might filter down to 10 microns which is 25 times smaller than .25mm. Bikes that don't have a paper filter , need some other mechanism for filtering out fine particles, much smaller than can get through the gauze, and a centfrifugal filer is often used , as indeed is the case with the bike being talked about here.
jeffyjeff
PostPosted: 22:59 - 10 Aug 2020    Post subject: Reply with quote
What about a YBR? Those poor little engines have a filter screen and nothing else! Shocked .25mm is probably the best filtering you are going to get, unless the screen begins to load up and the filtered debris take on the role of filtering media; but then flow and oil pressure drops off, and that's even worse. How do you counter that...frequent oil changes. Way more frequently than the factory 3,750 mile recommendation. That may be an inadequate countermeasure, but you do what you can.
steve the grease
PostPosted: 20:57 - 11 Aug 2020    Post subject: Reply with quote
What about Rotary filter, part number 5VLE345100 as fitted to the YBR check out CSMNL, it does sound rather like a centrifugal filter.
jeffyjeff
PostPosted: 05:53 - 12 Aug 2020    Post subject: Reply with quote
Thank you, steve the grease. Looks like it fits just behind the primary drive gear. I had no idea it was there, and I've pretty much read my Haynes manual cover to cover. Best, JJ
The last post was made 6 years, 93 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 123.3 Kb
