Wireless guitar transmitter?
Ribenapigeon
PostPosted: 12:17 - 08 Aug 2020    Post subject: Wireless guitar transmitter? Reply with quote
What's a good or at least half-decent affordable (less than £50) guitar to amp wireless setup?
Cheers musos!
Suntan Sid
PostPosted: 12:23 - 09 Aug 2020    Post subject: Reply with quote
A bit out of your price range but I bought this system.
XVive Wireless System U2 Silver
https://www.thomann.de/gb/xvive_wireless_system_u2.htm
I looked at the cheaper ones but a mate had the system I bought so i went with that. Never had a problem with them, does what it says on the tin!
One thing you need to be aware of is what frequencies the units are using, if there's a group of you all using the same units then you must use different frequencies. Some of the cheaper units only have one frequency!
WD Forte
PostPosted: 13:58 - 09 Aug 2020    Post subject: Reply with quote
2.4Ghz is the usual base frequency of these units
If its just for you, a single channel would do but
if playing in an ensemble, multi channel units would be advised.
48Khz data rate with 24bit ADC/DAC with say around 6 mS latency seems the norm or minimum spec
Lots on Ebay new for less then £50 but I'd consider
a second hand quality make as long as it met the specs
bikers smell of wee
Ribenapigeon
PostPosted: 14:16 - 10 Aug 2020    Post subject: Reply with quote
It's just for playing at home so this sort of thing ok? https://www.ebay.co.uk/itm/Guitar-Wireless-System-Speaker-Audio-Connector-Receiver-Transmitter-Set-/283862367662
Any particular brand to buy or are they mostly the same generic but of circuitry from the same Chinese factory just in different packages?
The last post was made 6 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.44 - MySQL Queries: 13 - Page Size: 39.75 Kb
