1978 Suzuki TS100 won’t start
Shamg
PostPosted: 14:25 - 08 Aug 2020    Post subject: 1978 Suzuki TS100 won’t start Reply with quote
Hello, I’ve recently got a TS100 and I cannot get it to start. It has spark (and a new ignition coil), I cleaned the carb yesterday and fit a new air filter. The bike has plenty of compression. The bike currently has no tank but I have tried pouring fuel into both the carb and directly into the cylinder head and it won’t even fire. There is a small pin hole in the fat section of the exhaust however which appears to leaking oil/fuel. Any advice? Thanks
Should also add I’ve never had this bike running
Easy-X
PostPosted: 14:42 - 08 Aug 2020    Post subject: Reply with quote
Looking at some Google images this looks like a similar beast to my ol' DT175...
You have spark, nice Thumbs Up You have compression (although I'd be curious to know how you'd qualify that) Thumbs Up That only leaves two things generally: are you getting fuel or is the timing sooooo far off it won't catch?
Dripping a little fuel* straight into the cylinder and popping the spark plug back in should get something: a hint that it might start. Have you tried a rolling start? For example: I had the kicker on wrong on my DT at one point and a few degrees made all the difference for ease of starting.
I'm assuming the timing's done via points? Double check the flywheel is all okay. Something like the woodruff key being sheared - effectively the flywheel would be in the wrong position - is a common occurence on larger engines.
*You really don't need much to get some reaction, don't drown it!
Shamg
PostPosted: 14:51 - 08 Aug 2020    Post subject: Reply with quote
Thanks for your reply. My compression test consists of placing my thumb over the spark plug hole and seeing if it will blow my thumb off lol. Good call on the ignition timing though, I will certainly check that. Can’t really do a rolling start atm as the clutch does not function. I have tried fuel straight into the cylinder but it’s almost as if the fuel disappears, could this be a sign of bad piston rings? If I kick the bike immediately after pouring fuel in the cylinder and placing my hand over the spark plug hole (without the plug in) I feel no fuel spray onto my hand
Nobby the Bastard
Harley Gaydar
PostPosted: 14:58 - 08 Aug 2020    Post subject: Reply with quote
So you dont know if you have compression then.
Triumph Sprint ST 1050
Shamg
PostPosted: 15:06 - 08 Aug 2020    Post subject: Reply with quote
Previous owner had it running off a bottle into the carb so I don’t think compression is the issue
Robby
Dirty Old Man
PostPosted: 15:38 - 08 Aug 2020    Post subject: Reply with quote
It's a 2 stroke, so stop pouring fuel into the spark plug hole. You're just making a puddle under the crank.
Make sure the carb is clean and set up properly. Make sure it is getting 2-stroke oil somehow (either via autolube if fitted, or by using pre-mix). Make sure it has a good spark. If it won't even try to start with those bits in place, you've got some work to do.
It's a 40 year old 2 stroke. All kinds of things could be broken. Doing a proper compression test is your first step in diagnosis.
steve the grease
PostPosted: 18:45 - 08 Aug 2020    Post subject: Reply with quote
And emptying the crankcase of petrol....
New plug wouldn't do any harm either.
The last post was made 6 years, 96 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 51.66 Kb
