Getting sparks in the wrong place :O
Bros650
PostPosted: 18:03 - 10 Aug 2020    Post subject: Getting sparks in the wrong place :O Reply with quote
So I've finally retrieved this family heirloom. Had it mot'd & started a couple of years ago & trying to get it started again now, does fire but doesn't run yet. Charged the battery and now I get a spark where the pos cable from battery connects to some other stuff, 50 amp fuse, black connector red connector and silvery can (capacitor type thing). So, bad insulation, obvious candidate (but doesn't look that bad) or faulty component?
Bros 650 grey import (obviously) declared manufactured 1989 (grey wheels) Will attempt to add relevant pics.
Any info/suggestions particularly welcome (except advice to get a decent bike haha).
Nobby the Bastard
Harley Gaydar
PostPosted: 18:12 - 10 Aug 2020    Post subject: Reply with quote
That's the starter solenoid by the looks.
Triumph Sprint ST 1050
A100man
PostPosted: 19:09 - 10 Aug 2020    Post subject: Reply with quote
Aye.. If it doesn't click (to provide mucho amps to the starter motor) and you're feeling brave you can short the two big terminals on it with a screwdriver - they may be under that rubber cap
RhynoCZ
PostPosted: 19:21 - 10 Aug 2020    Post subject: Reply with quote
Before you do anything crazy, clean all the terminals and connectors! Everything has got to be clean and shiny, no green/white oxidation crap.
Bros650
PostPosted: 20:24 - 10 Aug 2020    Post subject: Reply with quote
Ooh interesting, starter solenoid eh? engine turns over fine & the spark doesn't seem to make a difference. Thorough clean & tidy sounds like a good place to start tho & make sure all rubbers are in place properly & see what happens I'd noticed the rubbers may not have seated properly, curled edges etc & the one over the fuse was the wrong way round :O That's the job for tomorrow after work then Smile
Bros650
PostPosted: 20:37 - 11 Aug 2020    Post subject: Reply with quote
Awesome thanks guys, bit of a clean up (not too cruddy) remounted it all correctly with rubber covers in the right place and no more arching Smile starts with power start and runs for a while if I keep blipping it up to 5k. Rather bizarrely will fire without but only once if I leave it for half hour. Gotta see if I can get some carb cleaner in. Don't want to remove carbs as they're a real pain to put back. Kudos for your responses, thanks Smile
Nobby the Bastard
Harley Gaydar
PostPosted: 09:11 - 12 Aug 2020    Post subject: Reply with quote
Sounds like fuel starvation. It could be anything from fuel tap blocked to float stuck.
The last post was made 6 years, 93 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 52.12 Kb
