Fuel leaking when dropped
Lyra
PostPosted: 19:34 - 11 Aug 2020    Post subject: Fuel leaking when dropped Reply with quote
I dropped my ninja 250 while practicing a while ago, and I noticed that the gas cap leaks fuel at kinda an alarming rate. I managed to get it up before I lost to much, but what are your thoughts on that? I asked the dealership and they said that was normal, but my last bike didn't leak, and it seems like an odd choice to make a starter bike extra flammable when dropped. As it is I can't practice after ten, because I don't want to be the person who totaled her bike because of a two mile an hour drop...
yen_powell
PostPosted: 20:06 - 11 Aug 2020    Post subject: Reply with quote
They leak sometimes when the tank is quite full and less so when the tank level is lower.
On carbed bikes a drop can sometimes stop the bike starting straight away which can panic a new rider, not sure what happens with a fuel injected bike as I haven't dropped one of those yet. Just give it a minute or so if it doesn't start straight away and then try again.
XT1200Z and a DR350 in bits
xX-Alex-Xx
PostPosted: 20:13 - 11 Aug 2020    Post subject: Reply with quote
FI bikes start right up as soon as the tip over sensor has sorted itself out. (Apparently) Wink Wink
DILLIGAF
BigTim
PostPosted: 21:32 - 11 Aug 2020    Post subject: Reply with quote
i can confirm this. Thumbs Up
MZ S50B, Suzuki GP100, Honda CBF1000, Honda Blackbird (I like my Blackbird)
Hong Kong Phooey
PostPosted: 21:46 - 11 Aug 2020    Post subject: Reply with quote
What year is the bike? Some leak through the bolts holding the cap surround.
jaffa90
Check the cap rubber ring / s and the tank mating surface.
I would not expect fuel pi**ing out of a breather hole in the cap.
Easy-X
PostPosted: 21:50 - 11 Aug 2020    Post subject: Reply with quote
Petrol's very good at finding its way through even the slightest of cracks or gaps - gaps small enough to not let oil or water through.
MCN
PostPosted: 20:24 - 12 Aug 2020    Post subject: Reply with quote
All tanks must be vented or they reach a state where atmospheric pressure is greater than the weight of the fuel (other fluid) and the effect of vacuum inside thebsealed tank. Therefore, the fuel will be trapped inside.
Tanks vent through the cap or via more sophisticated means such as pipes/tubes leading to a lower point on the frame under the tank.
If you have the latter type there will be a small hole or more in the tanks cap fitting. These allow the tank to vent but will prevent fuel spilling out if leaned or dropped.
If the seal on the cap is old then all the above is redundant as the seal can simply leak fuel.
PostPosted: 08:59 - 13 Aug 2020    Post subject: Reply with quote
All the bikes I've seen dropped have leaked a bit through the filler.
The last post was made 6 years, 92 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 59.42 Kb
