Easy question about Bros carbs
Bros650
PostPosted: 22:04 - 16 Aug 2020    Post subject: Easy question about Bros carbs Reply with quote
Can't quite relate the service sheet diagrams to the carbs on the bike. I reckon the bike is all original and generally the carbs seem to be as per description however, the main jet and slow jet appear to be next to each other on the sheets but only the needle jet appears in my pics. I may be a bit more used to carbs from the 50's & 60's Rolling Eyes haha. So where does the slow jet emerge into the air stream? Surprised
There are 2 holes in the face of the air inlet, what do these do?
jaffa90
PostPosted: 22:46 - 16 Aug 2020    Post subject: Reply with quote
More info on the Honda and carbs,
also crap pic.
PostPosted: 23:16 - 16 Aug 2020    Post subject: Reply with quote
It can be a tiny pinhole. If you take the nozzle off and squirt carb cleaner up the jet directly from the can, it'll be obvious.
steve the grease
PostPosted: 20:03 - 17 Aug 2020    Post subject: Reply with quote
It's usually a tiny pinhole downstream from the butterfly/ slide.
The 2 holes. One is the air inlet for the slow running circuit, the other either feeds the air supply to the emulsion tube or is a vent for the float chamber ... it's probably the emulsion tube. thinking about it.
The last post was made 6 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 39.21 Kb
