1989 1200 won't charge!
merlin480
PostPosted: 20:27 - 16 Aug 2020    Post subject: 1989 1200 won't charge! Reply with quote
Hello guys! looking to the Gods of the FJ universe for some help. I have an 89 1200, the bike fell off the sidestand yesterday and cracked the stator cover. Not a problem I have a spare. however the bike stopped charging. When I removed the cover, everything looks fine, the only issue I can find is that there is a small magnetic switch that reads small protrusions on the wheel attached to the crank. My issue with this switch is that the resistance across the switch reads the same whether it is in contact with a protrusion or not. I cannot even find a reference to this switch in my Clymer manual. Please help!!
jaffa90
PostPosted: 21:40 - 16 Aug 2020    Post subject: Reply with quote
""" small magnetic switch that reads small protrusions on the wheel attached to the crank. My issue with this switch is that the resistance across the switch reads the same whether it is in contact with a protrusion or not."""
Pics please.
Robby
Dirty Old Man
PostPosted: 22:18 - 16 Aug 2020    Post subject: Reply with quote
Sounds like you're talking about the hall effect sensor/ignition pick-up coil. It doesn't ever touch the trigger wheel, just sits close to it. It is triggered to produce a small electrical charge (signal) based on the protusions on the trigger wheel spinning past it.
Hopefully workshop manual will give you the proper clearance from the trigger wheel. Generally you want it very close, but not touching. Sort of thing you set with a feeler gauge.
WD Forte
PostPosted: 22:50 - 16 Aug 2020    Post subject: Reply with quote
I thought FJ1200 had alternators not stators?
would pics kill ya?
I mean, is there anybody who doesn't have a phone/camera nowdays?
Also if it was an ignition trigger and it broke,
how could he run the motor to discover it wasnt charging?
This is the ass end of an FJ alternator mounted above the
'stator cover' where the pimple switch err I mean pulse generator is
The impact may have cracked a solder joint on the diode pack
or damaged the brush holder
https://www.bilder01.mcr-dortmund.de/19749-5.jpg
4/10 must do better
bikers smell of wee
merlin480
PostPosted: 23:36 - 16 Aug 2020    Post subject: Reply with quote
Here are a couple pictures. I have the Clymer manual for this bike ( which I have owned since 2003) there is no mention of this sensor in the manual.
PostPosted: 07:22 - 17 Aug 2020    Post subject: Reply with quote
As above, that's a hall effect sensor and nothing to do with the charging system. If the engine is running, it's working fine.
As with WD forte, I'd go with a broken brush or one not making contact. Also checkthe battery terminals are making good contact.
WD Forte
PostPosted: 13:54 - 17 Aug 2020    Post subject: Reply with quote
Is that a sheared off bolt bottom left of the trigger?
bikers smell of wee
merlin480
PostPosted: 15:39 - 17 Aug 2020    Post subject: 1989 1200 won't charge! Reply with quote
Yes WD Forte that is a broken bolt. I have left hand drills and easy outs, That will be no issue. My question remains if this sensor has the same resistance across it regardless of whether it is near metal or not then what is it's purpose? If it is attached to the charging system it must have some function of charging.
Kawasaki Jimbo
PostPosted: 16:35 - 17 Aug 2020    Post subject: Reply with quote
It's probably not a good way to check.
stinkwheel wrote:
If the engine is running, (the sensor is) working fine.
merlin480 wrote:
the bike fell off the sidestand yesterday and... the bike stopped charging.
How did you test that?
PostPosted: 17:28 - 17 Aug 2020    Post subject: Re: 1989 1200 won't charge! Reply with quote
It's part of the ignition system, not the charging system. You can't do a static functional test of a hall effect sensor, it needs a moving mass of ferromagnetic material nearby to trigger it. You need an oscilloscope to test one properly.
Once again, if the bike is running, it is working properly. If it wasn't, you would have no spark.
https://en.wikipedia.org/wiki/Hall_effect_sensor
WD Forte
PostPosted: 18:00 - 17 Aug 2020    Post subject: Reply with quote
Merlin
To sum up:
Apart from fixing the sheared bolt, forget that area
If the bike runs, its fine.
Your problem is in the alternator mounted above and behind the cylinder block
or, as said above and if you're lucky, a bad connection due to shock/impact.
The lead from the alternator probably goes to somewhere around the starter solenoid and main fuse block and battery.
I'd check clean all these then test again before taking the alternator apart.
Incidentally
lets call it the 'Timing cover' to avoid further confusion
you dont have a stator.
bikers smell of wee
The last post was made 6 years, 88 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 70.27 Kb
