| droog |
 droog Spanner Monkey
 Posted: 15:26 - 21 Aug 2020 Post subject: Aluminium or Stainless Steel? |
Hi, hope everyone is doing ok and enjoying their bikes!
I just want to apologise in advance for my personal aluminium washer psycho-drama outlined below - but I reckon if anyone on the planet understands the importance of this stuff its you guys on here.
I Just wanted to check that I am looking at aluminium washers here (pics below) and not stainless steel? The pics below show Honda OEM M6 washers for the CBR cam-holder bolts - I'm pretty sure these are alumiinium as you wouldn't use stainless steel for an application like this right?
Reason I ask is that I got totally fleeced buying X8 official Honda OEM washers for the cam-holder - so when they arrived I measured the thickness of the brand new Honda OEM washers at 1.5 mm on the mic.
So now I know the exact spec of the OEM washers I have ordered 20 aluminium M6 washers off Ebay with 1.6mm thickness for a fraction of the cost of OEM for next time I do this job or if I have to take the cam off again.
The orginal factory fitted washers on the cam-holder were copper and not aluminium anyway - so there is obviously no 'special unique washer' for the cam holders which justifies the exorbitant cost of OEM.
From what I can see if they are aluminium/copper, are M6 and the same or near as dammit thickness they should be fine.
Cheers.
https://i.ibb.co/p1cYXsS/HONDA-WASHER.jpg
https://i.ibb.co/hf6ztPY/HONDA-WASHERS.jpg |
| Riejufixing |
 Riejufixing World Chat Champion
 Posted: 15:35 - 21 Aug 2020 Post subject: |
My first thought is it looks like BZP steel. Edit: I've been had, you said they were OEM aluminiun pics!
My next thought is that without having one in my hand, an easy test is to rub one edge across a file, going with the line of the teeth. If it's aluminium, it will groove very easily (you can compare it to an ordinary steel washer) because aluminium is a comparatively soft and sticky metal. You should still be able to use the washer after. You could also try a scratch test, using for instance a nail on the edge of the washer (comparing the result to steel).
Edit: copper's a bit stronger than aluminium, and it's easy to tell what it is  |
| stinkwheel |
 Posted: 16:40 - 21 Aug 2020 Post subject: |
Unless it's martensitic stainless (which is unlikely in this application and would not be cheap at any rate), it'll be slightly magnetic. Aluminium is in no way magnetic. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| droog |
 Posted: 20:43 - 21 Aug 2020 Post subject: |
Thanks for both your replies - much appreciated.
I tried the magnet test (I should have worked this out for myself but I was bogged down in other detail )
Yep - no magnetic attraction whatsoever - so definitely aluminium.
Ok - the upshot is that I spent way too much money on the Honda OEM aluminium washers and I'm feeling foolish for doing so - I went strictly OEM because this is my first cams out job and I was anxious to do everything by the book.
If I was doing this again I would have ordered the one washer, established what it was made out of, the thicknes and OD and sourced the equivalent much cheaper off ebay. |
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| droog |
| mentalboy |
 mentalboy World Chat Champion
| droog |
The last post was made 6 years, 65 days ago. Instead of replying here, would creating a new thread be more useful? |
