Bleeding front brakes Suzuki B-King
David_viny
PostPosted: 04:17 - 23 Aug 2020    Post subject: Bleeding front brakes Suzuki B-King Reply with quote
Long story short, it was impossible to bleed my brakes by vacuum or manually unless I removed the brake lever. Apparently, the brake lever pre-loads the master cylinder piston in slightly at rest and there is no adjustment to back it off any. That was enough to not allow bleeding apparently. Got it all bleed and its working fine now but it has got me wondering if that's normal.
Is it normal for brake levers to slightly pre-load the master cylinder?
I always thought there should be a tiny air gap between the lever and the plunger when fully extended?
Thanks - Dave
2008 Suzuki B-King
2005 GasGas EC250
sickpup
Old Timer
PostPosted: 14:03 - 23 Aug 2020    Post subject: Reply with quote
No it isn't normal and could have caused a serious accident. Probably a cheap after market lever.
Someone will be along shortly to tell you it happened to them.
jeffyjeff
PostPosted: 19:31 - 23 Aug 2020    Post subject: Reply with quote
Agree with sickpup this is not normal. Your master cylinder piston is not returning far enough to uncover the fill port and compensating port. Without a free and clear passage to the reservoir, the trapped brake fluid will heat up and expand in heavy use, causing the brake to drag and possibly lock. Shocked You really should find and fix the cause of this abnormality.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:58 - 23 Aug 2020    Post subject: Reply with quote
What they said .
Triumph Sprint ST 1050
David_viny
PostPosted: 20:14 - 23 Aug 2020    Post subject: Reply with quote
Ok, thats what I thought. Whats very weird is its all stock, and it seems to work fine now so i'm not sure what to do lol. Levers looked fine, no weird wear on anything.
The only thing I can think of is someone rebuilt the master and the rod is too long?
Also my clutch is like that too... I didnt try to bleed it with lever on though.
2008 Suzuki B-King
2005 GasGas EC250
Nobby the Bastard
Harley Gaydar
PostPosted: 20:32 - 23 Aug 2020    Post subject: Reply with quote
I did buy a master cylinder kit for my fz where the connector rod was longer than the original and didnt fit so this is possible .
In that instance it was obviously too long so I just used the original.
The last post was made 6 years, 65 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 46.58 Kb
