M.2 drive question
kerr
PostPosted: 18:51 - 09 Sep 2020    Post subject: M.2 drive question Reply with quote
Trying to figure out which M.2 i would need, my mobo has 2 slots, thge first one has a 500gb in already but im trying to figure which type the 2nd slot would accept.
https://www.asrock.com/mb/AMD/B450%20Steel%20Legend/#Specification
1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280/22110 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x2 (16 Gb/s)
Don't want to pay moneys and find it wont work in the system, would this one do?
https://www.overclockers.co.uk/wd-blue-sn550-1tb-nvme-m.2-2280-pcie-gen3-solid-state-drive-wds100t2b0c-hd-56l-wd.html
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
xX-Alex-Xx
PostPosted: 19:43 - 09 Sep 2020    Post subject: Reply with quote
Your board supports NVME so definitely get that over SATA.
Looks like the board supports 2280 so the drive you picked will be fine.
DILLIGAF
PostPosted: 21:13 - 09 Sep 2020    Post subject: Reply with quote
That is a good M2.
Honest opinion after having mine for 2 years, worth every penny, I do have a cooler on mine and it is the 970 Evo.
They get hot, unsure what you are running case wise, but I would 100% get a head spreader and ample airflow.
Use the top most M2 slot, using both would disable some SATA ports I believe.
kerr
PostPosted: 00:55 - 10 Sep 2020    Post subject: Reply with quote
Paddy. wrote:
That is a good M2.
The case has got loads of airflow, as far as i can tell it shares a lane with 1 of the sata ports?
I have a hard drive in 1 of the 4 but i only really use it for back up, that being said it currently has the new flight sim on it, its not doing the loading time any favours Laughing
xX-Alex-Xx
PostPosted: 08:37 - 10 Sep 2020    Post subject: Reply with quote
If you're using NVME, it'll take up the PCIe bus lanes (the manual will likely say that if you're using one or both of the slots, you'll lose access to one of the 4 lane PCIe slots.
DILLIGAF
kerr
PostPosted: 16:34 - 10 Sep 2020    Post subject: Reply with quote
Hmm might just get a sata drive and save any future headache's
Looking through the manual and it sais, m.2 (2) and sata 3 (3) share lanes, but then the website sais it shares lanes with sata 3 AND 4, the hard drive is currently plugged into sata 4.
This stuff makes my head spin sometimes Rolling Eyes
PostPosted: 18:19 - 10 Sep 2020    Post subject: Reply with quote
I'm not aware of it stealing PCIe. I know it steals SATA... I have a full board of PCIe and 2 M2s and have no issues.
Your one has 2 M2 slots, only if you populate 2 will you affect SATA.
xX-Alex-Xx
PostPosted: 18:40 - 10 Sep 2020    Post subject: Reply with quote
From the website:
M2_2, SATA3_3 and SATA3_4 share lanes. If either one of them is in use, the others will be disabled.
**If M2_1 is occupied, PCIE4 will be disabled.
Supports NVMe SSD as boot disks
Supports ASRock U.2 Kit
So depends what slot his current m2 is plugged in.
DILLIGAF
kerr
PostPosted: 21:03 - 10 Sep 2020    Post subject: Reply with quote
The current nvme drive is in the first slot, i noticed that too but the mobo doesn't have a 4th PCIE Confused
PostPosted: 22:51 - 10 Sep 2020    Post subject: Reply with quote
You have 6
kerr
PostPosted: 14:26 - 11 Sep 2020    Post subject: Reply with quote
Just realised the link i posted was the wrong one, mine is the Matx version Embarassed
So as i understand it, i should be fine to plug the ssd in the 2nd slot and all should be well, as in this board it shares a lane with sata 3.
PostPosted: 00:26 - 12 Sep 2020    Post subject: Reply with quote
You should use the top one, always.
kerr
PostPosted: 16:00 - 12 Sep 2020    Post subject: Reply with quote
I already have the 500gb drive in there, was looking to add the TB one for storing games and photo's and leaving the first slot as boot drive
PostPosted: 16:29 - 12 Sep 2020    Post subject: Reply with quote
Ah I got you, 2 M2 drives, mans flashing the cash Laughing Would recommend a heat sink for them to be honest, they do get hot.
kerr
PostPosted: 18:15 - 12 Sep 2020    Post subject: Reply with quote
Don't tell the Mrs Laughing
I know i should really get a couple for them, I'm assuming you need to take the stickers off befoie sticking on the heatsink?
PostPosted: 09:53 - 13 Sep 2020    Post subject: Reply with quote
I did. They say it's not required but I 100% did. Going to drop a water cooled one next time as I've got some spare fittings.
kerr
PostPosted: 16:57 - 15 Sep 2020    Post subject: Reply with quote
Yup so the other drive isn't working, i'm hearing conflicting info online, some say this board supports 2 nvme's others say 1 nvme and 1 sata drive.
Sigh i always forget the reason i don't like messing around with pc's Sad
PostPosted: 19:19 - 15 Sep 2020    Post subject: Reply with quote
1 x Ultra M.2 Socket (M2_1), supports M Key type 2230/2242/2260/2280 M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Matisse, Picasso, Summit Ridge, Raven Ridge and Pinnacle Ridge) or Gen3 x2 (16 Gb/s) (with Athlon series APU and Raven Ridge 2)**
- 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280/22110 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x2 (16 Gb/s)**
*M2_2, SATA3_3 and SATA3_4 share lanes. If either one of them is in use, the others will be disabled.
That will work OK as 2 NVMEs. Same spec ish as mine, works fine in mine, check disk manager to see if its there.
kerr
PostPosted: 17:27 - 16 Sep 2020    Post subject: Reply with quote
Emailed Asrock and this was their reply
"This motherboard does not support 2 NVMe drives via the M.2 sockets.
M2_1 supports only PCIe M.2 SSDs (NVMe is PCIe).
M2_2 supports only SATA M.2 SSDs."
Ah well i'll have to send this one back.
Thing is the only sata m.2's i've seen have a different key to them
The last post was made 6 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 98.59 Kb
