Squaring off tyres - how fast?
ThunderGuts
PostPosted: 13:56 - 22 Sep 2020    Post subject: Squaring off tyres - how fast? Reply with quote
OK, so I'm obviously aware of the issue but have been fortunate that my last three bikes have all been bought with new/nearly new tyres, that combined with my low annual mileage and the fact I rarely use straight roads as I'm fortunate enough to purely ride for pleasure, means I've not actually encountered the issue as yet. So my two questions are;
1) Does squaring off happen irrespective of riding conditions eventually (on the basis that even a "twisty" route will still probably have a bike spending the majority of the time upright or nearly upright)
2) How quickly does motorway travel knacker tyres out? Is doing the odd several hundred mile motorway journey mixed in with the usual twisty stuff going to see tyres ready for binning rather rapidly, or is the rate this happens at exaggerated and in reality it takes thousands of motorway miles?
Running Scorpion Trail 2 tyres by the way.
TG.
Riejufixing
PostPosted: 14:23 - 22 Sep 2020    Post subject: Re: Squaring off tyres - how fast? Reply with quote
Most of it's down to how you use the throttle and the brake.
Oh, unless you have an outfit. They eat tyres up very quickly indeed.
ThunderGuts
PostPosted: 14:26 - 22 Sep 2020    Post subject: Reply with quote
I'd say 95% of the time I'm pretty easy going on both; I try to plan corners to avoid braking / acceleration and get a smooth transition through them. There are occasions I don't though . . . Laughing
TG.
PostPosted: 14:50 - 22 Sep 2020    Post subject: Reply with quote
Motorway miles do it. None of my bikes have ever really done it except the ones I use to commute on the motorway. In which case you can do it in 3000-4000 miles.
PostPosted: 14:51 - 22 Sep 2020    Post subject: Reply with quote
I tend to ride up the motorway to Scotland, hammer the shit out of the twisties, then back down the motorway again. My tyres land up more like a 50p over time but it certainly squares them then brings them back to more of a round over the course of a trip. For perspective, I'll generally do about 200 miles of motorway and 250-300 miles of twisties on a weekend run with the bike fully laden.
A lot depends on the tyre too. We fitted a new PR4GT to my bike and a road5 to the wifes bike. I'm heavier but I also tend to throw it into corners more enthusiastically. After our Euro tour last summer we'd both done exactly the same mileage. Mine was square and worn/feathered off the edge of the tread, hers looked like new with fair sized unused portions of tread.
I also now have a road5 GT...
A100man
PostPosted: 15:00 - 22 Sep 2020    Post subject: Reply with quote
Run an Avon Speedmaster - since the rear is square to start with you'll never know the difference Wink
trevor saxe-coburg-gotha
PostPosted: 16:29 - 22 Sep 2020    Post subject: Re: Squaring off tyres - how fast? Reply with quote
pretty much yeah - just not as bad as if you've slogged up and down motorways all day every day
Depends on the tyre and how far you're tight-fistedness is prepared to run them. I've had 10k out of a pair of T30s - the chord was showing through and the last three thousand miles were fvcking horrible. I decided to not scrimp on tyres any more because riding on fvcked tyres fvcking sucks.
For average road-orientated bikes, 6-7k is probably about it.
Apparently one key way to prolong life is to exercise restraint from 0 to 30.
Last edited by trevor saxe-coburg-gotha on 08:21 - 23 Sep 2020; edited 2 times in total
ThunderGuts
PostPosted: 16:42 - 22 Sep 2020    Post subject: Reply with quote
Thanks all. Interesting the comment about low speed behaviour. I guess it's all a balance. 6-7k miles for a tyre . . . I can believe that, I bought my bike with 6k on it and it'd just had new boots.
TG.
PostPosted: 16:56 - 22 Sep 2020    Post subject: Reply with quote
Only gas-it in corners.
c_dug
PostPosted: 17:34 - 22 Sep 2020    Post subject: Reply with quote
I do around 12k miles a year and 90+% of that is city commuting.
The last couple of generations of tyres seem to really resist squaring off, my commute hasn't changed since 2012 and I don't think I've had properly square tyres since... T30's's maybe?
In any case, I use Road 5's now, I'm onto my third rear, and they seem to lose some of the sharpness of their profile a bit (not that they're a particularly pointy tyre) but in my experience never become what I'd consider square.
Edit: Oh, and I accelerate like a plonker from traffic lights a few times a week - my average speed is high twentysomething mph, I'm certainly not avoiding low speed acceleration!
Nobby the Bastard
Harley Gaydar
PostPosted: 17:58 - 22 Sep 2020    Post subject: Reply with quote
All of mine end up shaped like 50p pences.
on my commute I'm typically either in a straight line or going round a roundabout for the vast majority of the journey. The roundabouts seem to be the bit that makes the tyres bald first. Metzler Z6s.
Triumph Sprint ST 1050
chickenstrip
PostPosted: 18:27 - 22 Sep 2020    Post subject: Reply with quote
If you fit a new one of these then stay off motorways, do they get a rounder profile as they wear? Smile
PostPosted: 19:02 - 22 Sep 2020    Post subject: Reply with quote
It's actually the safety mileage that's square, speedmaster is a front with a 90% round profile and is groove cut.
If you run them under-inflated too much, they actually go slightly concave round the middle. Laughing
The tread actually mostly stays on the road as you corner and the sidewalls flex so the contact patch is pretty large. I used to run out of ground clearance before grip on the enfield with safety mileage.
xX-Alex-Xx
PostPosted: 21:22 - 22 Sep 2020    Post subject: Reply with quote
Just keep swerving side to side the whole time. Issue will resolve itself. Thumbs Up
DILLIGAF
PostPosted: 08:33 - 23 Sep 2020    Post subject: Reply with quote
not sure if anyone's mentioned it but another kind of deformation that sometimes happens with front tyres is uneven wear nearside to offside, so that the latter chamfers because of crown camber
the ironic implication of this seems to be that, if you avoid motorways and opt for e.g. unmarked back lines, you illeviate rear tyres squaring off but now the problem is with chiselling off the sweet, rounded profile of the front tyre
in practice, what actually happens is that the rear squares off (that's just the natural sort of pattern of wear, eventually), and the front's offside goes angular - but them together, and it can make for some horrible handling habits. bikes never prone to anything resembling slappy fronts start to shake their heads in corners, and when the going gets properly tight, they basically do NOT want to know and you find yourself slipping further and further behind those ahead of you
A100man
PostPosted: 10:03 - 23 Sep 2020    Post subject: Reply with quote
What's in a name.. they were all known as 'squaremasters' back in the day and we feared overstepping the 'corner' Wink The cool kids ran TT100s or Pirelli Phantoms
Riejufixing
PostPosted: 12:30 - 23 Sep 2020    Post subject: Reply with quote
Never heard that before. "Skidmasters", yes. I think I've still got a new one somewhere. Well, unused, anyway. They don't last very long on outfits, either, especially if you start doing 180s...
1198
PostPosted: 18:32 - 23 Sep 2020    Post subject: Reply with quote
I’ve got about7k from a set of Contimotions of predominantly motorway miles over the last couple of years. They’re still plenty legal, albeit slightly square now, but I’m now watching them a little more closely. They weren’t particularly expensive and handle well enough for A and B Road use - I’ve been out this afternoon and covered 125 miles on the twisties and enjoyed them all.
I’ll be putting 325 miles on them tomorrow then the same again Sunday And next Thursday too - I imagine they’ll be about buggered by then. They’re on a ZZR - so hardly a light bike either
garth
PostPosted: 09:14 - 24 Sep 2020    Post subject: Reply with quote
5k motorway miles done in the last three months and the Avon Storms on the V Strom aren't square yet. The trade off for this is there's limited grip. You can't have it all. Pilot Roads come close.
Jozzer
PostPosted: 18:23 - 25 Sep 2020    Post subject: Reply with quote
This is an issue I've suffered for all of my biking career and never been able to cure it as of yet...
No matter how hard I crank it through the twisties (and there's a good few round my way) I still only seem to wear the middle of the tyre out, anyone know what that's all about ?...
ThatDippyTwat
PostPosted: 20:07 - 25 Sep 2020    Post subject: Reply with quote
Commuting - 2K. Thrashing the tits off it - 5K.
Jozzer
PostPosted: 20:30 - 25 Sep 2020    Post subject: Reply with quote
How is it some folk seem to be able to get good mileage from their rear tyres, 7k from a continental ?...
I managed 1600 from my last continental rear (road attack) and that was going easy on it !...
MCN
PostPosted: 21:16 - 25 Sep 2020    Post subject: Reply with quote
Conti Attack are super grippy but they do this by using a softer compound.
I was easily getting 7k+ miles on Metzerlers on an R1200GS.
I tried the Contis and never got much more than 3k to the wire.
So I wont be fitting them again.
Jozzer
PostPosted: 22:29 - 25 Sep 2020    Post subject: Reply with quote
You and me both buddy, especially considering the price of'em...
FretGrinder
PostPosted: 22:32 - 25 Sep 2020    Post subject: Reply with quote
I found the Avon Storm ultra tyres to be a fantastic commuter tyre on my CBF1000 when I had it, they were recommended to me as a good tyre.
I was doing 70 miles a day with a lot of motorway miles and I would would regularly see upwards of 10k miles before the middle of the tyre was on its last legs.
For me, I found that they weren't spectacular in wet or dry but we're good enough in both types of weather for general grip, even on the winter roads.
If I was commuting again, I'd go for the successor, namely the Avon Storm 3D XM.
They pale in comparison to the current OEM tyres I have on the MT-09, after 3k miles, they've had it. I'm on a second set as the other half had pilot road 4's put on when new, so we kept the OEM tyres, so I out them on and saved me some cash this year.
I'm more of a fair weather rider these days as I don't have to commute on the bike anymore and I don't have anywhere safe to keep the bike at work, so I'll be possibly looking for something sticker next year.
Yamaha MT-09
ಠ_ಠ
The last post was made 6 years, 21 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 135.53 Kb
