Mono shock differences?
stirlinggaz
PostPosted: 21:38 - 28 Sep 2020    Post subject: Mono shock differences? Reply with quote
Hi,
Theoretical question.
Seeing as I spent a bit of time on line looking for a replacement shock recently, I have a question.
Genuinely interested.
Mono shocks : looking at 2 here I have in my big box of spares I dragged out of shed due to wasps nest.
Anyway, simple Marzochi or whatever they're called.
Just has 2 adjustment rings at bottom, nothing else fancy.
My question : the thin rod gets compressed DOWN when in use on road, into thick bit with all the seals, gas, oil etc.
The other shock I'm looking at works "upside down" if that makes sense .
Adjustment rings again at bottom. BUT fat bit is at top , with thin rod at bottom so it goes up into fat bit.
Note the use of technical vocabulary.
What's the difference?
Could 1 in theory be turned upside down turning spring round if necessary?
cheers,
GAZ
PostPosted: 22:12 - 28 Sep 2020    Post subject: Reply with quote
Spring is a spring whichever way up it is.
Damper Thinking . Some have gas on top of oil. In theory sealed in seperate compartments and if the seal is leaking, it's fucked anyway. I'm genuinely not sure how well these would play upside down. On remote reservoirs, the gas is usually under the oil anyway.
The basic shocks on my trials bike are sold as being able to be fitted either way up.
The last post was made 5 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 32.62 Kb
