2019 Keeway Superlight 125 torque specs
BrianD
PostPosted: 16:29 - 03 Oct 2020    Post subject: 2019 Keeway Superlight 125 torque specs Reply with quote
Hi All
I need to align my forks after my bike was backed into. I can't find any torque specs. Looking mainly for the upper and lower clamp bolts as well as the front axle.
Thanks! Brian
jaffa90
PostPosted: 16:46 - 03 Oct 2020    Post subject: Reply with quote
The forks maybe bent and unsafe. Do you know who damage your young bike?
BrianD
PostPosted: 17:39 - 03 Oct 2020    Post subject: 2019 Keeway Superlight 125 torque specs Reply with quote
Yes, they paid for paint damage already. I'd like to try to align the front before asking for more money.
PostPosted: 17:44 - 03 Oct 2020    Post subject: Reply with quote
It's probably a generic chinese 125 torque setting. I think there are manuals floating about for generic 125s...
What I'd do, is buy a steel rule and use it to check the fork legs for straightness as you're not just fixing a car park drop, you're fixing something that could potentially put a lot of force onto the fork legs...
BrianD
PostPosted: 18:03 - 03 Oct 2020    Post subject: 2019 Keeway Superlight 125 torque specs Reply with quote
Thanks for the response. As for generic specs, that may well be the case, I have only been able to find specs for older models, and they vary greatly. So far I haven't found any evidence that the struts have a bend. The handle bars aren't perfectly straight when riding though. The car backed into the tyre and twisted the forks a bit but didn't even bend the wheel.
Easy-X
PostPosted: 18:37 - 03 Oct 2020    Post subject: Reply with quote
From the service manual:
Specify tightening torque
NO. ITEM QTY. TIGHTENING
TORQUE
Front wheel/front disc brake
1 Nut, front axle 1 80 N.M
2 Bolt, disc brake 6
3 Bolt 2
4 Discharging oil mouth
5 Collar
6 Mounting bolt, pipe
7
8
Handlebar
1 Screw, uppr handle retainer 4 25N.M
2 Bolt, lower handle retainer 2 4N.M
3 Mounting bolt, disc brake lever 1
4 Mounting bolt, right handle retainer 2
Front fork
1 Fixing bolt, upper connecting board 2 25N.M
2 Fixing bolt, lower connecting board 2 25N.M
3 Press nut 1
4 Fixing bolt, right handle seat 1 40N.M
5
6
7
Rear wheel/rear shock absorber
1 Rear wheel axle 1 105N.M
2 Bolt, rear brake rocker arm 1 6N.M
3 Fixing bolt, sprocket 4 40N.M
4 Fixing nut, shock absorber upper part 2 40N.M
5 Fixing bolt, shock absorber lower part 2 25N.M
6
7
8
BrianD
PostPosted: 18:43 - 03 Oct 2020    Post subject: 2019 Keeway Superlight 125 torque specs Reply with quote
Thank you very much!
Brian
The last post was made 5 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 50.25 Kb
