Tyre won’t take air (with inner tube)
Chrisjlm
PostPosted: 14:00 - 04 Oct 2020    Post subject: Tyre won’t take air (with inner tube) Reply with quote
Hello, I have a Yamaha XT 125 the other day I went to take the bike out but the front tyre was flat, not sure why as it was fine 2 days prior. The pin inside the valve seems to be fine but no air is escaping when pressed in (I’m not sure whether this is due to there not being any air to escape though)
I tried a hand pump for well over 5 minutes but didn’t put any air in so I tried a gas station compressed air machine, first I tried regular mode but nothing happened so I tried the “flat tyre” mode and still wasn’t taking any air in.
Apologies if I haven’t explained well enough I’m pretty new to biking and still learning. Thanks in advance.
NJD
PostPosted: 14:06 - 04 Oct 2020    Post subject: Reply with quote
Surely you're aware that you probably have a puncture on the tube itself and therefore needs replacing?
Worth checking the locknut around the valve stem is tight to the rim (loosen, pull stem by hand and then tighten locknut back up).
PostPosted: 14:21 - 04 Oct 2020    Post subject: Reply with quote
From what you say it sounds like either the valve is faulty and no air is going into the tube or there's a puncture in the tube so air is escaping as fast as it goes in.
If no air was going in the valve then I'd expect the compressor attachment to pop off the valve when you try to inflate the tube.
Either way, I think you need to take the inner tube out to investigate further.
dynax
PostPosted: 14:50 - 04 Oct 2020    Post subject: Reply with quote
Take the valve out and see if it inflates Thumbs Up
Mike.
Bikes: Xena, Bridget,Florence
https://www.youtube.com/channel/UCmihUc0xXxYbR4_0l-F1FzA/videos?view_as=subscriber
PostPosted: 15:57 - 04 Oct 2020    Post subject: Reply with quote
If the valve was jammed, the pump would offer a lot of resistance. If air is going out of the pump but the tyre isn't inflating, you have a puncture.
If you're getting nothing at all even with a compressor, I'd guess the valve has torn off the tube. This is a common issue if you run on an underinflated/flat tyre and the tyre itself slips round on the rim.
If this is what happened and you are running low tyre pressures for offroad grip, consider fitting a rimlock. Or if you aren't using it on the road at all, a mousse.
I run my trials bike at 6psi and the tyre can still slip, even with a rimlock. I never screw the little nut down against the rim for this reason. I put the valve cap on and screw the nut up against it, then if the tyre moves slightly, I'll notice the valve sitting at an odd angle.
Chrisjlm
PostPosted: 17:04 - 04 Oct 2020    Post subject: Reply with quote
So I got the inner tube out and it had completely torn away from the valve. I guess it’s just a case of fitting a new tube then. Any advice on stopping it happening again?
https://ibb.co/wzXgcwG
https://ibb.co/1Tb0fsP
yen_powell
PostPosted: 17:10 - 04 Oct 2020    Post subject: Reply with quote
Old tubes perish so replacing them every tyre can be a good idea.
In addition if you let the tyre run soft or flat it can creep around the wheel rim pulling the valve. If you see a valve not sitting at 90 degrees to the rim then this is what is happening. On trail bikes some people leave the external locking ring or nut off completely or loosened so they can see if this is happening when they run lower pressures for mud or sand.
XT1200Z and a DR350 in bits
Riejufixing
PostPosted: 17:40 - 04 Oct 2020    Post subject: Reply with quote
Security bolts?
PostPosted: 18:06 - 04 Oct 2020    Post subject: Reply with quote
In addition to my previous about running soft tyres etc, you also need to ensure the tyre is properly seated onthe rim when you fit it. There is a thin line on the outside of the tyre sidewall all the way around. You need to make sure you can see this an equal distance from the rim all the way round on both sides.
It can take a lot of pressure to achieve this. I had to put 90psi into the roadrider front tyre on my Enfield with the valve core out to get it fully seated. Once seated, I let the air out again, re-fitted the valve core and inflated it to the correct pressure.
Riejufixing
PostPosted: 18:30 - 04 Oct 2020    Post subject: Reply with quote
[quote="stinkwheel"I had to put 90psi into the roadrider front tyre on my Enfield with the valve core out to get it fully seated.[/quote]
That's dangerous. You should use tyre paste.
PostPosted: 18:39 - 04 Oct 2020    Post subject: Reply with quote
That's dangerous. You should use tyre paste.[/quote]
Not as dangerous as a blow-out. Had plenty of green soap on. They have textured bead-seats and as such are a bit of a bastard. The roadriders are also optionally tubeless fitment so not as forgiving as speedmasters..
Jozzer
PostPosted: 10:42 - 05 Oct 2020    Post subject: Reply with quote
Replace the tube, they're cheap and inexpensive so far easier (and far cheaper) than getting the old one repaired...
Could be one of two or three issues, perished tube (old age) tube has rubbed through inside somewhere (usually caused by under inflation) or proper punctured nail/thorn etc...
blurredman
PostPosted: 12:18 - 05 Oct 2020    Post subject: Reply with quote
Some tyres indeed can be pigs to re-install, esspecially if they're more inclined for tubeless applications.
redeem ouzzer
PostPosted: 13:42 - 05 Oct 2020    Post subject: Reply with quote
I think the Michelin Pilot Sporty on the back of my X5 took 80 PSI to seat. Some beads are just bastards to pop.
Be a REAL MAN!
steve the grease
PostPosted: 18:51 - 05 Oct 2020    Post subject: Reply with quote
Riejufixing wrote:
90 psi That's dangerous. You should use tyre paste.
When I briefly worked in a remould factory the tyre carcasses , once all the tread had been scrubbed off, where mounted on a rim and inflated to 150 psi to check for bulges , punctures etc. So, whilst 90 psi is 'a lot of pressure' which it is, a healthy tyre should easily be able to stand that, for a short time at least.
Jozzer
PostPosted: 19:07 - 05 Oct 2020    Post subject: Reply with quote
Yup, quite agree buddy, I used to work for ATS, 90 should be fine as long as the tyre is in good condition, wouldn't wanna go too far though, 100/110 tops on a 4ply radial...
11-22.5 10ply truck tyres run 100-110 anyway...
It's all in the square inch/volume of the tyre, pressure has little bearing on it... Thumbs Up
PostPosted: 23:32 - 05 Oct 2020    Post subject: Reply with quote
You what?
Pressure is force/area. Volume is a constant in this case and has fuck all to do with it.
PostPosted: 09:57 - 06 Oct 2020    Post subject: Reply with quote
What does PSI stand for and where does volume come into it?
Johnnythefox
PostPosted: 11:11 - 09 Oct 2020    Post subject: Reply with quote
Just had my Harley Sportster MOT and asked them to check front tyre as not holding pressure overnight, new valve fitted (for free) bike passed all done £29.65 - i gave them some money for the workshop tea bag supply.
Jozzer
PostPosted: 23:29 - 10 Oct 2020    Post subject: Reply with quote
Pounds per square inch, the larger the volume (square inch) the higher the "overall" pressure...
10psi times by 10 square inches = 100 pounds of pressure in total, 10psi times by 100 square inches = 1000 pounds of pressure in total, not so much about the psi, more about the volume... Thumbs Up
I can't remember the maths of it all now but when we did our fitters courses we had to work out the overall volume of a tyre (say 16.9-38 tractor rear) at a certain PSI (say 10 or 12psi) and give the overall pressure contained within the tyre...
Things have changed since my day though, now most agricultural tyres are radial and run higher pressures than a crossply of a similar size, a 16.9-38 radial runs 30-34psi these days where as a similar sized crossply back in the day would run 10-12psi...
Crossply's had harder/stiffer sidewalls thus needed less pressure so as to aid grip...
oilyrag
PostPosted: 13:35 - 11 Oct 2020    Post subject: Reply with quote
PSI means Pounds divided by Square Inches. Pressure = Force/Area
Volume only depends on the dimensions. Cubic Inches.
Evil Hans
PostPosted: 01:09 - 12 Oct 2020    Post subject: Reply with quote
Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy
PostPosted: 08:09 - 12 Oct 2020    Post subject: Reply with quote
Oh my fcuking god. Brick Wall Brick Wall Brick Wall Brick Wall
So according to you a tractor tye pressurised to 30 psi is actually at a higher pressure than a pushbike tyre pressurised to 30 psi because its a bigger volume!
Laughing Laughing
Riejufixing
PostPosted: 09:15 - 12 Oct 2020    Post subject: Reply with quote
He did put "overall" in inverted commas, and even put in an example.
I don't know why it's so hard for people to see that. It's correct.
I could quarrel with the "larger the volume (square inch)" in that he should have said "A higher volume results in a larger area in square inches", but the meaning should be quite obvious to anyone.
The last post was made 6 years, 5 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 128.77 Kb
