Spec a video editing PC
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2, 3, 4, 5  Next
Stevie GooGs
PostPosted: 18:07 - 28 Sep 2020    Post subject: Spec a video editing PC Reply with quote
Hi guys i need to upgrade my machine, its now 4 years old and Premier Pro is killing it. If you had 4k to spend what would you build and who would you buy it from. A lot of money but I need something for editing 4k / 5.2k video without having to make proxies all the time. Needs to be a full tower with up to 7 sata drives for storage.
This is not for gaming, wish i had the time for that its for video / photo.
doggone
PostPosted: 19:54 - 28 Sep 2020    Post subject: Reply with quote
Don't skimp on graphics card, Premiere 2020 finally makes good use of it when rendering.
Stevie GooGs
PostPosted: 21:26 - 28 Sep 2020    Post subject: Reply with quote
This is what i spec from scan.
3XS Evolve NLE 4K
• LN110544 3XS 1TB Corsair Force MP600, M.2 PCIe 4.0
• LN94915 3XS Evolve NLE 4K - Threadripper
• LN85337 3XS Microsoft H17-10001 GML Win Logo
• LN87858 3XS Only RM850X 850W Gold Modular PSU
• LN101051 500GB Corsair Force MP600, M.2 (2280) PCIe 4.0 (x4) NVMe SSD, Phison, TLC 3D NAND,4950MB/s Read,2500MB/s Write,420k/550k
• LN90001 64GB (4x16GB) Corsair DDR4 Vengeance LPX Black, PC4-25600 (3200), Non-ECC Unbuffered, CAS 16-18-18-36, XMP 2.0, 1.35V
• LN103289 AMD Ryzen™ Threadripper 3970X, TRX4, Zen 2, 32 Core, 64 Thread, 3.7GHz, 4.5GHz Turbo, PCIe 4.0, 280W, CPU
• LN95547 ASUS GeForce RTX 2060 Turbo 6GB GDDR6 Ray-Tracing Graphics Card, 1920 Core, 1365MHz GPU, 1680MHz Boost
• LN103589 ASUS ROG STRIX TRX40-E GAMING, AMD TRX40, sTRX4, DDR4, PCIe 4.0, 3xM.2, SLI/CrossFire, 2.5GbE, ax WiFi, USB3.2 Gen2, ATX
• LN93233 Cooler Master MasterLiquid ML360 RGB TR4 Edition, 360mm All-in-One Hydro CPU Cooler, 3x120mm PWM Fan, Aluminium/Copper
• LN101250 Fractal Design Define 7 XL, Black, Full Tower w/ Dark Tempered Glass, 3x 140mm Fans, USB 3.1 Type-C, SSI-EEB to Mini-ITX
• LN61513 Logickeyboard Premiere Pro CC - Slim Line Black PC Keyboard
• LN45708 Scan 3XS System - 3 Year Warranty (Mainland UK) - 1st Year Onsite, 2nd & 3rd Year Return to Base (Parts & Labour)
• LN55098 System
• LN92927 Windows 10 Pro High End DPK MUP-00003
Pjay
PostPosted: 22:00 - 28 Sep 2020    Post subject: Reply with quote
Watch some Linus tech tips videos, they are always banging on about video workstations.
https://www.youtube.com/watch?v=EXBGRxmLqOU
Was the last full build I think, it's 4 months old, so speccing in the 3070 or 3060 would be obvious.
struan80 - I'll go first - satisfied tick 1
Stevie GooGs
PostPosted: 23:01 - 28 Sep 2020    Post subject: Reply with quote
Thanks, watching now.
Easy-X
PostPosted: 12:24 - 29 Sep 2020    Post subject: Reply with quote
Maybe look at server/workstation motherboards? Haven't done video editing for a while but is 64GB gonna be enough for >4K?
PostPosted: 17:02 - 29 Sep 2020    Post subject: Reply with quote
If you can wait the 30 series graphics cards are a huge leaper over the 20 series. So big in fact trying to get one is a fucking nightmare Laughing
doggone
PostPosted: 17:53 - 29 Sep 2020    Post subject: Reply with quote
Memory isn't usually what slows them down but it will depend on how may layers or whatever, some things like diffusion effects really hammer it. 64GB is ample with good graphics card doing the donkey work with any applied effects
Stevie GooGs
PostPosted: 09:56 - 30 Sep 2020    Post subject: Reply with quote
Pushing the boat out but one of my mates is telling me to hold of for Zen 3 but not sure when that will be and im struggling atm.
Case FRACTAL DEFINE 7 XL BLACK QUIET TOWER CASE
Processor (CPU) AMD Ryzen Threadripper 3970X 32 Core CPU (3.7GHz - 4.5GHz, 147MB CACHE)
Motherboard ASUS® ROG ZENITH II EXTREME ALPHA (DDR4, Wi-Fi 6, CrossFireX/SLI) - ARGB Ready!
Memory (RAM) 256GB Corsair VENGEANCE DDR4 3000MHz (8 x 32GB)
Graphics Card 10GB NVIDIA GEFORCE RTX 3080 (Pre-Order Only)
1 Storage Drive 500GB Samsung 860 EVO 2.5" SSD, SATA 6Gb/s (up to 550MB/st sR | 520MB/sW)
2 Storage Drive 1TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
Memory Card Reader USB 3.0 EXTERNAL SD/MICRO SD CARD READER
Power Supply CORSAIR 1200W HX SERIES™ MODULAR 80 PLUS® PLATINUM, ULTRA QUIET
Power Cable 1 x 1 Metre UK Power Cable (Ke􀂂le Lead)
Processor Cooling CoolerMaster MasterLiquid ML360 RGB TR4 High Performance Liquid Cooler
Thermal Paste ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND
Extra Case Fans 2x 120mm Black Case Fan (configured to extract from rear/roof)
Sound Card ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)
Wireless/Wired Networking 10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED)
USB/Thunderbolt Op
PostPosted: 12:36 - 30 Sep 2020    Post subject: Reply with quote
The struggle was real!
Would suggest a 3080, but don't buy a non-nvidia one, crashing is unreal currently, rolled back to a 2080 Super.
OP I would not run that all in one water cooler with that threadripper, I would not consider it.
Thermal paste isn't needed, its pre-applied on most of the coolers, helpful as a back up though.
For video, those disks are alright, you can get faster storage at the cost of more heat.
3000Mhz RAM with a Ryzen is retarded, go minimum 3600Mhz base, otherwise you might as well not have a Ryzen. Also try to just get stupidly fast RAM, your board is capable of 4600Mhz, it doesn't even list support for 3000Mhz Laughing
PSU is a bit beefy, but futureproof!
Basically, I would change the RAM and the cooler, you are running too slow and going to get VERY warm in there.
I would consider M2 disks and a PCIe expansion for 4 of them and might be worth getting some sensible cooling for it.
Easy-X
PostPosted: 13:38 - 30 Sep 2020    Post subject: Reply with quote
Worth considering ambient temperature. All the cooling in the world is no use if the room heats up. Scotland though so probably not a problem Wink
Bottom/Front in & Top/Rear out airflow is always good. Ideally a slight positive pressure unless the case is perfectly sealed in which case go for neutral pressure.
According to the specs the DIMM.2 expansion slot runs slightly faster than the under-board slots. There's a lot going on with that motherboard Smile
Stevie GooGs
PostPosted: 23:06 - 30 Sep 2020    Post subject: Reply with quote
Thanks guys so if i change to faster RAM what cooling would you recommend? If specific models that would be fantastic.
I appreciate the help.
PostPosted: 23:17 - 30 Sep 2020    Post subject: Reply with quote
Personally, I like these - https://www.amazon.co.uk/Crucial-Ballistix-BL2K8G36C16U4B-Desktop-Gaming/dp/B083V93HJG/ref=sr_1_3?dchild=1&keywords=3600mhz%2Bddr4&qid=1601503892&sr=8-3&th=1
But you are gonna pay serious money for 3600Mhz+ variants.
Cooler wise, Ryujin ROG cooler would bbe good, otherwise you are goinng to want something massive.
https://www.overclockers.co.uk/asus-rog-ryujin-performance-aio-cpu-liquid-cooler-with-oled-display-360mm-hs-04p-as.html?gclid=CjwKCAjw2dD7BRASEiwAWCtCbyYOOLdkGOW3wzv65J5tc2BvcvDjkDQdAkpZ_q7fZd1OPGBrvxi1yhoCl94QAvD_BwE
Again ROG, they do a Strix 360mm, but I cant see a TR4 socket one in stock.
Just make sure a 360mm rad with a bit of leeway will fit nicely at the top of your case. Want to make sure there is ventilation at the top, looks to be ample room, but your motherboard shroud over the IO might be an issue, might not! You can front mount the radiator, but you have next to zero intake gap there.
I've got full on water so its very different, but I've never had a PC run so cool Laughing
Pjay
PostPosted: 16:50 - 02 Oct 2020    Post subject: Reply with quote
I wouldnt bother with the 3080 unless you really need that much grunt.
The bang for buck sweetspot is the 3070.
Easy-X
PostPosted: 16:52 - 02 Oct 2020    Post subject: Reply with quote
However it's spec'd out be interesting to see some photos of the final build.
Stevie GooGs
PostPosted: 19:48 - 02 Oct 2020    Post subject: Reply with quote
Hey thanks guys, its ordered but been told its a waiting game for the 3080 at the moment so might see what options there possibly the 3070
PostPosted: 10:37 - 05 Oct 2020    Post subject: Reply with quote
But if you are buying a seriously pricey PC with 256GB RAM and a Threadripper... why skimp on the GPU? Wink Just means it will handle anything, rather than get upset later on in life. The wait is annoying and the failure rate of the 3080 right now with aftermarket vendors is horrific Neutral
blurredman
PostPosted: 12:10 - 05 Oct 2020    Post subject: Reply with quote
Athlon 1700, 512mb ddr and an FX5200, that'll sort you right out. Thumbs Up
Stevie GooGs
PostPosted: 17:39 - 07 Oct 2020    Post subject: Reply with quote
GPU will be November at the earliest....
Stevie GooGs
PostPosted: 09:51 - 08 Oct 2020    Post subject: Reply with quote
Is there any other card that comes close to the new series?
colink98
PostPosted: 10:28 - 08 Oct 2020    Post subject: Reply with quote
Apparently not.
even the 3070 is on par with the top of the range 2x series
but the new AMD GPUs are coming.
Ride it like you stole it.
PostPosted: 22:24 - 08 Oct 2020    Post subject: Reply with quote
Expect to hear about the AMD cards shortly. They might pull something out! I've seen some fairly positive news on it!
Stevie GooGs
PostPosted: 18:59 - 10 Oct 2020    Post subject: Reply with quote
Is it covid catching up now with delays in production? Cant get a gfx card and can't get a front tyre for my bike, both on back order.
Pjay
PostPosted: 09:01 - 11 Oct 2020    Post subject: Reply with quote
Paddy. wrote:
Why skimp on the GPU?
I wouldn't say it was 'skimping'.
The price difference between the 3070 and the 3080 isn't worth it for the extra power. 50% more cost for what 10 % more grunt?
Besides, he is video editing which is more reliant on vram than on the 3d capabilities. Buying a 3080 over a 3070 would pretty much just be an extravagance.
I'd have put that extra money into optane and actually get a real world benefit.
PostPosted: 16:13 - 11 Oct 2020    Post subject: Reply with quote
Ok, sure, I'm not going to argue with you, it's tiresome.
The last post was made 5 years, 362 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 5
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 136.11 Kb
